Old May 20, 2013, 03:32 PM
cptsnoopy is offline
Find More Posts by cptsnoopy
Where is the lift?
cptsnoopy's Avatar
USA, AZ, Phoenix
Joined Nov 2005
Originally Posted by Rollo340 View Post
Hey Charlie...
what do you mean? Aren't you coming to Denmark?
Cheers, RJ
Unfortunately it does not look possible. I was unable to secure vacation to cover the dates of the contest and I am unable to hold weekends on reserve anymore. If things change I'll be there but the odds are against it at the moment.
Charlie
cptsnoopy is offline Find More Posts by cptsnoopy
Old May 20, 2013, 06:25 PM
wgeffon is online now
Find More Posts by wgeffon
wgeffon's Avatar
United States, IL, Bloomington
Joined Feb 2002
I'm interested to hear where everyone is flying their CX2's in respect to CG.
wgeffon is online now Find More Posts by wgeffon
Old May 20, 2013, 09:37 PM
rcgeorge is offline
Find More Posts by rcgeorge
usaf3kteam
rcgeorge's Avatar
United States, AZ, Arizona City
Joined Sep 2005
Depending on conditions 82 calm conditions no lift no wind no sink. 80 to 78 as conditions get better. 78 seems to be where lots pilots like it. Turbulent winds 15 and up 76 for me no ballast. Hope that helps.
rcgeorge is offline Find More Posts by rcgeorge
Old May 20, 2013, 09:39 PM
rcgeorge is offline
usaf3kteam
rcgeorge's Avatar
Joined Sep 2005
I also go full rate in turbulent conditions
Old May 20, 2013, 09:40 PM
wgeffon's Avatar
Joined Feb 2002
Yes George that helps. I'm at 80 and then add some nose weight for turbulence and wind.
Just curious as to what everyone is using.
Old May 20, 2013, 09:42 PM
rcgeorge is offline
usaf3kteam
rcgeorge's Avatar
Joined Sep 2005
Cool
Old May 21, 2013, 04:20 AM
Rollo340 is offline
Find More Posts by Rollo340
Rollo340's Avatar
Joined Jul 2011
Charlie
Oh no...I'm sorry to hear that, Charlie ...
But I'm staying positive and have a slight hope seeing you in July .
Good luck, RJ
Rollo340 is offline Find More Posts by Rollo340
Old May 21, 2013, 12:56 PM
Where is the lift?
cptsnoopy's Avatar
USA, AZ, Phoenix
Joined Nov 2005
Good luck, RJ
Thank you Roland
Charlie
Old May 22, 2013, 11:23 AM
rcgeorge is offline
usaf3kteam
rcgeorge's Avatar
Joined Sep 2005
Good luck, RJ
Me too cheers
Old May 23, 2013, 03:51 PM
rcgeorge is offline
usaf3kteam
rcgeorge's Avatar
Joined Sep 2005
Cheers
BRIGHT SUNSHINY DAY (3 min 6 sec)
Old May 23, 2013, 08:33 PM
gopherhunter is offline
Find More Posts by gopherhunter
excelling at mediocrity
gopherhunter's Avatar
Franktown, CO. USA
Joined Mar 2009
Thanks George. Even though its 7:30 pm, I needed that.
John
gopherhunter is offline Find More Posts by gopherhunter
Old May 30, 2013, 05:15 PM
Tmfury is offline
Find More Posts by Tmfury
up from the skies
Tmfury's Avatar
United States, CO, Fort Garland
Joined Jul 2011
New day glo colors are amazing -super bright ill try to post photos
Tmfury is offline Find More Posts by Tmfury
Old May 31, 2013, 10:16 AM
KINETIC is offline
Find More Posts by KINETIC
Zeus
Wild East
Joined May 2008
NEW! stainless steel braid for rudder and elevator
In the course of constant improvements, I can offer as an upgrade for new models or as an accessory....
Stainless steel braid string
1) 0.39 mm dia. 7 wires twisted, weight 0.77g /meter tensile strength 15,5 Kg
or
2) 0.40mm dia. 19 wires twisted, weight 0.8g /meter tensile strength 15,1 Kg
Wire no. 1 has slightly more stiffness (less longitudinal flex) but is more prone to breakage in sharp repeated bends
Wire no.2 is more pliant and less prone to breakage in sharp repeated bends
However, the longitudinal flex is many times less in compare to Kevlar string, similar to a solid push rod, at fraction of its weight.
Every existing plane can be converted easily to the new Steel braid cable by simply exchanging the lower Kevlar string.
The stiffness of the rudder and perhaps (if really necessary) elevator stiffness will make a big difference, as well as the improved center precision.
The best of it, you don't have to install VERY heavy steel or carbon push rods / guide tubes and glue to fix them.
Roland
KINETIC is offline Find More Posts by KINETIC
Old May 31, 2013, 10:20 AM
Fly2High is offline
Find More Posts by Fly2High
Chuck 'Em and Chase 'Em
Fly2High's Avatar
United States, NY, Plainview
Joined Aug 2005
Roland,
So if I understand, these braided wires will be unsupported?
No teflon tubing or any form of guidtubing?
How much to purchase as an accessory? Might want to use in my CX2.
Any only one wire is used to replace both kevlar strings?
thanks
Frank
Fly2High is offline Find More Posts by Fly2High
Old May 31, 2013, 10:36 AM
KINETIC is offline
Zeus
Wild East
Joined May 2008
Originally Posted by Fly2High View Post
Roland,
thanks
Frank
Yes, Frank, you understood well....
The braided wires are used the same way as the Kevlar strings. No guide, support or glue in any way.....
For each linkage you only have to replace 1 wire, which is connected to the LOWER hole (botom side) in the bellcrank. The upper Kevlar / Dynema string can remain.
10m of the 1x7 0.39mm dia. braid is 8.50 US$
10m of the 1x19 0.4mm dia.brais is 12.50 US$
Cheers, Roland
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 2 Mar 09, 2011 09:23 AM
For Sale Kyosho EP Concept 30 X 2 dhsmith1 Aircraft - Electric - Helis (FS/W) 0 Feb 14, 2011 05:34 PM
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 0 Jan 11, 2011 01:53 PM
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 0 Dec 26, 2010 02:57 PM
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 0 Nov 16, 2010 10:07 PM
