Old Nov 03, 2012, 12:20 PM
KINETIC is offline
Find More Posts by KINETIC
Zeus
Wild East
Joined May 2008
Originally Posted by Fly2High View Post
Now I know what Roland and Mong feel like. Hurricane Sandy ripped up Long Island pretty bad. within 1 block of my home, 9 trees are down.
One of them in my back yard. 70ft Oak tree took out the pole, transformer, power lines, and all telecommunication lines (Verizon, cablevision and regular phone).
I was about to go out to remove a propane tank when I doubled back in to get a wrench. That is when it fell. Just missing the deck I would have been on. Wife and daughter saw it fall and screamed, 'Frank, Oh my God It is Falling!!!' I ran up stairs just as the power went out.
Had to call the fire dept 5 times to report a fire in aa neighbor's yard from the downed lines. The tree was glowing red from the line being draged and stripped through it and was risking of a fire. Luckily it never caught fire but the bushed below did several times.
Luckily everyone is safe and no damage to the home. Just need to wait for power to be restored.
I know I said I wanted the full Roland experience when I purchased a CX2 but Now I can say I HAVE THE FULL EXPERIENCE!!!
Frank
Frank, by 100% we can understand your feelings. Mong and me know exactly what you are taking about. The same way we are releaved that you and your Family made it throug unharmed. Our thoughts where with you all that night long, even though I coldn't reply more early for computer troubles.....
Might we never ever have a similar experience again......
Mong & Roland
KINETIC is offline Find More Posts by KINETIC
Old Nov 04, 2012, 07:01 AM
Fly2High is offline
Find More Posts by Fly2High
Chuck 'Em and Chase 'Em
Fly2High's Avatar
United States, NY, Plainview
Joined Aug 2005
I couldn't agree with you more.
Thanks for the support and understanding. Makes me proud to be apart of this R/C community with all the support being shown. Really a great bunch.
I was lucky to find a gas station local to my home where I only needed to wait for an hour to get gas. We were limited to $50 worth. There are photos of several tankers waiting to get into port. Should be better 4-7 days from now before the gas lines ease and start to go back to normal. Most gas lines are 2 -3 hours long with no promise of getting gas.
I am lucky to live more centrally. The shorelines are devastated. There are photos on TV showing areas where fire has ravaged entire neighborhoods (100+ homes) and the storm surge wiped out shoreline communities. Other than no power, I have nothing like that in my area. Sure, you cannot go 400 ft without seeing a tree down and many of the ones across roads have been removed but at least our home is intact and we will have somewhere to spend the coming holidays.
So far food is still available and stores and restaurants are open so you have options. Lunch is interesting since EVERYONE is going out for lunch and it takes most of your lunch hour just to get food but even that is subsiding rather quickly in my area.
Just hoping they return power before the freezing temps come and they are promising a NorEaster storm (40-50 mph winds and rain - some snow north and west) on Wed or Thurs.
Definitely something to be grateful for......
Thank you all for your well wishes and concern. I am safe and warm at my dad's since he has power and heat.
Sincerely,
Frank Nisita
Fly2High is offline Find More Posts by Fly2High
Old Nov 04, 2012, 07:42 PM
Dbox is offline
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
We are having weather blast here in Oregon this fall. (Sorry East coast,I feel for You)
It was 70F and 0 wind all day.
I have tested C2 with both my antennas INSIDE of the canopy.Flew her as far as I could see.
Worked like a charm,no signal losses.
Radio 2.4 G Futaba 10C full range receiver R617 FS.
Yuri
Dbox is offline Find More Posts by Dbox
Old Nov 04, 2012, 09:46 PM
cptsnoopy is offline
Find More Posts by cptsnoopy
Where is the lift?
cptsnoopy's Avatar
USA, AZ, Phoenix
Joined Nov 2005
Just be aware that you may find issues with that antenna placement when flying with many others in a big contest. Of course your mileage may vary.
Charlie
cptsnoopy is offline Find More Posts by cptsnoopy
Old Nov 08, 2012, 03:14 PM
TomK is offline
Find More Posts by TomK
Tom Knudtson
United States, CA, Redlands
Joined Aug 2004
Bell crank and control rod weight?
I would like to know how much weight I could save by removing the bell crank and control rods from a Concept.
The MoBros remove the bell crank and control rods. Have you ever weighed them?
I'm thinking of spring-pull controls for the Concept. I know the recommendation is 0.037" steel rods, but I'm thinking that one of the few advantages of a weak launch is that I can use spring-pull. Down at the low altitudes where I fly, the thermals are weaker and a lighter plan helps.
If I could shave 3 grams from the tall I might be able to drop 9 grams in the pod for a total of 12 grams =0.4 oz.
