Old Feb 17, 2011, 06:32 PM
CaliDave is offline
Find More Posts by CaliDave
CaliDave's Avatar
Bay Area
Joined Dec 2010
Build Log
FPV Twin Star II - Build Log
I've edited this build log to reflect my current build status.
Thanks to those who've given me advice on this.
My goal is still to have long flight times and stable flight for HD recording.
Here is the update:
11/06/2011
Current setup (operational):
Motors: HB2815-1400 (Himax)
ESCs: x2 Turnigy Plush 30A Speed Controller
Counter Rotating Prop Setup:
APC 8x6 Thin Electric Propeller
APC 8x6 Thin Electric Pusher Propeller
Battery: ZIPPY Flightmax 5000mAh 3S1P 20C
OSD: Eagle Tree w/RTH
Flight/Record Camera: GoPro HD
Servos: x4 HiTec HS-82MG
Other: LC-Filter for VTx power
POD: ReadyMadeRC pan/tilt for GoPro
VTx: 1.3g or 5.8g
Video Link Antenna: Inverted V (1280) or BluBeam CP (5.8G)
AUW: 63oz.
Energy Consumption: 275mAh/mile (approx.)
Max Flight Travel Distance: 16 miles (approx.)
Max Distance from home flown: 3.8 miles
CaliDave is offline Find More Posts by CaliDave
Old Feb 17, 2011, 07:19 PM
zaguruinzasky is offline
Find More Posts by zaguruinzasky
Smoke on , go !
zaguruinzasky's Avatar
Verona - Italy
Joined Jan 2007
Ciao Dave,
a 3 blade (same size same pitch) pulls more but is less efficient and it brakes your airplane more when you're idle.
I suggest you to go for the very new TwinStar multiplex motor kit. That's very fine tuned on this airframe. I would go fot that if I had to build a new TS. I've built some TS in the past so if you need just ask but basically the only mod that I found useful is to mount the servo on tail or somewhere on the rear side to compensate the need of tail weight to achieve the correct cg. The TS is rock solid, you don't need any reinforcement, keep it light and easy to build.
Another important thing is counter rotating props, one normal prop and one pusher prop, you won't affect the attitude of the airplane while managing the power.
The fuselage doesn't need to be solid in flight because motors are on wing so I suggest you a solution that allows you to re-open the fuselage anytime you need or at least some doors on the belly.
zaguruinzasky is offline Find More Posts by zaguruinzasky
Old Feb 17, 2011, 07:21 PM
Smoke on , go !
Verona - Italy
Joined Jan 2007
Don't buy cheap motors, go for Multiplex or Hyperion or Skorpion, you need vibration free airplane if you fly cmos sensor at fullHD resolution.
Buy parkflierplastic's belly protection for twinstar, it's fantastic.
Old Feb 17, 2011, 07:31 PM
Alvid98 is offline
Find More Posts by Alvid98
Joined Jan 2011
I used eflite park480 1020kv motors pulling 10x8 props (the thin eflite ones - 1 counter rotating) and with a 3s 5000mah batt I was getting 30min powered flights. The motors are def too big and were a pain to get mounted, I would use smaller motors if I bought everything again. Also the readymaderc pan/tilt pod works outstanding, love mine. Hs65hb servos were flawless with no jitter on 900mhz .5w
Alvid98 is offline Find More Posts by Alvid98
Old Feb 17, 2011, 07:36 PM
CaliDave is offline
CaliDave's Avatar
Bay Area
Joined Dec 2010
Thanks for the advice, good thoughts for balance, weight and motors. I was looking into this motor/prop/esc combo, but it looks like the multiplex pack is slightly less$.
Any thoughts on the 2? And it doesn't seem that either is a combo of pusher and counter motor... but maybe I'm not totally understand that. But yes, less vibration is desired.
Old Feb 17, 2011, 07:38 PM
Smoke on , go !
Verona - Italy
Joined Jan 2007
no no go for multiplex new kit, outrunner, for the pusher thing you just need a pusher prop (inverted pitch), and you need to change the direction of motor rotation by changing position at two of the 3 cables going from the esc to the motor. But you can just start with normal props and make the change later if you feel the need...
Old Feb 17, 2011, 07:39 PM
Smoke on , go !
Verona - Italy
Joined Jan 2007
Multiplex catalogue 2011, page 10
Old Feb 17, 2011, 07:41 PM
Smoke on , go !
