Espritmodel.com Heli Air
Old Apr 23, 2011, 10:59 AM
hyperknight's Avatar
Irvine, CA
Joined Apr 2003
Originally Posted by The Don View Post
Look at this photo in the top right. The receiver is white in color. I used my Dremel and removed some foam so the rx would fit.
http://www.rcgroups.com/forums/attac...mentid=3817158
This is the receiver I use:
http://www.hobbyking.com/hobbyking/s...idProduct=8389
Hmmm... Thats not going to work for me. Need to use a spektrum receiver. Well, hopefully, I'll be able to dremel out some foam and get a AR6100e to fit in there...
hk
hyperknight is offline Find More Posts by hyperknight
Old Apr 23, 2011, 08:19 PM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
hk
No need for a dremel aside form the wire channels. Here is how I did it...
gooniac33 is offline Find More Posts by gooniac33
Old Apr 24, 2011, 12:51 AM
Irvine, CA
Joined Apr 2003
Where's the receiver???
Look pretty tight. I was thinking to go with 1300mAh pack. Might have to go with 1000mAh if I have to use the bigger spektrum receiver.
hk
Old Apr 24, 2011, 12:59 AM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
There is an AR6110E under the wires. You can see part of it just below the silver elevator pushrods.
Old Apr 24, 2011, 01:40 AM
Irvine, CA
Joined Apr 2003
Ah. I see it now. I was thinking of trying to squeeze in an AR6200 without the remote receiver in the similar location. Not sure if the 6200 can be used without it.
hk
Old Apr 24, 2011, 12:32 PM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
hk
It is not needed. Just use the parkflyer receivers. This is a small jet and it won't be able to go very far from you. I use AR6110E's and Hobby King Orange receivers as well. Really no need for the bigger ones....
Old Apr 24, 2011, 06:51 PM
Irvine, CA
Joined Apr 2003
Yup. I'll probably just get one of the 6110's then.
Thanks for the info.
hk
Old May 08, 2011, 09:38 PM
Irvine, CA
Joined Apr 2003
Maidened yesterday. Performance was awesome! Way faster than I had anticipated.
Unfortunately, the Mig got destroyed on the second hand launch. Got another one on order already.
This Wicked 4800kv w/ wemo combo is awesome!
Hey Don,
Quick question. I had originally bought the 40amp HW ESC based on your original posting listing your setup. However, I see in your pictures you're using the 30 amp esc. Can you confirm which one you're using? If the 30 amp works well, then I'll switch to the smaller esc.... need all the room I can get...
BTW, for the receiver, I picked up an ORANGE Spektrum compatible 4 channel receiver. This thing is tiny. I was nervous at first to use it but it seemed to work flawlessly.
hk
Old Jun 03, 2011, 08:53 PM
Call sign = TOMATOFLAMES
roto20's Avatar
Seattle, WA
Joined Sep 2008
My Mig CG is about 93mm with the 4S1000mah lipo and about 87mm with the 4S 1300 lipo. I like the forward CG a little better as it needs no down elevator trim. With the 4S 1000 I needed about 1/16" down elevator. The 4S1300 needed no down elevator.
Have you experimented with adding some anhedral? I noticed a few people have done this for added stability. Curious on your thoughts>?
roto20 is offline Find More Posts by roto20
Old Jun 04, 2011, 01:02 AM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
I fly with someone that has put has done that to his and it flies great! It is kinda hard to get the wings straight and not twisted though.
Old Jun 04, 2011, 12:46 PM
roto20's Avatar
Seattle, WA
Joined Sep 2008
Wing Incidence & washout Mod?
I had read in the Alfa thread about adding some incidence in the wing. Has anyone done this?
Did TheDon add any washout in the wing? I know rvincent did but doesn't look like he added much.
http://www.rcgroups.com/forums/showp...ostcount=11340
Old Jul 15, 2011, 06:37 PM
Joined Jul 2006
mig 15 50mm
glad i looked at what everyone had to say on this---flew mine stock today and if i had not set about 1/16 down trim on elev i would have got into trouble---i had to enter 5 more clicks of down and everything was fine--cg is about 93 mm---I used a quarter up in nose---flys good ---i will keep drop tanks off-- it needs the streamlining ----Go Vertical Baby !--but u will have to go 4S
flyr602 is offline Find More Posts by flyr602
Old Mar 09, 2013, 02:42 PM
Huntington Beach CA
[QUOTE=rvincent;17770344]Ok thanks, I'm getting ready for that step right now. I did as you did with the vertical stab and changed the incidence. I also cut in the needed anhydralto give it the scale look I also warped in a little wash out in the wing tips. Hoping these changes help it fly flower better given the added weight of the 1300 4S pack[/QUOTE
I know I am coming in a little late but hopefully this thread and the plane is still alive.
How much anhedral did you give for the scale look and did it help out at all?
socalsteve is offline Find More Posts by socalsteve
Old Mar 09, 2013, 02:55 PM
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Funny you should ask I just dusted her off to go out tomorrow! Yeah it helped and it flies great!! Very stable and smooth. Also VERY fast With the fuse on a level table it has 1/2" clearance under each wingtip.
rvincent is offline Find More Posts by rvincent
Old Mar 09, 2013, 06:39 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Bob,
Glad to see you poking around RCG again. How you been?
The Don is offline Find More Posts by The Don
Build Log Wicked Powered Banana Hobby Jpower 50mm AMX The Don Don's RC 199 Dec 19, 2012 08:19 PM
Build Log Wicked Powered 50mm Jpower T-33 EDF The Don Don's RC 21 Jul 26, 2012 02:07 PM
Build Log Wicked Powered Banana Hobby JPower 50mm F-86 The Don Don's RC 126 Aug 11, 2011 09:05 PM
Build Log Wicked Powered Jpower 50mm T-45 EDF The Don Don's RC 32 Aug 07, 2011 04:31 PM
Sold Receiver Ready Wicked Powered 50mm Jpower L-39 and T-45 The Don Aircraft - Electric - Jets (FS/W) 0 Oct 10, 2010 06:50 PM
