Old Aug 03, 2003, 02:39 PM
RICH S is offline
Find More Posts by RICH S
Joined May 2000
Wattage High End ARF's?
What's the word on the Ultimate Bipe, Pitts, Cap, Edge etc. they are offering with the cobalt motors? Will they fly box stock or do you have to intall BL?
Thanks.
RICH S is offline Find More Posts by RICH S
Old Aug 03, 2003, 03:04 PM
jk is offline
jk
Find More Posts by jk
jk
jk's Avatar
Huntington Beach, CA
Joined Apr 2001
the Wattage planes are built well, but they are very heavy.
IMO, their cobalt motors are not of good quality & draw alot of amps ( inefficient).
-john
jk is offline Find More Posts by jk
Old Aug 03, 2003, 03:08 PM
fletch is offline
Find More Posts by fletch
Gulf Coast
Joined Nov 2002
I have an internet buddy who said performace was very poor with the colbalt motor (with crazy 8). He said his CrazyMAX with stock motor was much better I went with hacker b20-15 with 4:1 gearbox and very happy with performace.
regards, Fletch
fletch is offline Find More Posts by fletch
Old Aug 03, 2003, 03:21 PM
aeropenguin is offline
Find More Posts by aeropenguin
Who Says Penguins Can't Fly?
aeropenguin's Avatar
Bay Area, California
Joined Jan 2003
I have used the Watt-Age cobalt 400 super motor, and it's of very low quality. Magnets fall off, very heavy, draws tons of amps, doesn't last long, and it has a mount different than that of any motor ever - fitting a gearbox is awkward and difficult, let alone very few fit - even with modifications.....
For just a little more cash, I recommend the Promax cobalt 4014 motor. It's lighter, easier to mount and add a gearbox, uses less amps, and it definitely has a ton more oomph, especially when geared.
-Michael
aeropenguin is offline Find More Posts by aeropenguin
Old Aug 03, 2003, 03:28 PM
sgil2001 is offline
Find More Posts by sgil2001
R/C Enthusiast
sgil2001's Avatar
Craley, Pennsylvania, United States
Joined May 2001
Wattage planes look pretty, but are too heavy and never fly well stock.
sgil2001 is offline Find More Posts by sgil2001
Old Aug 03, 2003, 05:57 PM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
May be should take a look about what GWS Formosa, F4U....many new airplanes, check their cost-performance!
I remember, some one said GWS made cheap crappy products. But GWS airplanes fly pretty well!
GWS4CEO is offline Find More Posts by GWS4CEO
Old Aug 03, 2003, 06:56 PM
RacerX is offline
Find More Posts by RacerX
RacerX's Avatar
Orlando
Joined Jan 2003
Rich.
I have the Crazy 8 and the Ultimate Bipe. Stock was under powered on these planes, but with Hackers and some mods, they fly very well.
I am in the process of adding aerolons to the top wing of the bipe as it's roll rate is pretty poor. I did some mods inside which pulled some of the weight off, and made room for standard batteries. I will say that the bipe is built very well. I've cartwheeled it several times, and the worst that has happened is the LG comes off.
The build very nice planes, but yes- they are a tad on the heavy side. I believe they could have been lighter like my Tantrum, but they would probably not be half as resilient as they are now.
Steve
RacerX is offline Find More Posts by RacerX
Old Aug 03, 2003, 07:03 PM
Basketcase is offline
Find More Posts by Basketcase
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
If you're looking for a CAP or Ultimate (soon) as a home for a brushless check out www.stevensaero.com
Very high quality laser cut kits and half the weight of the Wattage planes.
BC
Basketcase is offline Find More Posts by Basketcase
Old Aug 03, 2003, 10:20 PM
Billmagann is offline
Find More Posts by Billmagann
Valencia, CA
Joined Feb 2002
Rich,
The Wattage kits are very high quality ARFs. Your view of the power systems will largely depend on what you are used to. I felt the Cap and the Ultimate flew fine with the stock motors. However, you will certainly get better performance by going brushless, which I eventually did on both of mine.
