Old Feb 18, 2011, 05:21 PM
joallen001 is offline
Find More Posts by joallen001
Tennessee
Joined Dec 2005
Parallel charging with this board?
http://www.powerwerx.com/anderson-po...tact.html#desc
Is it possible to parallel charge using power poles and this board?
joallen001 is offline Find More Posts by joallen001
Old Feb 18, 2011, 06:15 PM
rampman is online now
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
No, that board is more of a high amp project board than a parallel charging board.
I would never parallel charge without connecting the balance taps too.
Rick
rampman is online now Find More Posts by rampman
Old Feb 18, 2011, 06:21 PM
Tennessee
Joined Dec 2005
Rick
Yes I would still use balance taps. Even though it is rated for high amps. Could it not be used since the charger is supplying the desired amps.
Old Feb 18, 2011, 06:31 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
It will certainly work but understand that the link that you provided is for the contacts that go into a PCB, not for a PCB itself. To my understanding, Powerwerx does not carry printed circuit boards.
Brewing your own PCB mount APP's is pretty simple with some solid core bus wire.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Feb 18, 2011, 06:37 PM
Tennessee
Joined Dec 2005
Mark
You have a link to where that board can be purchased.
Old Feb 18, 2011, 07:25 PM
So. Cal.
I buy my perf board from All Electronics and then wire / customize for my purposes.
Mark
Sold Hobby King Parallel charging Board for 6 packs 2~6S FieldofDreamsFlyer Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 06, 2011 04:56 PM
Discussion Parallel charging board from HK Lardog Batteries and Chargers 2 Dec 10, 2010 07:20 PM
Discussion New HK 6S parallel charging board bymannan Batteries and Chargers 6 Nov 23, 2010 08:27 AM
Discussion Can I use this adapter for parallel charging in 206B? avt Batteries and Chargers 5 Oct 29, 2010 04:14 PM
New Product parallel charging board‏ warbirdguyn951 Batteries and Chargers 43 Oct 13, 2010 04:03 AM
