Old Feb 01, 2012, 03:46 PM
FLY F3B is offline
Find More Posts by FLY F3B
or F, J, K, or even TD
FLY F3B's Avatar
Joined Jun 2007
Oh, Thanks Dan, my next CX2 will be the RHC31HF layup as well. Smooooooooth.
FLY F3B is offline Find More Posts by FLY F3B
Old Feb 01, 2012, 07:05 PM
rcgeorge is offline
Find More Posts by rcgeorge
usaf3kteam
rcgeorge's Avatar
United States, AZ, Arizona City
Joined Sep 2005
Originally Posted by 808 View Post
No - graduating from Blaster and Fireworks FW5.
I think the benefits of heavier vs lighter wing loading are well discussed and the compromise of penetrtaion vs climb rate understood.
My question is simply around the practical experience by folks who have been flying the CX2 for a while now.
Go with the light as you can always add weight and I have not broken one yet they rock
rcgeorge is offline Find More Posts by rcgeorge
Old Feb 02, 2012, 12:34 PM
rcgeorge is offline
usaf3kteam
rcgeorge's Avatar
Joined Sep 2005
Man it is windy will be disc golf no hand launch for me today
Old Feb 08, 2012, 06:00 PM
apex is offline
Find More Posts by apex
Just a plane Junkie
Portland, Oregon
Joined May 2002
Tip strike!
This will be my first molded repair job, but I'm about halfway done after a days work.
I've opened up the bottom of the wing, and rebuilt both spars, which are now drying.
So far the hardest part for me has been getting the outer wing skins re-attched to the rohacell. The skins aren't porous enough for my thin CA to soak through.
More pics as I make progress.
apex is offline Find More Posts by apex
Old Feb 08, 2012, 09:04 PM
gopherhunter is offline
Find More Posts by gopherhunter
excelling at mediocrity
gopherhunter's Avatar
Franktown, CO. USA
Joined Mar 2009
Owwwwwch! That hurts... Good Luck with it. Looks good so far.
Do we need to work on our launch technique, or was it real windy that day?
gopherhunter is offline Find More Posts by gopherhunter
Old Feb 08, 2012, 09:38 PM
apex is offline
Just a plane Junkie
Portland, Oregon
Joined May 2002
Both. New launch technique, and with high winds which pushed the plane up higher on the frontside (windward) of the launch and hence lower on the backside. It was one of those 'oh just one more flight' moments... I knew I should have quit after the first roller coaster ride.
Old Feb 08, 2012, 10:09 PM
samc99us is offline
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
Ouch! I nearly had that happen on the Akcent-2, but I don't practice new launch techniques when the breeze is up.
Repair is looking good and I appreciate the close ups of a molded wing structure!
samc99us is offline Find More Posts by samc99us
Old Feb 08, 2012, 10:52 PM
Phil Barnes is offline
Find More Posts by Phil Barnes
Germantown, Maryland
Joined Apr 2004
It looks as if the Rohacell in that wing was died yellow. It looks like the color goes all the way through the Rohacell, and the color continues even under the carbon. That is something that you might do if you were using perhaps a water based dye to color the Rohacell. Rohacell just loves to soak up water. If you were using paint, the paint would be just be on the surface and there would be no reason to paint where the carbon will cover it. I can envision just dropping a stack of Rohacell sheets in a big tub of water with some dye and then just hanging the sheets to dry. I bet you wouldn't even be able to measure any weight gain.
Those pictures also make me wonder why they put the disser threads on the inside skin rather than the outside skin. The Stobel does it that way also. It seems like the disser threads would be more effective closer to the outside.
Phil Barnes is offline Find More Posts by Phil Barnes
Old Feb 08, 2012, 10:56 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Just a thought, but if they were on the outside then the other fibres in the wing and the foam underneath them would have to bend to go under them.
If they are on the inside then they can just sort of lay on top of the inner skin.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Feb 08, 2012, 11:04 PM
FLY F3B is offline
FLY F3B's Avatar
Joined Jun 2007
Nope, the foam is not died. The skins are made with tinted epoxy. You can tell by the bit of foam left on the spar in one of the shots. Sorry to see that happen, but good on ya for undertaking the repair. It will work well.
Cheers.
Old Feb 09, 2012, 08:01 AM
rcgeorge is offline
usaf3kteam
rcgeorge's Avatar
Joined Sep 2005
What happened?
Old Feb 09, 2012, 08:55 AM
samc99us is offline
Aurora Builder
Joined Nov 2003
I have been putting the disser right on the outside lately. However, I think the reason for putting the disser skin on the inside is entirely related to QC. When you place the disser cloth on the outer skin, it is easy to distort those fibers during the layup. Also, it is possible that the fibers start peeling at the LE of the wing. Placing the disser inside eliminates this problem as the cloth would be 3M'd to the foam at that point. The <2mm loss in separation distance between the lower and upper skins is likely a negligible loss in overall torsional stiffness.
Doesn't the Stobel come in a double disser variety with disser on the inner and outer skins?
Old Feb 09, 2012, 09:40 AM
rcgeorge is offline
usaf3kteam
rcgeorge's Avatar
Joined Sep 2005
Yes the Stobel is the same
Old Feb 09, 2012, 09:45 AM
rcgeorge is offline
usaf3kteam
rcgeorge's Avatar
Joined Sep 2005
Well went flying at 7:45 temp 40d no wind throwing 160' to 165' times were 2.20 to 2.30 man my fingers are numb. Did not throw hard will go and throw for launch latter when little warmer. This plane is 10 oz and CG is at 82mm with how high in it. Will fly light plane maybe tomorrow early if get a chance. Cheers happy flying
Old Feb 09, 2012, 10:01 AM
JOLOVINS is offline
Find More Posts by JOLOVINS
Joined Sep 2004
40s, thats a heat wave here...
JOLOVINS is offline Find More Posts by JOLOVINS
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 2 Mar 09, 2011 09:23 AM
For Sale Kyosho EP Concept 30 X 2 dhsmith1 Aircraft - Electric - Helis (FS/W) 0 Feb 14, 2011 05:34 PM
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 0 Jan 11, 2011 01:53 PM
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 0 Dec 26, 2010 02:57 PM
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 0 Nov 16, 2010 10:07 PM
