Old Feb 17, 2011, 11:48 PM
The Don is offline
Find More Posts by The Don
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Build Log
Wicked powered Jpower 50mm Mig-15 EDF
Here is my build thread for the Jpower 50mm Mig 15 50mm EDF. I bought this from Nitroplanes when they had free shipping last month.
Setup:
Wicked 4800 KV
Wemotec 50mm fan
Pentium 40 ESC
lipo will be a 4S 1000 40C Skylipo from hobbypartz
Don
The Don is offline Find More Posts by The Don
Old Feb 17, 2011, 11:58 PM
The Don is offline
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Used the Dremel and removed some foam. The 4S1000 lipo fits well. A 3S 1800 does fit but is quite long. If you are wanting to use the 6000 KV motor then a 3S 1500 would be the biggest I think you can fit in. More tomorrow but need to head off to bed.
Don.
Old Feb 18, 2011, 09:00 AM
MRGTX is offline
Find More Posts by MRGTX
MRGTX's Avatar
United States, CT
Joined Aug 2005
I have been looking this Mig.. I'll be following your build and results with some interest.
It seems that every plane that gets the Wemo 50mm treatment is vastly improved... but my hunch is that this airframe might not benefit as much due to the excessive drag.
Even if the top speed wont keep up with the Wicked powered F-16, etc I bet it will still climb like King Kong.
MRGTX is offline Find More Posts by MRGTX
Old Feb 18, 2011, 10:08 AM
gooniac33 is offline
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Setup:
Wicked 4800 KV
Wemotec 50mm fan
Pentium 40 ESC
Don
That battery has been very good for me thus far! Lots of power in those little things! Over 400watts in my set up with those. And with mine I used the dremel along the sides on the inside of the battery compartment for the wires to slide next to the battery.
gooniac33 is offline Find More Posts by gooniac33
Old Feb 18, 2011, 12:15 PM
killickb is online now
Find More Posts by killickb
killickb
killickb's Avatar
The Villages. Florida
Joined Jan 2005
Don, I got a Hyperion 1600 in the fuse of my Mig ok but had to cut away all of the canopy floor to be able to stuff the wiring into the canopy and change to higher powered magnets to keep it closed ! As stated before more thrust is noticeable more speed less so but the whine from that 6000 motor/fan prevents me flying at our field so going back to stock on the Mig.
killickb is online now Find More Posts by killickb
Old Feb 20, 2011, 11:11 PM
The Don is offline
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Here are more photos. The plane is all finished. I am headed to bed for now. Will add comments on what I did tomorrow.
Don
EDIT: captions added
Old Feb 21, 2011, 11:19 AM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Looking good! I like how you set up the battery compartment! And the fix for the incidence as well.... Can't wait to hear about the flight report!
Old Mar 08, 2011, 12:22 AM
The Don is offline
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Got my maiden in today. Had only one 4S1000 pack but it flew right out of my hand. I still needed a few down trim clicks but I am so glad I went with reduced tail incidence. I did manage a 90 mph pass on my droid app which is not to bad in 32F weather. I did hit the darn field goal post on my landing approach, knocked a wing off but I have already fixed it. I think I am going to go for a 4S 1300 lipo in this model. I need more WOT flight time!
Don
Old Mar 08, 2011, 08:50 AM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Don
Nice! That is the set up that I need to try on mine!
Old Mar 16, 2011, 04:01 PM
rvincent is online now
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Nice Don! I will follow your lead with the tail incidence
rvincent is online now Find More Posts by rvincent
Old Mar 16, 2011, 04:51 PM
foamjet is offline
Find More Posts by foamjet
Joined Mar 2011
thanks for the great build.
Only a few posts but worth much more than
those big threads over there with so many
confusing, repeating info.
Are you doing the anhydral wings too?
foamjet is offline Find More Posts by foamjet
Reply With Quote  (Disabled)
Old Mar 17, 2011, 12:13 AM
The Don is offline
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Here is how I get a 4AS 1300 lipo in. I made a tray from some hard 1/16" sheet about 4" x 2 ". Then glued 1/8 x 1/4" strip around the perimeter. Then cut the front open so the balsa try will install much easier (see photo). Then glued the tray in. The lipo fits perfectly in. Next will be putting the nose back together.
Don
Old Mar 17, 2011, 12:57 AM
rvincent's Avatar
Joined Jul 2004
Way to go Don! I was going to use a carbon plate, but it think I will use it for control horn protection and build a wood tray for the pack. How's the CG?
Old Mar 20, 2011, 03:05 PM
The Don is offline
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Here is some video from my two flights yesterday.
Wicked Powered Jpower Mig15 50mm EDF (5 min 36 sec)
I am flying the CG forward of the manual. I will get the CG I am using posted.
Don
Old Mar 20, 2011, 05:56 PM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
http://www.youtube.com/watch?v=-bgjjP4U6n0
Don
That must be why it is so fast! Very nice!!
Build Log Wicked Powered Banana Hobby JPower 50mm F-86 The Don Don's RC 131 Feb 15, 2014 10:50 PM
Build Log Wicked Powered Banana Hobby Jpower 50mm AMX The Don Don's RC 199 Dec 19, 2012 08:19 PM
Build Log Wicked Powered 50mm Jpower T-33 EDF The Don Don's RC 21 Jul 26, 2012 02:07 PM
Build Log Wicked Powered Jpower 50mm T-45 EDF The Don Don's RC 32 Aug 07, 2011 04:31 PM
Sold Receiver Ready Wicked Powered 50mm Jpower L-39 and T-45 The Don Aircraft - Electric - Jets (FS/W) 0 Oct 10, 2010 06:50 PM
