Old Feb 21, 2011, 08:20 PM
Guz is offline
Guz
Find More Posts by Guz
Guz
Gutless wonder
Guz's Avatar
Tempe, AZ
Joined Dec 2005
I really like U-POL Dolphin Glaze
It's available at most auto paint shops or online. It mixes 50:1, so just a dot of hardener for most repairs. The more hardener you use, the faster it sets up.
I LOVE SANDING THE STUFF. It doesn't clog up my sandpaper, and it can be sanded down quickly with heavy grit, but polished up with fine grit.
I haven't tried it on foam, but I think it will work. It doesn't get hot when curing, but smells funny.
I've cleaned up many hollow composite wing, fuselage with this stuff. I usually just airbrush acrylic paint over it (for a semi close color match. I never match exactly, so one can tell there was a repair. That and I hate doing exact color matching )
Guz is offline Find More Posts by Guz
Old Feb 22, 2011, 04:55 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
If you mix it (WS and 410) to the consistancy of peanut-butter, it works well.
R,
Target
target is offline Find More Posts by target
Old Sep 26, 2012, 03:18 PM
Twyl is offline
Find More Posts by Twyl
Silent Flight
Twyl's Avatar
United States, CA, Cypress
Joined Jul 2005
Originally Posted by fcbflyer View Post
Thank you guys to chime in here. I did the 410 epoxy mix before and didn't like it too much.
I ordered a can of split second and will report on the outcome.
So did you ever receive your can of Split Second? What did you think?
-Jonathan
Twyl is offline Find More Posts by Twyl
Old Sep 26, 2012, 03:48 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
If you are mixing the 410 with hobby epoxy, that is your problem. You need a filler-rich mixture with REAL epoxy, not epoxy glue.
R,
Target
Old Sep 26, 2012, 05:02 PM
fcbflyer is offline
Find More Posts by fcbflyer
Sloping the Financial Cliff
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
-Jonathan
Split Second is great, it works really well. I sands easy, I would recommend it.
After you get it to 95% with that filler, I use Glazing putty to finish the Job.
R,
Target
I used West Systems and Jefco with it when I didn't like it.
fcbflyer is offline Find More Posts by fcbflyer
Old Sep 26, 2012, 05:07 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Thanks for the report, Bruno.
I may try to get some of the Split Second to try out.
R,
Target
Old Sep 26, 2012, 05:08 PM
Twyl is offline
Silent Flight
Twyl's Avatar
Joined Jul 2005
Thanks FCB. So in and of itself it is not a replacement for glazing putty? I have yet to do any bondo/filler/whatnot and painting so this is all new to me. I hadn't counted on needing two products to get the job done.
-Jonathan
Old Sep 26, 2012, 06:00 PM
fcbflyer is offline
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
You can absolutely use split second to do the whole job. I just found it faster to use glazing putty to get it perfect.
Old Sep 26, 2012, 06:11 PM
Twyl is offline
Silent Flight
Twyl's Avatar
Joined Jul 2005
Sounds great. Now to find a B&W who sells it. Not really expecting them to have it I checked Autozone but nada.
-Jonathan
Old Sep 26, 2012, 06:46 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
http://www.summitracing.com/parts/UCP-26020/
Old Sep 26, 2012, 06:54 PM
Twyl is offline
Silent Flight
Twyl's Avatar
Joined Jul 2005
Thanks Target, that might be the cheapest I found online. I was hoping to have some this evening or at least by this weekend though so was looking for a B&M (brick and mortar) store that carried it.
EDIT: someone mentioned something about a shop in Long Beach...
-Jonathan
Old Sep 26, 2012, 06:55 PM
Twyl is offline
Silent Flight
Twyl's Avatar
Joined Jul 2005
Originally Posted by s2000 View Post
Here is a picture, G.E. Paint (Gary Elliot runs the place) is I think on Anaheim street in Long Beach just east of Junipero, it is around $25 a can, the can feels almost empty since the stuff is so lightweight, it is just a lttle thicker than whipped cream.
Ah hah!
Old Sep 26, 2012, 06:59 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
There used to be a 3M brand paint supply place on the South side of Anaheim street in Wilmington, near but east of the 110 freeway.
Good luck.
R,
Target
http://www.superpages.com/bp/Wilming...0018537090.htm
http://www.yelp.com/biz/g-e-auto-pai...ies-long-beach
Old Sep 26, 2012, 11:51 PM
dnbarrie11 is offline
Find More Posts by dnbarrie11
RV7guy
dnbarrie11's Avatar
Chandler, AZ
Joined May 2004
Evercoat 416
The best I've found is Evercoat 416 glazing compound. This is for metal or fiberglass. It is very light and sands like butter. It is used as a final fill and not designed for a very thick fill.
I've used this while building two RV 7 "real" planes to do the fit and finish on the glass work for a couple of friends planes.
I've tried most of the others. Super-fil is okay but is an overnight cure deal. I use this for thicker fill needs and try to do it at the end of the day.
Don't use any of the fill products that come in a tube and are not catalyzed. They will never fully cure causing painting issues.
Darwin N. Barrie
Chandler, AZ
dnbarrie11 is offline Find More Posts by dnbarrie11
Old Sep 27, 2012, 09:28 AM
dharban is online now
Find More Posts by dharban
Flying = Falling (Slowly)
dharban's Avatar
Tulsa, OK
Joined May 2004
I like Superfill as described here:
http://www.polyfiber.com/products/su...epoxyfiler.htm
It is a two part epoxy based filler designed for aircraft applications. It is very light, sands easily and will finish to a feather edge better than anything else I have used. And it bonds to almost anything.
While it is excellent on glass surfaces, its ability to finish out to a feather edge is best described when it is used to fill balsa -- even soft balsa -- it can be applied to irregularities on balsa and sanded to a perfect surface finish even though the balsa is substantially softer than the filler.
Of course it is great on glass and composite surfaces.
Happy Landings,
Don
dharban is online now Find More Posts by dharban
Discussion Sandable Glue? ForeverFlying The Builders Workshop 11 Jan 28, 2011 02:30 PM
Discussion FFF sandable filler Crash Trash Foamies (Scratchbuilt) 6 Sep 05, 2009 10:00 AM
best sandable primer? Bob K Foamies (Kits) 1 Oct 10, 2002 11:50 AM
Foam Safe light Sandable Primer S Anastasio Foamies (Kits) 1 Feb 02, 2002 08:40 PM
