Old Feb 19, 2011, 01:20 PM
fcbflyer is offline
Find More Posts by fcbflyer
Sloping the Financial Cliff
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
Question
Sandable filler?
What do the experts use as a filler to make a wing repair looking like new?
I am not so happy with the bondo/easy sand auto body filler I tried. It is also pretty heavy.
One of these any good?
http://www.aircraftspruce.com/catalo...s/superfil.php
http://www.aircraftspruce.com/catalo...ltwtfiller.php
http://www.aircraftspruce.com/catalo...finisputty.php
fcbflyer is offline Find More Posts by fcbflyer
Old Feb 19, 2011, 01:37 PM
yyz is offline
yyz
Find More Posts by yyz
yyz
yyz's Avatar
USA, CA, Paso Robles
Joined Dec 2004
West System 410 is a good product and much lighter than Bondo when used with the West epoxy and hardener. It's light brown in color when dry.
CST carries it.
Happy sanding,
yyz is offline Find More Posts by yyz
Old Feb 19, 2011, 02:20 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
+1 for the 410 with West Systems. "Dryer" mix is more sandable, wetter less, but stronger and heavier. Bondo is for the PSS cavemen, where heavier at all ends is better (they think).
If you REALLY want it light and strong, under-fill a fillet a little, and lay on some light glass. When it gets tacky, add the finish layer that you will sand.
R,
Target
target is offline Find More Posts by target
Old Feb 19, 2011, 03:07 PM
G Norsworthy is online now
Find More Posts by G Norsworthy
Master of the Wind
G Norsworthy's Avatar
United States, AZ, Tempe
Joined Sep 2008
I really like the Superfil and use it almost exclusively. I have since put away the epoxy and microballoons unless I need a really wet mix or want to put in fibers. Good for both dry and wet sand, really good with wet sand. I'm on my 5th project with it. Nice working time, a little slow, but I put some in the hot box last night and it was easily ready to sand in the morning.
Most of the filling I do with epoxy is for internal work and uses chopped fiber in place of microballoons.
I also keep some lightweight spackle on hand for the last foam fill before bagging.
G Norsworthy is online now Find More Posts by G Norsworthy
Old Feb 19, 2011, 03:19 PM
s2000 is online now
Find More Posts by s2000
so. cal.
Joined Jan 2006
Split Second filler is the best I have ever used. It is liquid microballoons suspended in the can, SUPER light weight, fast, and sands so fine you can polish it. I get it at my local automotive paint store in Long Beach. Once you use it there is no going back. I can post a picture of the can if needed.
s2000 is online now Find More Posts by s2000
Old Feb 19, 2011, 10:09 PM
flytrip is online now
Find More Posts by flytrip
I land when i CFIT!
flytrip's Avatar
USA, UT, Sandy
Joined May 2007
flytrip is online now Find More Posts by flytrip
Old Feb 19, 2011, 10:38 PM
yyz is offline
yyz
yyz
yyz's Avatar
Joined Dec 2004
Dennis, please post a picture of the can.
Old Feb 19, 2011, 11:10 PM
fcbflyer is offline
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
Split Second
Old Feb 19, 2011, 11:44 PM
THE EYE is online now
Find More Posts by THE EYE
THE EYE's Avatar
United States, CA, Fresno
Joined Aug 2006
split second that stuff is the best! thanks to LJ introducing me to the product. works wonders and is smooooth!
MB3
THE EYE is online now Find More Posts by THE EYE
Old Feb 20, 2011, 12:36 AM
Master of the Wind
Joined Sep 2008
I take it split second is polyester based, meaning no foam cores?
Old Feb 20, 2011, 12:47 AM
fcbflyer is offline
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
On foam cores I would only use lightweight spacle. Trying to sand anything harder then that will Be nearly impossible.
Old Feb 20, 2011, 02:33 AM
ChrisJ800 is offline
Find More Posts by ChrisJ800
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
+1 for Spackle, its so light and easy to sand.
ChrisJ800 is offline Find More Posts by ChrisJ800
Old Feb 20, 2011, 08:16 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I'll have to try the Superfil and Split Second stuff.
Target
Old Feb 20, 2011, 01:44 PM
s2000 is online now
so. cal.
Joined Jan 2006
Here is a picture, G.E. Paint (Gary Elliot runs the place) is I think on Anaheim street in Long Beach just east of Junipero, it is around $25 a can, the can feels almost empty since the stuff is so lightweight, it is just a lttle thicker than whipped cream.
Old Feb 21, 2011, 06:02 PM
fcbflyer is offline
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
Thank you guys to chime in here. I did the 410 epoxy mix before and didn't like it too much.
I ordered a can of split second and will report on the outcome.
Discussion Sandable Glue? ForeverFlying The Builders Workshop 11 Jan 28, 2011 02:30 PM
Discussion FFF sandable filler Crash Trash Foamies (Scratchbuilt) 6 Sep 05, 2009 10:00 AM
best sandable primer? Bob K Foamies (Kits) 1 Oct 10, 2002 11:50 AM
Foam Safe light Sandable Primer S Anastasio Foamies (Kits) 1 Feb 02, 2002 08:40 PM
