Old Oct 26, 2011, 02:02 PM
I Like Deraring
jdog83's Avatar
Canada, ON, Guelph
The weakest part on the plane IMHO is the horizontal stab. The rest of the plane is epp which takes a beating, and glues well with a little CA. I thought about putting the guts in something else, but to be honest I think it's a good airframe, very stable.
jdog83 is offline Find More Posts by jdog83
Old Oct 30, 2011, 12:19 PM
RTF only for now!!!
Greg_Vincent's Avatar
Jacksonville, FL
Joined Mar 2007
Both Toys R Us and K-Mart have the Hawk Eye Blue Sky on sale for 49.99. K-Mart requires a coupon, TRU does not.
Greg_Vincent is offline Find More Posts by Greg_Vincent
Old Nov 19, 2011, 11:25 PM
Joined Nov 2011
Blue Sky mods?
Hi,
I bought the Blue Sky as well and think it's great, but it didn't seem that stable to me, especially for a video camera plane. Not complaining though, all Air Hogs are extremely light weight. I love this plane! A great deal for $60. The most stable platform I think is the delta wing Jet Set, the one with the props set in slots in the wings similar to the Blue Sky design. That airframe is what this camera and controls should be built into.
Right out of the box, Blue Sky does porpoise quite a bit, so I performed a mod I do on all my Air Hogs and was pleasantly surprised at the stability increase. Still I think the swept forward wing-tips have to go. Any modders out there start cutting into the Blue sky yet?
The videos are .avi files. What's the best way to post them on this forum?
EPPwunderkind is offline Find More Posts by EPPwunderkind
Old Nov 19, 2011, 11:56 PM
turaboy's Avatar
USA, VA, Centreville
Joined Jan 2003
Please post the anti-porpoising mod, that's one of the big things that's stopped me from picking this up.
turaboy is offline Find More Posts by turaboy
Old Nov 20, 2011, 09:26 AM
I Like Deraring
jdog83's Avatar
Canada, ON, Guelph
I only fly mine when there's absolutely no wind, I found the wind makes it porpoise quite a bit... It's quite manageable with no wind. Not to mention smooth video.
Old Nov 20, 2011, 06:42 PM
Joined Nov 2011
Anti-porpoise mod
OK, first the disclaimer: This works for my plane. I posted before and after-mod video clips to show the effect of the mod and the basis from which it achieved a change. Your results may vary, so you might want to proceed with incremental adjustments. I say this because I noticed Blue-Sky flight videos posted by a couple other people that looked as steady as mine after my mod. I do not know if those posters modded their planes or not so I assume there may be production differences from plane to plane. You may need more or less correction.
The mod basically brings the horizontal stabilizer more in-line with the plane of the main-wing chord, but not completely. I did it without making an adjustable trim surface to keep drag down.
You still need some "up" elevator for the plane to fly, just less of it than my plane had out of the box.
So here it is:
1) Remove the tail section. I carefully cut the glue line and tape using an x-acto knife.
2) Mark a trim line on the base of each vertical stabilizer from the leading edge point at the base to a spot on the trailing edge just a little bit up from the base.
I used 1/8 inch at the trailing edge.
3) Trim the base of each vertical stabilizer along the line you marked.
You will be cutting away a long thin triangle of foam allowing the horizontal stabilizer's trailing edge to sit lower when the tail is re-attached.
4) Re-attach tail piece back to the fuselage as before, but now it is attached at the tail's newly cut edges. I used tape in case further modding was needed. For mine it worked fine.
That's it! Good luck.
My plane still is touchy in wind so I want to "adjust" the swept forward wing-tips next.
Flight before mod:
Air Hogs Hawk-Eye Blue-Sky initial flight right out of the box (0 min 18 sec)
Flight after mod:
Air Hogs Hawk Eye Blue Sky after mod. (0 min 48 sec)
Last edited by EPPwunderkind; Nov 29, 2011 at 05:19 PM. Reason: Uploaded bigger pictures.
Old Nov 21, 2011, 01:54 PM
I Like Deraring
jdog83's Avatar
Canada, ON, Guelph
I'm sold
Originally Posted by EPPwunderkind View Post
OK, first the disclaimer: This works for my plane. I posted before and after-mod video clips to show the effect of the mod and the basis from which it achieved a change. Your results may vary, so you might want to proceed in incremental adjustments. I say this because I noticed Blue-Sky flight videos posted by a couple other people that looked as steady as mine after my mod. I do not know if those posters modded their planes or not so I assume there may be production differences from plane to plane. You may need more or less correction.