The cobalt motors are very inconsistent, and carefully breaking them in as the manufacturer suggests is a must. Even then, I had a problem with one, although I have had no trouble with 2 others I have owned.
The planes are pretty heavy. They are better suited to paved runways or packed dirt then bumpy grass. If you are going to fly the planes from rough fields you need to ditch the wheel-pants and install larger wheels.
Bill
Billmagann is offline Find More Posts by Billmagann
Old Aug 03, 2003, 10:49 PM
jk is offline
jk
jk
jk's Avatar
Joined Apr 2001
i agree with you Bill. I own 3 wattage planes (Extra 330, Super Decathalon and the Crazy 8). i use BL motors in all of them, have done a few things to make them lighter and do use larger wheels.
for more info on some of them, you can visit my website here:
http://microhelis.homestead.com/Airplanes.html
btw,
the C8 seems to be the least affected by it's weight due to it's large wing area.
-john
Old Aug 04, 2003, 02:12 AM
Foaminator is offline
Find More Posts by Foaminator
The need for speed
Foaminator's Avatar
Coffs Harbour, Australia
Joined Apr 2003
I agree with GWS4CEO, GWS planes are unbelievable value, and excellent flyers. Having had both the Wattage Reno Racer and the GWS Mustang I can say there is no comparison! My Mustang is the most realistic and exciting looking plane I have ever had, and it's very fast. My Reno Racer lasted for about ten flights before the cracks in the fuselage behind the wing become unrepairable. It now hangs on the wall as a showpiece!
Foaminator is offline Find More Posts by Foaminator
Old Aug 04, 2003, 08:34 AM
tekochip is offline
Find More Posts by tekochip
tekochip's Avatar
West Dundee, IL, USA
Joined Jul 2001
I just finished my Crazy 8 with a Super Cobalt. I think the biggest problem with the motor is that the published specs are WAY off. I'm using 2520 rpm/V, 3A idle, and .1 Ohm. This seems much closer to reality (a place I like to visit). Wattage should really correct this, and I think they'd get fewer complaints. Yes, the first motors were pretty bad, but the gold unit I have is working well so far geared at 2:1, 8X6, and 9 cells.
The construction and quality of the C8 is fantastic, and a darn fast build. A real Almost Ready to Fly.
tekochip is offline Find More Posts by tekochip
Old Aug 04, 2003, 10:58 PM
DesertRC is offline
Find More Posts by DesertRC
DesertRC's Avatar
Tucson, AZ
Joined May 2002
Eindecker
I have the Eindecker and it flys really well.
I highly recommend this plane. It is pretty beefy
but agile and slow enough for a small baseball field.
I fly mine low and slow and real close in. It's a hoot
for some relaxing flying. I really like it. It builds really fast
too. Give it a try you will dig it!
DesertRC is offline Find More Posts by DesertRC
Old Aug 05, 2003, 03:02 AM
new2heli is offline
Find More Posts by new2heli
santa clarita ca
Joined Jul 2000
JOHN,
nice job on th decathlon! i was going to use the astro 010 14 with the 3.3 gearbox. did your 3.3 bolt right on the razor?
tom
new2heli is offline Find More Posts by new2heli
What is a good high end ARF? Pookee Electric Sailplanes 26 Sep 02, 2005 05:45 PM
Any shops in socal that sell high end dlg's? Dennis Everett Hand Launch 2 Apr 01, 2004 04:51 PM
High end servo's, reciever, and some speedo's for sale Heli Slime Aircraft - Electric - Airplanes (FS/W) 0 Jul 11, 2002 11:43 PM
High end servo's, reciever, and some speedo's for sale Heli Slime Aircraft - Fuel - Airplanes (FS/W) 0 Jul 11, 2002 11:19 PM