Verona - Italy
Joined Jan 2007
2 x PERMAX BL-O 2830-1100 brushless motors # 33 3108
2 x MULTIcont BL-20 SD speed controllers # 7 2232
2 x 8” x 5” propellers # 73 3163
2 x Aluminium firewalls # 33 2607
2 x Propeller drivers and spinners # 33 2335
Cable set for “TwinStar II brushless” power set # 8 5061
Li-BATT eco 3/1-3000 (M6) # 15 723
Old Feb 17, 2011, 07:42 PM
galaxiex is offline
Find More Posts by galaxiex
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
That (your link) >>>> http://www3.towerhobbies.com/cgi-bin...?&I=LXPVG5&P=7
....is the "old" Power Pack for the TSII.
The "new" Power Pack is in here >>>> http://www.multiplex-rc.de/cms/vorsc...PX_2011_GB.pdf
.... sorry for the huge download...
The new Power Pack is listed near the end of the document.
Edit; oops, too slow... Zaguru beat me to it....
galaxiex is offline Find More Posts by galaxiex
Old Feb 17, 2011, 07:52 PM
CaliDave is offline
CaliDave's Avatar
Bay Area
Joined Dec 2010
Great update... I find the old power pack all around, however I can't seem to find the new one for sale... do you have a link or is it not released yet?
Old Feb 17, 2011, 07:53 PM
Smoke on , go !
Verona - Italy
Joined Jan 2007
just announced , probably it's a matter of days/weeks.. worth waiting.
Old Feb 17, 2011, 07:55 PM
galaxiex is offline
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
What he said... ^^^
Old Feb 17, 2011, 08:02 PM
CaliDave is offline
CaliDave's Avatar
Bay Area
Joined Dec 2010
Thanks! I won't have the plane until next week so I'll be patient. Gotta get my EZ back in the air after my crash so I'll be busy with that.
Any thoughts on landing gear? Not worth the weight? Maybe just wing tip skids and belly protection? Hard to say if I'll always have a road like landing strip, but that's mostly what I have to land on.
Also, I will be adding either the belly or side hatch. Anyone tried both (not on the same plane) and found one better/easier to deal with? The belly hatch on my EZ is perfect and has been no issue but I know there is more room on the TS2 so maybe it needs to be bigger causing more stress to the frame if on the bottom?
Old Feb 17, 2011, 08:25 PM
twinturbostang is offline
Find More Posts by twinturbostang
Fly FPV, sleep; repeat
twinturbostang's Avatar
United States, MD, Hagerstown
Joined Mar 2006
Belly protection is easy. Just use long strips of packing tape. No need to buy anything else for that. If it wears out, you remove it and put new packing tape on.
My TS2 is flying with justgofly.com 400F motors turning 6x4 props. Gives flight times around 30-35 minutes on a 4200 mAh pack if you manage the throttle well. No vibrations at all either since the props are small. My GoPro video is clean as a whistle.
twinturbostang is offline Find More Posts by twinturbostang
Old Feb 17, 2011, 09:55 PM
BloomingtonFPV is offline
Find More Posts by BloomingtonFPV
KC9TPL- Get Legit
BloomingtonFPV's Avatar
USA, IN, Bloomington
Joined Aug 2007
Use Transparent Scotch Toughtape. Stuff is incredibly tough and sticks great without leaving residue when you peel it off.
Here is my TS2 circuit diagram:
http://www.rcgroups.com/forums/showthread.php?t=1385067
I'm just finishing it now. I forgot to diagram in the 12-volt regulator that ensures a constant 12 volts to the camera.
BloomingtonFPV is offline Find More Posts by BloomingtonFPV
Cool Maiden my new FPV Twin Star II Crash9 FPV Talk 35 Dec 02, 2014 03:37 PM
Sold Multiplex Twin Star II - PnP with lots of mods! MinneFlyer Aircraft - Electric - Airplanes (FS/W) 3 Sep 05, 2010 10:05 PM
Discussion First FPV flight with the Twin Star II dadde FPV Talk 6 Jun 03, 2009 03:33 AM
Discussion My FPV Twin Star II. Lynxman FPV Talk 5 Mar 14, 2009 08:38 AM
Post your pics MPX Twin Star II build/color scheme. dnasrep000 Foamies (Kits) 3 Sep 01, 2005 12:59 AM
