Old Aug 03, 2003, 09:43 AM
FX1SUB is offline
Find More Posts by FX1SUB
Green Member
FX1SUB's Avatar
NJ
Joined Mar 2002
How come there are no wooden props in E-flight?
Is there a specific reason? they seem as light as the plastic props and the wood grain looks nice on a prop. Just curious why we don't use them or why they're not manufactured for E-flight.
Joe
FX1SUB is offline Find More Posts by FX1SUB
Old Aug 03, 2003, 10:42 AM
Vonbaron is offline
Find More Posts by Vonbaron
Plane hugging cat
Vonbaron's Avatar
Mackay Queensland Australia
Joined Sep 2001
I use em but prefer the new composite props. I find they are lighter than the nylon/glass props but tend to break very easy on a nose over etc.
Vonbaron is offline Find More Posts by Vonbaron
Old Aug 03, 2003, 10:43 AM
R101 is offline
Find More Posts by R101
R101's Avatar
Scotland
Joined Apr 2001
I use Master Airscrew Electric wooden props all the time as I expect many others do - great props, and not as brittle as the APCe.
R101 is offline Find More Posts by R101
Old Aug 03, 2003, 11:22 AM
FX1SUB is offline
Green Member
FX1SUB's Avatar
NJ
Joined Mar 2002
Looks like the smallest electric wood series by MA is 10x6. Is this the only manufacturer of Electric wood props?
Old Aug 03, 2003, 06:32 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Yes, they are the only maker of specific-for-electric wood props. Two other glow types that work well, but are, so far as I know out of production, are the Reve-Up brand, especially their four-stroke series, and the BY&Os.
BEC is offline Find More Posts by BEC
Old Aug 03, 2003, 07:13 PM
MKH is offline
MKH
Find More Posts by MKH
MKH
Ohio
Joined Mar 2000
The Master Airscrew wooden e-props are great, but like the plastic Slowfly props, they loose efficiency very rapidly as the rpm increases. For low rpm use, they put out alot of thrust. Anything above 5-6000 rpm and I'd go to the APC-e props, as they are designed for the higher rpm and perform much better. Rev-ups work well too, especially if you thin the blades, but its alot of work.
Marcus
MKH is offline Find More Posts by MKH
Old Aug 03, 2003, 07:23 PM
raptor22 is offline
Find More Posts by raptor22
Striving to Rip the Bring
raptor22's Avatar
San Diego, socal, USA, North America, Earth, Solar System, the Orion arm, Milky way, Universe
Joined Apr 2003
I just like the apc-e props; the performance rocks. Why does it matter if the apc is better anyway?
raptor22 is offline Find More Posts by raptor22
Old Aug 03, 2003, 11:14 PM
Flybyguy is offline
Find More Posts by Flybyguy
Go Giants!
Flybyguy's Avatar
San Mateo, California, United States
Joined Jun 2002
Would you recommend a wood prop for an EPS-400c with E gear?
If so, what pitch and diameter?
Brian
Flybyguy is offline Find More Posts by Flybyguy
Old Aug 04, 2003, 02:36 AM
Richard ll is offline
Find More Posts by Richard ll
Fe Fi Fo Fum
Richard ll's Avatar
Useless Loop, Australia
Joined Apr 2001
Brian
Try this site for specs on the 400C motors-For your motor there are several choices from 9*7 to 12*8-(these specs are for GWS props-so may be different for stiffer-ie wood props).
http://www.aircraft-world.com/prod_d...em/eps400c.htm
Cheers Rich
P.S wait till all twelve pages load-plenty of specs to wade through
Richard ll is offline Find More Posts by Richard ll
Old Aug 04, 2003, 12:50 PM
guyaneze is offline
Find More Posts by guyaneze
guyaneze's Avatar
gainesville FL
Joined Jan 2002
flybyguy: i just waded thru some of that 400c e gear info....it all depends on what batteries u have....or are willing to buy...and what kind of performance u are looking for....
guyaneze is offline Find More Posts by guyaneze
Old Aug 04, 2003, 12:59 PM
Flybyguy is offline
Go Giants!
Flybyguy's Avatar
Joined Jun 2002
Well, it is an AP platform, so I am not going to be flying real slow, the plane is about 30% over the recommended weight. I have an 8x1100 HECELL 2/3A pack, and an 8x1600 NiMH AA pack. I am considering buying a 9 or 10 cell KAN 1050 or 1300, as well as a Thunder Power 3s2p 1200 or 2100 pack. I am looking for a prop that will give me plenty of thrust but also some speed, so I can get up high fast, I am using the GWS ICS-480, which is I believe 15, maybe 20 amps.
Brian
Discussion How come there are no cheap 400 size inrunners? hallstudio Power Systems 15 Oct 14, 2006 09:36 PM
Help! How come there are no Canadian Depron suppliers? iam Foamies (Kits) 13 Mar 30, 2004 09:36 PM
Just getting started in E Flight Reaper802 Beginner Training Area (Aircraft-Electric) 2 Jun 08, 2002 05:30 PM
getting my brother started in E-flight JCV Parkflyers 7 Jan 06, 2002 07:27 PM
Boat Props for E-Flight! Dave Hederich Racing Boats - Electric 0 Jan 03, 2002 06:56 PM
