Old Feb 12, 2013, 10:25 AM
Fly2High is offline
Find More Posts by Fly2High
Chuck 'Em and Chase 'Em
Fly2High's Avatar
United States, NY, Plainview
Joined Aug 2005
Originally Posted by jfinch View Post
Yes, what George said. The rod for the bell cranks looks like a section of 2-56 all-thread. It'll "screw" itself out if you can either get ahold of it from the outside or inside between the cranks as George mentions.
I was thinking of putting a slot on the end so that I can put a screwdriver on it. Glad to know it is 'screwed' in place. I'll try to the hemostats first and once it's out, I can notch the end to make it easier in the future.
Too bad Roland doesn't notch the end to accept a screwdriver.
thanks.
Fly2High is offline Find More Posts by Fly2High
Old Feb 12, 2013, 02:58 PM
rrunyan is offline
Find More Posts by rrunyan
SoCal
Joined May 2006
CJ is back!!!
It is great to see CJ posting on the board again. It's been too long.
CJ... Any plans for building a new DLG??? Predator 3 maybe.
Great to hear you are doing well.
Ron R.
rrunyan is offline Find More Posts by rrunyan
Old Feb 12, 2013, 06:39 PM
gopherhunter is offline
Find More Posts by gopherhunter
excelling at mediocrity
gopherhunter's Avatar
Franktown, CO. USA
Joined Mar 2009
Originally Posted by Fly2High View Post
I was thinking of putting a slot on the end...notch the end to make it easier in the future...
I "dremeled" a slot, then used a screw driver to back mine out. There's enough of the allthread sticking out to cut a shallow slot pretty easily.
John
gopherhunter is offline Find More Posts by gopherhunter
Old Feb 15, 2013, 11:05 PM
KINETIC is offline
Find More Posts by KINETIC
Zeus
Wild East
Joined May 2008
Many thanks
Originally Posted by C. J. Hung View Post
Roland flying his CX3.
Hi J.C., MANY THANKS for your nice pictures and many thanks for your visit!
Cheers, Roland
KINETIC is offline Find More Posts by KINETIC
Old Feb 15, 2013, 11:17 PM
KINETIC is offline
Zeus
Wild East
Joined May 2008
thanks.
Hi Frank,
it's probably not a good idea to re-use the skrew while to short to make a proper adjustment of the bellcranks positions. Better use a new screw about 20mm in lengt and trim it off after everything is correctly in place and the srew is tightly secured at booth sides.
Since I considered the mechanics never to be replaced or frequently exchanged, a slot or even the use of a set screw seems not to be necessary. The screw I use is a 20 mm long stainless M2 (2mm) screw, easy to handle while the screw head is still on.
Cheers, Roland
Old Feb 16, 2013, 12:49 AM
danfitz is offline
Find More Posts by danfitz
danfitz's Avatar
United States, CA, Vista
I seem to remember that Roland told me the screw was locked in place by a tiny bit of CA glue. He suggested softening the CA bond by heating the end of the screw with the tip of a soldering iron right before backing the screw out.
danfitz is offline Find More Posts by danfitz
Old Feb 16, 2013, 01:00 AM
KINETIC is offline
Zeus
Wild East
Joined May 2008
Alternative pull methods
Since I really don't like the use of pushrods, while increasing dramatically the mass moment of inertia (MOI) behind Cm, I was evaluating some different methods which might bring similar advantages without reasonably increasing the "MOI" and the best of it, easy to modify, without complicated "surgeries"....
Changing the stock pull-pull Kevlar strings for the elevator doesn't seem to be necessary at all. Not any improvement can be detected if changed to a far more heavy (MOI !) heavy pushrod.
As my favorite, a dramatic improvement can be found by changing (replacing) only one string for the rudder, the one which is connected to the LOWER bell crank end (pull side), with a none stretchable (pre-stretched) steel wire of about 0.2 - 0,4mm in diameter.
For the friends of a pull-spring system, The change can be made easyly by disconnecting the string which is not loaded during the throw and connecting the free end to a pull spring, which is connected to a conveniant spot at the servo well. Voila....You have a pull-spring sytem, without having springs installed to the tail feathers....
Happy testing....
Roland
Old Feb 19, 2013, 05:57 PM
Franktown, CO. USA
Joined Mar 2009
Where can I get 0.2 - 0.4 mm steel wire?
Old Feb 19, 2013, 06:17 PM
carlsoti is offline
Find More Posts by carlsoti
hass-alfed and bass-ackwards
carlsoti's Avatar
United States, AZ, Chandler
Joined Jun 2008
guitar strings. .009-.015 inches.
carlsoti is offline Find More Posts by carlsoti
Old Feb 19, 2013, 06:51 PM
Fly2High is offline
Fly2High's Avatar
Joined Aug 2005
Malin hardened stainless steel fishing leader
Franktown, CO. USA
Joined Mar 2009
Duuuuuuuuuuuuuuuh!
LOL Thanks Tim (laughing at myself) as a guitar player myself... I should have made the metric conversion before asking the question.
I imagined my Super Slinky high E was way too fat! So next time I change strings on the Strat or Tele I'll have a nice pre-stretched 0.23 mm (.009 inch) wire.
Thanks for the "favorite" tip, Roland.
Old Feb 19, 2013, 07:19 PM
Tmfury is offline
Find More Posts by Tmfury
up from the skies
Tmfury's Avatar
United States, CO, Fort Garland
Joined Jul 2011
Noooooo!!!!!
When a guitar string comes off a guitar throw in trash, cause its trash!!! It's been through repeted bends at the nut and bridge and at every fret has been weakend !
You can safely stretch a brand new string w/o causing fatigue and wear to it - one that's been played a while is junk
Even players who don't subject their strings to the pure torture I put mine thru- like bending c# (21st fret) to f# ( full 2&1/2 steps)
Don't risk a concept with a fatigued , compromised high e or b string
Shoot a new one only cost buck 50
I put steel pushrods thanks Gman
Tmfury is offline Find More Posts by Tmfury
Old Feb 20, 2013, 07:56 AM
Fly2High is offline
Fly2High's Avatar
Joined Aug 2005
If you are concerned with the cost, I think the Malin hardened line is cheaper than guitar strings.
Please don't scare us all by using used materials in sucha beautiful plane!!!
Take care of that baby and only use top quality parts!!!
Old Feb 20, 2013, 09:38 AM
Franktown, CO. USA
Joined Mar 2009
I'm not scared.
Old Feb 20, 2013, 06:24 PM
KINETIC is offline
Zeus
Wild East
Joined May 2008
Originally Posted by gopherhunter View Post
I'm not scared.
Actually the idea was not the use of a single core steel wire rather than a steel braid or steel strand which is composed out of multiple wires, which gives more safety from breakage and is much more flexible as well.
Such steel braids are used for jewelry such as expensive necklaces, made in Germany and rather inexpensive in compare to a guitar string. Here the link:
http://www.gold-mueller.de/Kettenver...2d81tal7brjkq0
In case you still want to use a single core wire, there is very cheap "Spring Wire" available, similar to piano wire. This types of wire are high strength and available from spring manufacturers. The down side, such wires can't be bent very often, the might break.... The steel braid is by fare on the safe side but would need a pre-stretch.
Roland
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 2 Mar 09, 2011 09:23 AM
For Sale Kyosho EP Concept 30 X 2 dhsmith1 Aircraft - Electric - Helis (FS/W) 0 Feb 14, 2011 05:34 PM
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 0 Jan 11, 2011 01:53 PM
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 0 Dec 26, 2010 02:57 PM
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 0 Nov 16, 2010 10:07 PM
