Old Mar 23, 2011, 07:38 AM
FoamJunkE is offline
Find More Posts by FoamJunkE
EDF Junkie
FoamJunkE's Avatar
San Antonio, TX
Joined Jul 2010
What was the CG for your MIG Don? Im looking to start the build on mine pretty soon.. I really like your idea with the battery tray. Im currently working on my second F86 (really liked my first one, and thanx to you my CG was perfect) and did something similar, but instead of a wooden tray Im using some fiberglass window screen. It looks like it should work pretty good and will definetly add some cooling to my batt all at the same time.
FoamJunkE is offline Find More Posts by FoamJunkE
Old Mar 23, 2011, 02:33 PM
GBR2 is offline
Find More Posts by GBR2
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
Just curious, are those clone Ultra plugs as I've never seen Deans come with built in grabbing ribs (which I wish they would do).
GBR2 is offline Find More Posts by GBR2
Old Mar 23, 2011, 11:09 PM
rvincent is online now
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Hey Don I notice black depron around the exit duct? Was that to help center the smaller exit tube?
rvincent is online now Find More Posts by rvincent
Old Mar 23, 2011, 11:22 PM
The Don is online now
Find More Posts by The Don
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Oops.!!! my bad, looks like I forgot to post it, here it is.
Don
The Don is online now Find More Posts by The Don
Old Mar 23, 2011, 11:27 PM
rvincent's Avatar
Joined Jul 2004
Thanks!
Old Mar 23, 2011, 11:31 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
My Mig CG is about 93mm with the 4S1000mah lipo and about 87mm with the 4S 1300 lipo. I like the forward CG a little better as it needs no down elevator trim. With the 4S 1000 I needed about 1/16" down elevator. The 4S1300 needed no down elevator.
Old Mar 23, 2011, 11:55 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Bob,
As stupid as it sounds make sure your PDF print window is set to 100% print, sometimes they print 98% or "fit to paper" by default. Also the templates are not really meant to go over the EDF housing they are essentially the same diameter. If you look at the build photos I have the thrust tube butts up to the fan unit then I tape it to the fan. If you try to go over the OD of the housing there is usually no clearance as the foam hugs the OD of the fan unit.
Old Mar 24, 2011, 12:00 AM
rvincent's Avatar
Joined Jul 2004
Ok thanks, I'm getting ready for that step right now. I did as you did with the vertical stab and changed the incidence. I also cut in the needed anhydralto give it the scale look I also warped in a little wash out in the wing tips. Hoping these changes help it fly flower better given the added weight of the 1300 4S pack
Old Mar 24, 2011, 12:04 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I have been using them for a long time on my EDFs
http://www.donsrc.com/cart/index.php...d&productId=84
Old Mar 24, 2011, 09:37 AM
gooniac33 is online now
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
The weight is a good thing. I am actually going to get one and take out the nose weight that I have in mine. Actually I am going to order a couple...
gooniac33 is online now Find More Posts by gooniac33
Old Mar 30, 2011, 10:55 AM
profilefan is online now
Find More Posts by profilefan
profilefan's Avatar
NYC
Joined Jun 2008
Nice build as always Don, which lipo do you prefer if you had to pick one?
profilefan is online now Find More Posts by profilefan
Old Mar 30, 2011, 06:08 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
The 4S1300 is what I bought more of :-)
Don
Old Apr 22, 2011, 09:56 AM
hyperknight is offline
Find More Posts by hyperknight
hyperknight's Avatar
Irvine, CA
Joined Apr 2003
Don,
I just picked one of these up and ordered the power setup from your site (wemo & 4800kv motor). I will be getting the same battery as well (1000mah).
I think I got everything laid out but I'm scratching my head one where I would place the receiver. Can you let me know what receiver you are using and where you placed it?
TIA,
hk
hyperknight is offline Find More Posts by hyperknight
Old Apr 22, 2011, 10:03 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Originally Posted by hyperknight View Post
Don,
TIA,
hk
Look at this photo in the top right. The receiver is white in color. I used my Dremel and removed some foam so the rx would fit.
http://www.rcgroups.com/forums/attac...mentid=3817158
This is the receiver I use:
http://www.hobbyking.com/hobbyking/s...idProduct=8389
Old Apr 22, 2011, 10:46 AM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
That is exactly how I did mine and it works great. Once you remove the foam next to the battery the wires can slide into there. I also removed my canopy and reglued it with the foam piece about 1/4 inch higher than stock. It made more room for the battery to fit in there. Works great now!
Build Log Wicked Powered Banana Hobby JPower 50mm F-86 The Don Don's RC 131 Feb 15, 2014 10:50 PM
Build Log Wicked Powered Banana Hobby Jpower 50mm AMX The Don Don's RC 199 Dec 19, 2012 08:19 PM
Build Log Wicked Powered 50mm Jpower T-33 EDF The Don Don's RC 21 Jul 26, 2012 02:07 PM
Build Log Wicked Powered Jpower 50mm T-45 EDF The Don Don's RC 32 Aug 07, 2011 04:31 PM
Sold Receiver Ready Wicked Powered 50mm Jpower L-39 and T-45 The Don Aircraft - Electric - Jets (FS/W) 0 Oct 10, 2010 06:50 PM
