Old Feb 17, 2011, 10:24 AM
dpowellmeii is offline
Find More Posts by dpowellmeii
Madison, MS
Joined Oct 2006
Build Log
Thrust Vectoring Kite
http://www.rcgroups.com/forums/showthread.php?t=1340992
dpowellmeii is offline Find More Posts by dpowellmeii
Old Feb 17, 2011, 01:22 PM
rcrich is offline
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
Does anyone sell a thrust vectoring gimble?
rcrich is offline Find More Posts by rcrich
Old Feb 17, 2011, 01:51 PM
Madison, MS
Joined Oct 2006
http://shop.premierrc.com/vectorpowerunits.aspx
Old Feb 17, 2011, 02:21 PM
Harry D is offline
Find More Posts by Harry D
TLAR Aviation
Harry D's Avatar
Canada, AB, Edmonton
dp, I've been admiring that gimbal and support structure you designed and built. Would you care to post a bit more information on it?
I started doing something very similar a while ago but haven't had the time to finish it yet. I'd much appreciate hearing about any experiences you'd like to share (minimize reinventing the wheel, and all that).
Thanks!
Harry D is offline Find More Posts by Harry D
Old Feb 17, 2011, 04:23 PM
STRINGFLY is offline
Find More Posts by STRINGFLY
STRINGFLY's Avatar
Little Rock Regional, Arkansas, United States
Joined Sep 2002
Here are some closeups of my Premier unit.
Stringfly <>++++
STRINGFLY is offline Find More Posts by STRINGFLY
Old Feb 17, 2011, 04:34 PM
rcrich is offline
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
I only want the gimble unit not the motor or servos . thanks
Old Feb 17, 2011, 04:36 PM
Madison, MS
Joined Oct 2006
thats what i figured but this is the only thing i know of. call them they might sell it to you.
Old Feb 17, 2011, 04:43 PM
Madison, MS
Joined Oct 2006
Thanks!
i just eyeballed it from pics of the premier vector unit. i set ou to build one as cheap as possible with parts from the LHS and hardware store. couldn't tell you many dimensions right now as i'm out flying a trip. i do know that the gimbal ring is a sliver of 4in pvc i cut with a hacksaw and sanded. servos are hs-82mg's and the frame joints are tacked in place with ca glue, coated with 30min 2-ton epoxy, wrapped each joint with a strip of 3/4oz fiberglass cloth and then wrapped each joint with kite string and another coat of epoxy. SUPER Strong joints thus far.
Old Feb 17, 2011, 08:04 PM
IFLYOS is offline
Find More Posts by IFLYOS
14s 180mah should be enough...
IFLYOS's Avatar
United States, NC, Pfafftown
Joined Feb 2001
How are the HS-82's holding up to the gyroscopic forces? I wanna build a RC kite as well, and I have a Box Delta in my kite collection just begging for a power system...
Tim
AG4RZ
IFLYOS is offline Find More Posts by IFLYOS
Latest blog entry: Intro..a few years to late!
Old Feb 18, 2011, 12:31 AM
flattermann is offline
Find More Posts by flattermann
check the crazyplanes ...
flattermann's Avatar
Germany
Joined Dec 2006
@rcrich:
As far as I know, there are 2 sources for gimbels without and with power unit frames::
A. Reiser of www.vektor-technik.de sells a high-end carbon-plate or glassfibre-plate gimbel set only. Could be used for Foamies as well as for rc-vector kites.
PremierRC www.premierrc.com also sells the power unit frame and gimbel of their GEN. I and GEN. II Vector units only.
@ IFYLOS: In general, metal gear (titanium/alloy, brass) servos with ball bearing are first choice.
For Vector units up to 1000grs. of thrust the 'Mini Servo' class of around 15grs. weight and 2kgs/cm power is sufficient.
If BL-motors of more thrust are used (1000-1500grs. of thrust), the 'Park Servo' -metal gear class with 3kgs/cm power is O.K.
Carbonite- or plastic gear is not enough shock resistent, if once the vector unit contacts the ground directly.
flattermann
flattermann is offline Find More Posts by flattermann
Old Feb 23, 2011, 12:56 AM
Madison, MS
Joined Oct 2006
from now on i will post updates in the original thread since it has now been moved to the rc kites forum.
http://www.rcgroups.com/forums/showt...1340992&page=2
new videos uploaded
For Sale Freewing F-35 Retracts, Thrust Vectoring Nozzle(reduced), and Parts!!! Kevin Greene Aircraft - Electric - Jets (FS/W) 5 Aug 06, 2011 12:32 PM
Discussion Thrust Vectoring Kite dpowellmeii RC Paragliders and Kites 54 Mar 08, 2011 11:47 AM
Discussion thrust vectoring? mudbutt Flight Accessories 0 Oct 06, 2010 11:18 PM
Discussion Thrust Vectoring Fun jet wingletts stall fences SFG'S ?? garrcass Modeling Science 3 Sep 12, 2010 03:16 PM
Question how many use/want to use thrust vectoring in IR? nemoskull Scratchbuilt Indoor and Micro Models 2 Sep 12, 2010 01:21 AM
