Space Coast
Joined Oct 2000
Check out JJ's last two posts on this thread.
http://www.rcuniverse.com/showthread...75&forumid=269 This is the kind of information that needs to be in a sticky. What say guys? hoppy |
I now charge all batteries with my charger, power supply, and batteries being charged all in one of those small fireproof safes. Then I store all my batteries in an ammo box. Call me paranoid, but I am paranoid-after having a NIMH pack explode shortly after I was able to pull over and throw it out of my car.
I've also had another NiMH pack short out, and it probably would have caught fire if I hadn't ripped the cells apart and pulled the wires immediately. |
Daytona Beach, FL
Joined Sep 2003
As a manufacture of hobby products it is very difficult providing information to any forum. Some consider it to be just a marketing ploy to get exposure for one’s products. But, when it comes to a safety issue I believe one is obligated to inform and stimulate others thinking so research can be done and each can make his assessment. I will attempt to keep my post nonpartisan.
The “Lithium Polymer battery” used in the hobby and in most commercial applications is really a Lithium-ion battery that has had the internal power generating materials folded to be flat instead of rolled up to fit in the cylindrical can, it is then installed in a light aluminum container that was original designed for food storage, works great. The good news is that the “Lithium Polymer battery” is light and has the ability to support higher loads because of the better heat distribution and the ability to dissipate that heat under higher loads (5C to 8C), this is the good part. The other side of the coin is that under the charging process the “Lithium Polymer cells” don’t include any of the safety systems that are part of a Lithium-ion cylindrical cell, so the cell has no way of protecting itself. This then requires control of the charging cycle imperative. There was/is a false presentation in the hobby that the “Lithium Polymer Battery” is completely safe and won’t create an unhappy experience. The liquid electrolyte found in the hobby Lithium Polymer batteries is very flammable and when the battery is overcharged (voltage) it gets very hot, the liquid expands, the battery puffs up like a balloon, the cell packaging fails, the liquid electrolyte spreads over the area, and the possible result is a very exciding fire. The Hobby is experiencing an unacceptable number of failures with the Lithium Polymer hobby batteries caused by the use of an inappropriate charger, malfunctioning charger, or an incorrectly programmed charger. We have known from the beginning that the only safe way to present this technology to the hobby was to supply batteries with protection in the pack to prevent overcharge (voltage). This is the only sure way to protect the end user during the charging cycle. The only draw back is the cost of the safety circuit and its weight (3 to 4 grams), a small price to pay for the piece of mind that you eliminate the possibility of a catastrophic failure during charging. Yes, we include this protection in our packs and now many of the other major hobby battery suppliers are evaluating ways to include this safety circuit. All of us make every effort to supply a safe charger for the Lithium batteries but for many reasons it’s not always sufficient protection. Taking a chance that something won’t go wrong is a bad philosophy. Knowledge is an important ingredient. Have a great weekend, Emory |
Where it Rains
Joined Jul 2002
Emory,
This is very useful information, especially the electrolyte being flammable. What you don't addres, however, is what happens when the cell is damaged as from a crash. That's what happened to me - a crash damaged the cells, they shorted internally, and poof - a nasty car fire. Ken |
Walled Lake, MI, USA
Joined Feb 2000
Emory, the safety part of your messages on this subject are always welcome. You and your company deserve all the credit in the world for pioneering the use of safety circuits on your Li-poly packs for R/C use. No one should criticize you for talking about safety mechanisms that you have implemented. There's nothing wrong with marketing safety.
Your definition of lithium polymer is a separate issue and highly controversial. It appears to be a minority opinion accepted by only a few people in the business. Since you've elected to raise the issue here, I'm sure that it will be hotly debated. After all, you are essentially accusing Kokam, FMA Direct, Thunder Power, E-Tec and a host of others of false advertising when you say that their cells are not true Li-polys. So I hope you aren't too sensitive about being questioned on the definition you've elected to promote. |
Space Coast
Joined Oct 2000
The Energy Storage Association recognizes two LiPoly technologies - one uses liquid electrolyte, the other a dry electrolyte.
http://www.energystorage.org/pubs/20...lBatteries.pdf hoppy |
This is the question I would like to see answered. As I stated I have had a prop cut into a cell and I have seen pictures on this forum where a cell had been shot with an air gun and had a lead pellet lodged in it with no resualting fire. Ken, On the pack that caused your fire is it possible that the tabs shorted causing the fire. Most of my packs are home built so I can get to the tabs to do balance checks and inspect for damage but I did order two prebuilt packs that had the terminal end covered with duct tape so it is impossible to inspect the tabs for damage or to check pack balance and possible shorts. |
Joined Feb 2000
Hoppy, that's a good find. It lists the major classifications of cells, and has two major classifications for lithiums: lithium ion and lithium polymer. Within the lithium polymer classification, it notes that "lithium ion polymer has liquid electrolyte" and "dry polymer technology uses polymer as electrolyte."
Emory has presented one person's opinion that most of the cells being sold as Li-poly are not "true" lithium polymer cells. Yet the Energy Storage Association lists both liquid and dry technologies under lithium polymer. That indicates to me that when either the liquid or dry proponents claim that they are the only "true" lithium polymer, that it's nothing but marketing talk. |
