| Thread Tools |
| This thread is privately moderated by Quagga, who may elect to delete unwanted replies. |
Nederland, Noord-Holland, Krommenie
Joined Nov 2010
Build report: MIA S-300 kit - Nine Eagles Bravo III
Nine Eagles coaxial disassembly: Bravo III
Remove fuselage by undoing screws and separating halves Some joints are glued. I opened mine the fun way - crashing! Remove LED wires from circuit board (cut or solder) Undo screws to remove lower gear, inner shaft and upper rotor . Pry off press-fitted upper gear. Pull outer shaft upwards to free from bearings. Pull press-fitted landing gear off frame. Collar should be fitted with the raised edge facing down, on the bearing. A gap should be allowed between upper and lower gear. I'm not sure how the inner-shaft key should fit in lower gear! I have the one screw all the way in and the other only half Fitting the MIA S-300 kit Cut parts from frame with sharp scissors or knife. Sand rough edges and assemble with CA according to instructions. Fit landing gear with o-rings to stabilise frame for glueing. Liberate the battery connector and gain useful material. Glue battery connector to frame. Assembled with new inner-shaft and swash plate. Glue adjustable front mount in foremost position, filed down to clear servo gear. Glue recycled landing gear to main frame to mount canopy and frame. Done! Presenting the Bravo III S300. Glue elastic band to inside of canopy. Add 5mm of soldering wire for stability. Initial impressions:
| Thread Tools | |
| Question NE Bravo III owners | kablegod | Coaxial Helicopters | 4 | Jan 20, 2011 02:28 AM |
| Discussion Differences between Bravo III and Bravo SX | bunger | Coaxial Helicopters | 5 | Jan 15, 2011 02:40 AM |
| Discussion Nine Eagles Bravo III BNF? | dwholler | Coaxial Helicopters | 3 | Jan 03, 2011 01:55 AM |
| Discussion More durable 4 channel than Bravo III? | tigereye | Coaxial Helicopters | 14 | Dec 26, 2010 09:43 PM |
| Discussion Axe CX Nano vs NE Bravo III | cccpull | Coaxial Helicopters | 2 | Dec 22, 2010 05:52 PM |