Tom
TomK is offline Find More Posts by TomK
Old Nov 08, 2012, 04:47 PM
Where is the lift?
cptsnoopy's Avatar
USA, AZ, Phoenix
Joined Nov 2005
I'll root around and see if I can find the bellcrank system I pulled from one of my Concepts Tom.
It may be tomorrow before I get back with the info though...
Charlie
Old Nov 08, 2012, 04:54 PM
jfinch is offline
Find More Posts by jfinch
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
I'll check tonight too, Tom. But I can say that removing the bell cranks and running .020 wire in teflon tubing results in zero weight penalty.
jfinch is offline Find More Posts by jfinch
Old Nov 08, 2012, 05:38 PM
FLY F3B is offline
Find More Posts by FLY F3B
or F, J, K, or even TD
FLY F3B's Avatar
Joined Jun 2007
Wow, really Finchy?
The weight of two 0.020 wire rods and two teflon tubes is the same weight as 4 lengths of string, and the bellcrank system? I would check you scale man
But, if there is a little extra weight being carried around, solid pushrods do give a certain sense of security even though I have never strayed from Rolands pull/pull system.
Curious on the weight differences though.
M
FLY F3B is offline Find More Posts by FLY F3B
Old Nov 08, 2012, 06:53 PM
jfinch is offline
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
I hate it when I lie...
What I meant to say was that the change out from bellcranks to thin pushrods did not result in any nose weight having to be added.
Bellcranks/pushrods/kevlar string weight about 1.4 g
.020 pushrods and teflon tubing weigh about 4.4 g.
so the weight does increase by about 3 g. That's about 0.1 oz and I must not have noticed the difference on the scale i use to weigh my planes. But that weight is more evenly distributed along the boom and not all concentrated at the tail end.
Old Nov 08, 2012, 07:45 PM
KINETIC is offline
Zeus
Wild East
Joined May 2008
However, about 90% of the weight would distributed behind CG, + all the weight of the glue to fix the tubes inside the boom.....
roughly calculated. the effective weight increase behind CG would be ~3.8g + an extra nose compensation of ~2,1g resulting in total weight increase of ~ 5.9g.
In case of Tom's mentioned Spring system, about 0.6g spring weight would be located at the rear end behind CG which would almost equal the weight for the Bellcranks and at least one short wire rod. In total, an effective weight reduction by using the spring system would be neclectable but bringing back all the disadvantages of the spring system.
Roland
Old Nov 08, 2012, 10:12 PM
FLY F3B is offline
FLY F3B's Avatar
Joined Jun 2007
No worries Finchy. If it had worked out that you confirmed that the rod system weighed less than the pull/pull system, I was going to ask to borrow your scale. Does it go up to 225....lbs?
M
Old Nov 08, 2012, 10:32 PM
TomK is offline
Tom Knudtson
Joined Aug 2004
Wow! 1.4 grams for the bell cranks and push rods is half of what I was guessing.
One of the reasons I started thinking along this "light weight" approach is that I weighed a Concept fuse + boom+ vertical fin and it was 35 grams. That's the same weight of an early Stobel fuse I have, but without the mounted vertical fin. (I think that Stobel fuses have gotten heavier with time, probably to make them stronger for the high launchers.)
And the Concept wing is also pretty light; 139 grams with RDS (same as a Stobel).
So I was thinking I might be able to get the Concept AUW down to 8.6-8.7 ounces like some of the early Stobels.
But I think that the early Stobels had smaller and therefore lighter horizontal and vertical stabilizers and that is probably a lot of the difference.
Old Nov 11, 2012, 10:16 AM
dbone is offline
Find More Posts by dbone
Team ATX Pilot
dbone's Avatar
Phx. Az.
Joined Nov 2004
Just for fun! setting 1080p...
Concept (0 min 27 sec)
dbone is offline Find More Posts by dbone
Old Nov 11, 2012, 01:22 PM
Where is the lift?
cptsnoopy's Avatar
USA, AZ, Phoenix
Joined Nov 2005
Cool Donnie, Thank You for posting!
Charlie
Old Nov 11, 2012, 04:38 PM
Tmfury is offline
Find More Posts by Tmfury
up from the skies
Tmfury's Avatar
United States, CO, Fort Garland
Joined Jul 2011
Just finished installing push rods on #2-cx2. Thank you G-man and John Lovins for the materials.install went good
Only 30mph winds are stopping me from going out to fly
Sure feels heavier now, took more weight in nose to balance than with it needed with pull pull lines, but I was expecting that and it's all good
Laters homies
Tom
Tmfury is offline Find More Posts by Tmfury
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 2 Mar 09, 2011 09:23 AM
For Sale Kyosho EP Concept 30 X 2 dhsmith1 Aircraft - Electric - Helis (FS/W) 0 Feb 14, 2011 05:34 PM
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 0 Jan 11, 2011 01:53 PM
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 0 Dec 26, 2010 02:57 PM
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 0 Nov 16, 2010 10:07 PM
