Old Sep 18, 2003, 08:00 PM
Daren is offline
Find More Posts by Daren
Daren's Avatar
Los Alamos, NM, USofA
Joined Nov 2000
Re: Re: relativley safe lipos
Originally posted by Ulf Herder
If they make it fool poven and limit the current to ( for example) 3C at discharge nobody will use it for aircrafts or customers will disable the safety funktions!
Ulf,
You can still use the batteries at 3C (or any C), you just have to increase the capacity to match your amp draw.
(Amp draw / 3C = Minimum Capacity). But you knew that already, eh?
Daren
Daren is offline Find More Posts by Daren
Old Sep 19, 2003, 06:32 AM
rdimberio is offline
Find More Posts by rdimberio
Florida Flyer
Joined Aug 2003
RD Blakeslee,
I assume then, that you leave those lipos "out in the country" and don't transport them in your flammable car or bring them home to your flammable house for "known safety practice's" recharging?
rdimberio is offline Find More Posts by rdimberio
Old Sep 19, 2003, 12:08 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Re: Re: Re: relativley safe lipos
Originally posted by Daren
Ulf, ... you just have to increase the capacity to match your amp draw. ... Daren
... which will increase the weight - as usually the capacity scales linearly with the weight - I think that is what Ulf is taking into consideration as well..
Herb is offline Find More Posts by Herb
Old Sep 19, 2003, 12:40 PM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
Right, increase the weight enough and you might as well be using NiMH.
Dave Hederich is offline Find More Posts by Dave Hederich
Old Sep 19, 2003, 07:34 PM
lagcisco is offline
Find More Posts by lagcisco
Los Angeles Industry, California, United States
Joined May 2003
im scared now, maybe i should just go back to
nitro planes, then again thats flamable too..
lagcisco is offline Find More Posts by lagcisco
Old Sep 19, 2003, 08:16 PM
Daren is offline
Daren's Avatar
Joined Nov 2000
Re: Re: Re: Re: relativley safe lipos
Don't we all.
Dave:
You may be right, but it would be hard now to give up the ease of charging. Gone are cycling, peaking, etc. Now I charge when I get home from flying and I'm ready to go for next week!
Daren
Old Sep 19, 2003, 08:24 PM
Joined Feb 2000
Daren, it's a trade-off. The Li-poly packs are a hassle in one way and the NiMH packs are a hassle in a different way. Different people are coming to different conclusions, and I assume that everyone is correct because they are doing the right thing for themselves. I think the only time people get in trouble is when they try to do what they think they should do based on what other people are doing rather than doing what they think is best for themselves.
Old Sep 19, 2003, 08:45 PM
Daren is offline
Daren's Avatar
Joined Nov 2000
You're right about that. It always is.
Daren
Old Sep 21, 2003, 10:52 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Many new technologies bring new risks but also new opportinities ...
The new risks involved should be clearly and squarely addressed by the manufacturers and vendors involved.
Old Sep 22, 2003, 04:17 AM
othmanskn is offline
Find More Posts by othmanskn
othmanskn's Avatar
Petagas, Kota Kinabalu, Sabah, Malaysia
Joined Sep 2003
[QUOTE]Originally posted by opualuan
[B]safety circuits won't help. if the cell smashes in a wreck, so will the protection circuit.
casing the battery? bad. you now have a great source of not only weight, but shrapnel in the event of a vent. now, sausaging a li-poly is bad, but I'd rather a mylar coating popping than aluminum shards being blown apart.
consumer li-ion/li-poly implementations are meant for consumer use. I can almost guarantee a ballasted cellphone dropped from 250 feet up could cause a similar issue with the li-polymer cell is contains.
For aircraft RC, all protections will be removed to save weight,
but precautions should be initiated when charging and storing.
I am most worried about the damage due to vibrations and
crashes which I keep on getting with my batteries, although
they are NiCd and NiMH only.
I shall be more careful. Thank you all for your comments.
Looking for a good container.
othmanskn is offline Find More Posts by othmanskn
Old Jan 14, 2008, 08:13 AM
sven311 is offline
Find More Posts by sven311
Joined Mar 2007
I gues a nitro plane(not a jet!) won't burn that fast as an damaged lipo!
I had to throw a lipo away also today,she was very swollen end had a real nasty smell!The faster it's out of my house,the better!
sven
sven311 is offline Find More Posts by sven311
