Charlie
The way I installed them was to shrink some small heat shrink tubing to create antenna guides. The tubing I have shrinks to the exact correct size for 2.4 antenna coax, and it bonds well with glue. I then drilled holes in the fuse at an angle, then CA'd VERY short sections of the tubing into the holes. This prevents the antenna wire from being directly against the sharp carbon edge of the hole. I also cut the tubing in such a way to protect the wires from impacts from the front and allowing the wires to bend rearward (see pics). I didn't worry about gluing the antennae in place, friction is enough. I'm a Futaba guy, and am using the R6208SB 8ch receiver - it's probably overkill, and i'm sure I could have gotten by with the same R6106HFC 6ch Rx I use in all my other DLGs. I'm not saying this is the the "best" way to go, but it's what I settled on. Many folk have had good luck with the MS method, but I also know several who have had issues with it. No matter what you decide: RANGE CHECK. my new antenna locations give me a much stronger range check than I got with the MS install. Have fun! -m@ |
Thanks Matt ,I appreciate the instructions and photos. Your install looks slick and i would feel 100% confident with that set up.Roland says he shipping mine in about 2weeks.btw I hit the 200' mark today-man these dlg's are so much fun.when I started back in July I flew in bsonm,I could only throw about 60' all the help from people here, and watchin launch videos has helped me out so much .thanks again
Tom |
It flies again!
Last year at the JEM, I broke one of the first CX2's to fly here in the states. The fuselage failed on launch, and forensic analysis by Roland found that there was some bad material in that area. Roland tested, and fixed the problem, and CX2's have been getting brutally hurled into the air ever since without incident. The crash left my fuse irrepairable, and my wing buckled right at the aileron torque tube location on the right (non-launch) side. I stuck this wing in the rack for a time when I could sit down and do surgery. That time came Saturday night. I sat down, put in a fresh #11 blade and surgically removed the skin in the compromised area. I quickly discovered the issue, and planned my attack. The balsa spar was buckled in compression right at the torque tube. The wing had hit the ground somewhat inverted, so the compression failure was on the bottom side of the wing. My fix was to wrap a piece of 1/16 inch balsa with some carbon uni I had laying around, and while protecting the torque rod from being permanently bonded to a non moving part of the wing, bond that piece such that it adhered to the spar, and the skin. After shaping the piece and dry fitting in several times, I placed a shaped piece of thin plastic on the torque rod as it ran through the spar, and set the piece into its final position. I soaked the piece with thin CA making sure to let it wick into the fibers, and along the spar, then wicked in a little more along the exposed skin sandwich adjacent to the reinforcement. I did some manual flexing of the wing, and noticed no buckling. So, I sealed everything back up with CA, and made sure to relaminate some other areas that had delammed in the wreck by wicking thin CA and rubbing it out while it cured. Test flights on Sunday afternoon confirmed that I had succesfully breathed new life into a shop relick to be. I couldn't be happier to have this wing flying again, especially with the 2012 JEM right around the corner. Cheers all, and Happy Holidays. Mike |
Yep, so excited to see there will be another CX2 pilot there to woop me!
Cant wait.......... |
Latest blog entry: Swith in battery chemistry for all my...
New Mexico
Joined Mar 2004
New CX2 Takes to the Shy
I flew my new CX2 today for the first time. It was pretty windy so I didn't get the real fine tuning done. It seemed like I could launch higher but George, Charlie and the other big guns are still safe
. It has the Rohacell 51 layup (yellow) and the upgraded elevator servo. It came out 9.5 oz with an AR6255 DSMX receiver. Very nice work Roland. Thanks.Bruce T. |
Christmas was great well the food and company that is. Went throwing the Concept-X2 first time sense blue skies Az when injured shoulder. With how high was getting 175' to 180' not hard contest throws yet but great to be flying again. Air was soft flight times average 2 minutes 30 seconds. I sure miss flying but will be back to work and flying this year will not be much. Well Happy New Year to ALL Cheers and Beers.
| Thread Tools | |
| For Sale XPS Xtreme 2.4 Futaba module and RX $100 | John Kim | Aircraft - General - Radio Equipment (FS/W) | 2 | Mar 09, 2011 09:23 AM |
| For Sale Kyosho EP Concept 30 X 2 | dhsmith1 | Aircraft - Electric - Helis (FS/W) | 0 | Feb 14, 2011 05:34 PM |
| For Sale XPS Xtreme 2.4 Futaba module and RX $100 | John Kim | Aircraft - General - Radio Equipment (FS/W) | 0 | Jan 11, 2011 01:53 PM |
| For Sale XPS Xtreme 2.4 Futaba module and RX $100 | John Kim | Aircraft - General - Radio Equipment (FS/W) | 0 | Dec 26, 2010 02:57 PM |
| For Sale XPS Xtreme 2.4 Futaba module and RX $100 | John Kim | Aircraft - General - Radio Equipment (FS/W) | 0 | Nov 16, 2010 10:07 PM |