The mod basically brings the horizontal stabilizer more in-line with the plane of the main-wing chord, but not completely. I did it without making an adjustable trim surface to keep drag down. You still need some "up" elevator for the plane to fly, just less of it than my plane had out of the box.
So here it is: (thumbnails at bottom of post)
2) Mark a trim line on the base of each vertical stabilizer from the leading edge point at the base to a spot on the trailing edge just a little bit up from the base. I used 1/8 inch at the trailing edge.
3) Trim the base of each vertical stabilizer along the line you marked. You will be cutting away a long thin triangle of foam allowing the horizontal stabilizer's trailing edge to sit lower when the tail is re-attached.
Flight before mod:
http://www.youtube.com/watch?v=dGltj..._order&list=UL
Flight after mod:
http://www.youtube.com/watch?v=EefAG..._order&list=UL
Hmmm mine flies more like the first video.... But sometimes it's more smooth like the second, but not that smooth. I think I'm sold on this mod.
Old Nov 25, 2011, 09:50 PM
United States, FL, Miami
Joined Nov 2011
has anyone hacked the camera in any way yet?
danpass is offline Find More Posts by danpass
Old Dec 22, 2011, 02:45 PM
If It Works, I'll Break It
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
Just got mine today...can't wait for spring to fly it.
Jake8131 is offline Find More Posts by Jake8131
Old Dec 23, 2011, 12:50 AM
Jake8131's Avatar
Joined Dec 2010
So here it is:
Flight before mod:
Flight after mod:
Wouldn't it be easier to fit a piece of balsa wood on the tail with a slight down angle, instead of tearing the tail apart? Be like making a mini speed brake.
Old Dec 24, 2011, 09:36 AM
I Like Deraring
jdog83's Avatar
Canada, ON, Guelph
Darn
I could have traded you mine, for your helix 360! I shoulda mentioned it, I forgot about it! I only used it a few times.
Cheers!
Jdog
Old Dec 24, 2011, 09:59 AM
Jake8131's Avatar
Joined Dec 2010
Cheers!
Jdog
Darn!
Old Dec 25, 2011, 09:23 AM
Machy2k's Avatar
Ft Lauderdale, FL.
Joined Jan 2007
I finally got to try my Hawkeye in light enough wind, mine definitely has a range problem.
I guess I am going to email or call Air Hogs, (once I can be calm) to see what they say about it.
I am a lot dissapointed in these guys, because as I stated in another post, They have been releasing cool planes, some really nice designs, that after the radio re-design/downgrade, well, just plain suck! if you get a bad one and most are bad simply because of lack of range...
I like how the Blue Sky box states "100' range" then "Ultimate reception", ok. then it states "Extreme Range" "2.4ghz gives you uncompromised range, signal and responsiveness for unmatched performance".
O.K. being realistic I know this is a toy grade, well toy (mine does not get the 100' and that is all I want for now) but, I cannot wait to see the blow out sales for like $15.00 so I can take them all apart and steal the cameras and batteries for other projects.
Oh, if I ever get time for other projects...lol
Petey...
Machy2k is offline Find More Posts by Machy2k
Old Dec 25, 2011, 12:15 PM
Jake8131's Avatar
Joined Dec 2010
Petey...
What exactly is wrong???? Fresh batteries in the tx...I only use Duracels.
Old Dec 25, 2011, 03:36 PM
Machy2k's Avatar
Ft Lauderdale, FL.
Joined Jan 2007
Hi Jake; Yesterday was battery testing and replacing day, when me and my friend went out, I installed fresh Duracells, I did not fly yesterday, but this morning (Merry Christmas) and it gets like 60' up and 75' away and loses signal, but at times it seems closer than that.
Maybe I have to experiment more, it has been windy, but i want my 300' back baby...
Petey...
Mini-Review Air Hogs Hawk Eye camera\video coax Heli modfly Multirotor Talk 5 Dec 11, 2010 10:57 PM
New Product Air Hogs Sky Eye - Spotted in popular science.Takes video and pictures! PICS INCLUDED forrest225 Micro RTF 46 Nov 29, 2010 05:46 PM
Mini-Review Air Hogs "Hawk Eye" camera\video coax Heli modfly Micro RTF 6 Sep 12, 2010 02:39 PM
Alert New Air Hogs at Target, Jackal (interesting) Hawk Eye, (Uhh), Rafale Machy2k Micro RTF 16 Aug 28, 2010 02:41 PM
New Product Air Hogs Hawk Eye - aerial cam nanobot9000 Micro Helis 6 Apr 27, 2010 01:14 PM
