Old Feb 15, 2011, 05:04 PM
acobra is offline
Find More Posts by acobra
United States, IN, Vincennes
Joined Apr 2004
new to electric surging HELP
Hi Guys
I'm new to electrics and am having a problem with a power combination, it surges at high throttle. Here's what I've got. Turnigy C3536-1300, APC 10X7 electric prop, Sky Wing 60A speed control, Turnigy 3cell 2200 batt. When it is surging it is only drawing 29 Amps. Ideas?
Frank
acobra is offline Find More Posts by acobra
Old Feb 15, 2011, 07:53 PM
Forester is offline
Find More Posts by Forester
Crivitz, WI
Joined Dec 2005
Sounds like a low voltage cut off issue. Do you know what the voltage reads when the motor starts surging?
Forester is offline Find More Posts by Forester
Old Feb 15, 2011, 08:05 PM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
If you're pulling more than 30A, you should consider moving up to at least a 3000mAh pack. Ideally you should not draw much over 10C from a lipo, regardless of the C rating, especially if you want more than a 5 minute flight.
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Feb 15, 2011, 11:05 PM
speedy72vega is offline
Find More Posts by speedy72vega
United States, OR, Portland
Joined Sep 2009
As said above, checking the voltage under load will tell you alot, but could also be a timing issue. If your ESC is programmable, try med timing and see if that helps any.
speedy72vega is offline Find More Posts by speedy72vega
Old Feb 16, 2011, 03:21 PM
acobra is offline
Joined Apr 2004
OK so i checked the voltage under load with the motor surging and it's 11.45V
Old Feb 17, 2011, 08:41 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
The prop is too big.
Other users reports-
APCE 10x5 = 34A
9 1/2 x 6 gas prop = 35A
APC 9x6sf on 2s lipo= 21amps
APC 10x4.7sf on 2s lipo= 21 amps
APC 7x5e on 3s lipo= 13 amps
Same prop on 2s= 9 amps
APC 8x4e on 3s lipo= 13 amps
Same on 2s = 9 amps
That 10x7 appears to be just too much prop for the motor and pack.
Try a smaller prop.
hoppy is offline Find More Posts by hoppy
Old Feb 17, 2011, 12:50 PM
acobra is offline
Joined Apr 2004
I dropped the prop to a 9X3.8 and no surge and lower readings over but, OK now I'm really confused (or just stupid) Here is the setup and full throtle readings on the park Zone Wildcat that I flew last fall with great results. Most flights around 7 min. medium throttle. Turnigy 3536-1100, Turnigy 3c 2200 APC slowflier 10X7 Mystrey 40A SBEC. the readings are 572.3Wp, 1.6Wh, 51.75Apand 10.62Vm. Battery or ESV never got hot (just warm) Thesr readings are all higher that the ones I getting now and that combination never surges and works fine. I know at full load I'm pushing the 40A ESV and that is why I went to the Sky Wing 60A ....so ???????
Frank
Old Feb 17, 2011, 03:39 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
I'm confused also. You're talking about 2 different motors and setups , right? A 35-36/1300 and a 35-36 1100 with APC10x7E and a APC10x7SF prop? Are you also talking about 2 different batteries?
Running the 35-36/1100 on a 10x7SF is again over the top. The motor is rated for 35A for 30sec and you've got it set up for a 51A draw? The APC SF props are notorious amp hogs.
IMO, it should be set up for a 35A draw at full throttle.
In answer to your question, are you talking about the same battery pack? Did you store it over the winter fully charged? In any case, the pack you were using with the Wildcat was in better condition than the one used in post #1. The pack being used with the set-up in post#1 just couldn't provide the power needed with that 10x7 prop.
Old Feb 17, 2011, 07:02 PM
acobra is offline
Joined Apr 2004
2 different set ups yes. I stored the pack for plane #1 over the winter in the "storage mode according to my charger then full charged it one time before using it on plane #1. The very same battery was used to get the numbers for the Wildcat without any additional charging i.e. did one plane then switched the battery right away to the other and took the readings. If the APC props are amp hogs what do you recommend?
Old Feb 17, 2011, 08:17 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
APC-E
GWS-HD or DD
For the level of watts you're talking about, the APC-E props would be my choice. An APC-E 10x7 will draw about 25% less current than an APC-10x7SF.
So, you're saying on the first test the ESC/motor choked on 29A but right afterward, ran another setup at 51A.
That is a puzzler - one explanation - the pack warmed up after the first run which made it able to produce more current. I probably wouldn't bet on that idea but it's a possibility.
Or one ESC has a higher LVC setting than the other.
Old Feb 18, 2011, 08:24 AM
acobra is offline
Joined Apr 2004
No, the first test was on the new setup I'm trying to figure out (Airplane #1) the second was on the widcat I flew all last year I just used the same battery on each one to eliminate a vairiable. I'm beginning to suspect the speed control (programing?) so I'll do some more test today
Old Feb 18, 2011, 08:59 AM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Let's see if we can get on the same page.
This is a test you just did, right?
And then you took the battery used for that test and immediately ran this test?
If not, what was the sequence and results?
Old Feb 19, 2011, 08:06 AM
acobra is offline
Joined Apr 2004
Correct, that was the tests and the sequence.
Old Feb 19, 2011, 01:13 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
The results, 29A and 11.45V for Setup #1 may be misleading.
During surging, the LVC is cutting the motor power and the these measurements are at the LVC reduced power level.
Found an interesting chart on your motor. http://www.rcflights.com/fly2air/tdm/C3536-1300.gif
Look at the 9x7.5 APC electric prop data.
Full throttle with a 3s is 26A with a voltage of 9.43V.
Now put a 10x7 APCE prop on there and 2 things will happen.
Amps will increase significantly and voltage will drop. This looks in line with the results you obtained. I would guess that the voltage drop would be well into the LVC range.
The question now is how high would the A go with a pack that could provide the current without dropping voltage so the LVC kicks in. Your test#2 data suggests that it would be above 51A.
In both cases, I would suggest reducing the prop size till the max draw at full throttle is below 35A.
And a chart for the 1100 motor.
http://www.bungymania.com/imageshome...erf1.php?id=79
Old Feb 19, 2011, 07:35 PM
SargeNZ is offline
Find More Posts by SargeNZ
Dizzying Heights
SargeNZ's Avatar
New Zealand, Southland, Invercargill
Joined Feb 2003
It could be a timing issue rather than a LVC issue.
SargeNZ is offline Find More Posts by SargeNZ
Discussion Windsong electric conversion radio programming help for electric sailplane marcv Electric Sailplanes 13 Jan 29, 2011 05:49 PM
Discussion New to electric, need help edgetorker Electric Plane Talk 12 Jan 06, 2011 07:39 PM
Discussion Need Help Understanding Electric Motor Specs AdamChicago Electric Plane Talk 12 Sep 22, 2010 10:37 AM
Discussion Weird Surging Problem on New ESC... Captain Carlton Hacker Brushless 1 Mar 17, 2008 12:48 PM
??VIP Motor surging, Please Help?? jeremysm High Performance 17 Jan 04, 2005 02:26 PM
