Old Feb 16, 2011, 09:53 AM
hardhat is offline
Find More Posts by hardhat
Joined Oct 2010
Help!
Futaba 7c 2.4 + EzUHF on a 5Ah 3S LiPo, will that work?
I would like all my ground stuff to work on two parallel 3s batteries. It's fine for the goggles, video receiver and video recorder.
But will the Futaba 7C Radio Tx also work on a 3S lipo? I want 5Ah because any less runs out too quickly with the EzUHF. And somehow it takes ages to charge the radio, always overnight! The lipo I can charge in less than an hour.
Do you need a voltage regulator? The lipo comes from 12.6V which is a bit much.. But I see HobbyKing recommending a particular 3S lipo for 'any' Futaba Tx..
http://www.hobbycity.com/hobbycity/s...idproduct=6955
I know this is a regular question here but I can't find a definite answer for my particular situation...
hardhat is offline Find More Posts by hardhat
Old Feb 17, 2011, 01:47 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Originally Posted by hardhat View Post
I would like all my ground stuff to work on two parallel 3s batteries. It's fine for the goggles, video receiver and video recorder.But will the Futaba 7C Radio Tx also work on a 3S lipo? I want 5Ah because any less runs out too quickly with the EzUHF. And somehow it takes ages to charge the radio, always overnight! The lipo I can charge in less than an hour.Do you need a voltage regulator? The lipo comes from 12.6V which is a bit much.. But I see HobbyKing recommending a particular 3S lipo for 'any' Futaba TX. I know this is a regular question here but I can't find a definite answer for my particular situation...
Batteries_Lithium Polymer - Do Not Use 3S Lipo in Transmitters
Batteries_Lithium Polymer - Do Not Use 3S Lipo in Futaba Transmitters
However, can be used with a cheap voltage "regulator" as described in second thread above or
LiPo replacement for NiMH transmitter batteries
More under
"Radio Systems, Accessories, Alterations and FAQ." at:
Alan's Hobby, Model & RC FAQ Web Links
(quick search = Ctrl+F)
Alan T.
A.T. is offline Find More Posts by A.T.
Old Feb 17, 2011, 04:00 PM
hardhat is offline
Joined Oct 2010
Yeah, i guess it is not a good idea. Will put a regulator in between.
Help! Futaba 6ex 2.4 G + Chinese 2.4 g hack module. Will it work ? bujora Radios 10 Oct 12, 2013 06:00 PM
Discussion What is a good tx that will work with msr, 4#6 and airplanes? Jameslt1TA Micro Helis 23 Jan 23, 2011 11:55 PM
Sold Futaba 7c 2.4 with Lipo Transmitter Battery bbrown2828 Aircraft - General - Radio Equipment (FS/W) 0 Dec 15, 2010 05:43 PM
Discussion 3S lipo in Futaba 7C 2.4?? ronrandle Radios 2 Jun 04, 2008 10:14 AM
Discussion 3S lipo in Futaba 7C 2.4?? ronrandle Batteries and Chargers 2 Jun 03, 2008 11:09 PM
