Old Nov 09, 2011, 08:32 PM
rcgeorge is offline
Find More Posts by rcgeorge
usaf3kteam
rcgeorge's Avatar
United States, AZ, Arizona City
Joined Sep 2005
Man still can't believe this year with the Concepts what a dream come true thanks again Roland, Mong and Eric your the best. Cheers and Beers no fears.
rcgeorge is offline Find More Posts by rcgeorge
Old Nov 09, 2011, 08:57 PM
dbone is offline
Find More Posts by dbone
Team ATX Pilot
dbone's Avatar
Phx. Az.
Joined Nov 2004
The Concept has proven to be a great plane, and George handles this plane like nobody else can. You flew great last weekend, your the man.
Donnie
dbone is offline Find More Posts by dbone
Old Nov 09, 2011, 08:59 PM
carlsoti is offline
Find More Posts by carlsoti
hass-alfed and bass-ackwards
carlsoti's Avatar
United States, AZ, Chandler
Joined Jun 2008
Blue Skies Series Champion
USA F3K Tour Champion
Podium Finish at the First ever FAI F3K World Championship
That is one helluva year, George.
Congrats, buddy!
carlsoti is offline Find More Posts by carlsoti
Old Nov 10, 2011, 01:52 PM
shhhhh! is offline
Find More Posts by shhhhh!
Yes..ok..maybe..lol.....
Tucson Avra Valley, Arizona, United States
Joined Jul 2004
Master steak chef too!!!!!!!!!!!!
shhhhh! is offline Find More Posts by shhhhh!
Old Nov 10, 2011, 04:01 PM
rcgeorge is offline
usaf3kteam
rcgeorge's Avatar
Joined Sep 2005
Thanks Tim , Donnie and Dave your the best
Old Nov 13, 2011, 05:55 PM
MattN is offline
Find More Posts by MattN
a.k.a. Matt Nelson
MattN's Avatar
North Tustin, CA
Joined Oct 2008
Wing mounting getting loose
Still loving my Concepts - but I have noticed one undesirable thing happening: ya know that peg and hole at the rear of the wing/fuse that keeps the wing aligned when mounted? Well the hole on mine is wearing, and now looks more like an oval. There is definite play in the wing before I put the screws in (when new, everything fit so tight that I wondered if the screws were even necessary!)
Anybody else see this?
Roland - you might consider adding some sort of reinforcement or bushing at that spot.
MattN is offline Find More Posts by MattN
Old Nov 13, 2011, 06:07 PM
RCPC is offline
Find More Posts by RCPC
Throw it like you hate it
RCPC's Avatar
United States, CA, Castro Valley
Joined Apr 2007
Matt,
You are launching too hard Put a few layers of tape bridging the TE at the root and the boom. Then wrap once around boom over the end of the tape layers on the boom. This is what George does.
You can also wax up the locating peg and the wing and put some splooge in the hole and mount the wing. This will fill the gap.
Paul
RCPC is offline Find More Posts by RCPC
Old Nov 13, 2011, 06:13 PM
carlsoti is offline
carlsoti's Avatar
Joined Jun 2008
Matt, I've experienced the same thing on my older, previous generation concepts. I did just what George does, and now I'm back to flying a plane I though was destined for DLG Combat usage.
I wanted to try the splooge thing Paul is talking about, but I'd really rather see a write-up of how someone else does it, with pictures, before I try it.
Old Nov 13, 2011, 06:47 PM
MattN is offline
a.k.a. Matt Nelson
MattN's Avatar
North Tustin, CA
Joined Oct 2008
Originally Posted by RCPC View Post
Matt,
Paul
I doubt the shear strength of tape will be enough to do much. Tape at that location is a good idea aerodynamically, tho.
I've already concluded that splooge is the ultimate fix - I'll give it a go when I have some time. Even with wax, however, I am a little scared about permanently affixing the wing to the fuse...
I must admit that the primary motivation of my post was to alert Roland to an issue that he could probably effectively address in future designs...
Old Nov 13, 2011, 07:26 PM
G Norsworthy is offline
Find More Posts by G Norsworthy
Master of the Wind
G Norsworthy's Avatar
United States, AZ, Tempe
Joined Sep 2008
You can use plastic wrap if you are afraid of the wax.
G Norsworthy is offline Find More Posts by G Norsworthy
Old Nov 13, 2011, 08:27 PM
rcgeorge is offline
usaf3kteam
rcgeorge's Avatar
Joined Sep 2005
Matt the tape works and that is why I do it. Three 1/2" first 2/4" second and 1" last and then a wrap 3/4 way around the fuse and it works with our tape. Try it and let me know, I think you will be surprised. Well I hope.
Old Nov 13, 2011, 09:21 PM
carlsoti is offline
carlsoti's Avatar
Joined Jun 2008
I was in the same boat, Matt. George said tape it, and I chuckled inside. Now it's taped and I'm flying it.
Old Nov 13, 2011, 10:58 PM
FLY F3B is offline
Find More Posts by FLY F3B
or F, J, K, or even TD
FLY F3B's Avatar
Joined Jun 2007
Dudes, just tried a new fuse with the new H-stab from Roland. Flies great, looks super cool. I would be like the ultra uber calibrated launch height measuring device if I could tel you that it gave me any advantage over launch from the normal stabs...But I can say, it did not hurt my launch.....
Thanks Roland, the stabs are super cool.
FLY F3B is offline Find More Posts by FLY F3B
KINETIC is offline
Find More Posts by KINETIC
Zeus
Wild East
Joined May 2008
Actually this problem was discovered in early June during my practice flights for the WC in Sweden.
At this time we had very high temperatures and the fuse could heat-up well over 50C during extended exposure to the Sun on the ground.
Above 50C the Epoxy has reduced strength and can deform under high pressure as it happens during throw to the peg connection.
From ever since, I apply significantly more reinforcements to get more than double the wall thickness around the position hole area. From that time this problem seems to be resolved or at least substantially reduced.
Better don't try the shape filling method with attached wing...... The chance for glueing the wing to the fuse permanently is good at 99%..
Just filling the holes inner walls would not be good enough while breaking away soon after a few good throws.
I recommend to insert from inside the fuse a little plate of ~1mm PC board- or carbon board material behind the hole area using a good Epoxy glue (not 5min Epoxy!). After the glue has set, carefully rework the hole until the proper fit is restored.
KINETIC is offline Find More Posts by KINETIC
Old Dec 09, 2011, 11:22 PM
danfitz is online now
Find More Posts by danfitz
danfitz's Avatar
United States, CA, Vista
New CX-2
I flew my new Concept today. She is all tuned up and flying great.
This one came out light - 9.11oz / 258 grams. She seems happiest with the CG set at 83mm.
God I love these gliders. Thanks Roland.
danfitz is online now Find More Posts by danfitz
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 2 Mar 09, 2011 09:23 AM
For Sale Kyosho EP Concept 30 X 2 dhsmith1 Aircraft - Electric - Helis (FS/W) 0 Feb 14, 2011 05:34 PM
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 0 Jan 11, 2011 01:53 PM
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 0 Dec 26, 2010 02:57 PM
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 0 Nov 16, 2010 10:07 PM
