Old Feb 19, 2011, 03:35 AM
danfitz is offline
Find More Posts by danfitz
danfitz's Avatar
United States, CA, Vista
Cool
Concept Xtreme 2
Well, the twins are here! Now I am REALLY excited.
I received notice on Tuesday that Roland was shipping my gliders and they arrived on Thursday.
The shipping box is double wall all around and very stout. Critical parts were wrapped in bubble wrap and the whole box was filled with foam peanuts. All parts arrived in perfect condition.
On close inspection I was stunned at the extremely high level of completeness. This has to be the most ARF DLG available. It is more of an assembly than a build. The craftsmanship is outstanding, easily on par with the best I have seen.
The parts kit includes a 4.8V, 400 MAH 4 x 2/3 AAA, Ni-Mh battery and two 7 gram digital servos for the rudder and elevator. The servos seem to be high quality and are free of slop. A throwing peg is included. Roland even included an embroidered Concept hat!
Ailerons are driven by RDS with digital servos installed in the mold. All control surfaces including the elevator and rudder are gap sealed at the factory.
The vertical tail came assembled to the fuselage boom and the rudder horn and push rod are installed.
The elevator horn is pre installed and so is the push rod.
Rudder and elevator are driven by a double bell crank system that is hidden in the stab pylon. Pull-Pull strings are installed and strung to the nose area. All of this is done at the factory.
For the tail surfaces, all there is left to do is mount the stab, glue the included servo tray into the pod area, mount the servos and attach the pull-pull strings.
The canopy is held in place by the usual carbon rod which comes pre installed.
A nice touch is the full sized drawing of the tip area with dimensions to aid in the install of the throwing peg.
I am a slow builder but I should easily be able to finish and fly one this weekend.
danfitz is offline Find More Posts by danfitz
Old Feb 19, 2011, 03:47 AM
danfitz is offline
danfitz's Avatar
Cx2
Weights:
Wing one - 149.80 gm
Wing two - 148.52
Fuse one - 44.32 (vert fin installed)
Fuse two - 44.95 " " " "
Stab one - 8.07
Stab two - 8.10
Servo - 6.68
Peg - 2.04
Battery - 32.89
Old Feb 19, 2011, 03:59 AM
danfitz is offline
danfitz's Avatar
Cx2
A couple more...
Old Feb 19, 2011, 05:12 AM
beach1 is offline
Find More Posts by beach1
Concepts
Dan: You lucky dog! They look fantastic....got 2 on order but will not have them until May.....good luck....Jon
beach1 is offline Find More Posts by beach1
Old Feb 19, 2011, 08:45 AM
MattN is offline
Find More Posts by MattN
a.k.a. Matt Nelson
MattN's Avatar
North Tustin, CA
Joined Oct 2008
Dan, I'm envious. I wasn't feeling quite as bold, so I only ordered one - But it'll be months before I see it.
Even though the build looks simple, please post some pics...
-m@
MattN is offline Find More Posts by MattN
Old Feb 19, 2011, 10:58 AM
danfitz is offline
danfitz's Avatar
Yeah, I jumped in early. As soon as I flew Mike's I knew I wanted one, so I bought two!
Old Feb 19, 2011, 01:10 PM
LifeisGood is offline
Find More Posts by LifeisGood
Joined Apr 2006
Never mind
LifeisGood is offline Find More Posts by LifeisGood
Old Feb 20, 2011, 05:21 PM
MattN is offline
a.k.a. Matt Nelson
MattN's Avatar
North Tustin, CA
Joined Oct 2008
hey Dan, any evidence of re-engineering of the boom where George and Mike managed to blow them up?
-m@
Old Feb 20, 2011, 05:28 PM
ThomasLee is online now
Find More Posts by ThomasLee
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
this has got me drooling..........again.............
ThomasLee is online now Find More Posts by ThomasLee
Latest blog entry: Vibe Assembly Instructions
Old Feb 20, 2011, 09:34 PM
carlsoti is offline
Find More Posts by carlsoti
hass-alfed and bass-ackwards
carlsoti's Avatar
United States, AZ, Chandler
Joined Jun 2008
-m@
I may be incorrect in my assessment, but this is what I know of the issue.
In talking with George Morris, I gathered that the issue was bad CF fabric that Roland had gotten. IIRC, these first few planes were built just after his shop was destroyed by a typhoon. He had to resupply all his materials in a hurry, and thought that the CF he had gotten was not of the same quality he was using prior to the typhoon. After hearing of the issues, he went to a different cloth that had already proven itself.
Again, I could be wrong, so don't take that as gospel.
carlsoti is offline Find More Posts by carlsoti
Old Feb 20, 2011, 11:40 PM
danfitz is offline
danfitz's Avatar
Yes, that about sums it up. After the JEM Roland did tests and found problems with the fabric he was using for the booms. He has since switched to another fabric and test results were very positive. Outside of Mike's and George's gliders no other bad booms were shipped.
According to Roland - "Stiffness has increased by little over 40% and buckling strength by little under 300%!!!! The weight is just 1g more".
I can verify that the booms are VERY stiff. I flew #1 CX2 this morning and I am very happy! Thank you Roland!!
I will post some more pics later.
Dan
Old Feb 21, 2011, 10:47 PM
MattN is offline
a.k.a. Matt Nelson
MattN's Avatar
North Tustin, CA
Joined Oct 2008
dang it, Dan, you got me all excited about the CX2 again - so much so that i had to add a second one to my order
Old Feb 22, 2011, 12:19 AM
danfitz is offline
danfitz's Avatar
Anything I can do to help a friend Matt!
Old Feb 22, 2011, 12:45 AM
ShoGinn is offline
Find More Posts by ShoGinn
Space Cowboy
ShoGinn's Avatar
United States, CA, Vandenberg Air Force Base
Joined Jan 2007
Great looking plane. I love how clean everything is!
ShoGinn is offline Find More Posts by ShoGinn
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 2 Mar 09, 2011 09:23 AM
For Sale Kyosho EP Concept 30 X 2 dhsmith1 Aircraft - Electric - Helis (FS/W) 0 Feb 14, 2011 05:34 PM
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 0 Jan 11, 2011 01:53 PM
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 0 Dec 26, 2010 02:57 PM
For Sale XPS Xtreme 2.4 Futaba module and RX $100 John Kim Aircraft - General - Radio Equipment (FS/W) 0 Nov 16, 2010 10:07 PM
