Old Oct 15, 2012, 12:12 AM
vtol fan
nadine's Avatar
Joined Jul 2009
Deleted.
nadine is offline Find More Posts by nadine
Old Oct 22, 2012, 08:28 AM
YXmotor's Avatar
RPC
Joined Oct 2008
Hello folks here,
We did some improvement on our 13g contra-rotating motor these days, one motor mount and one prop adapter was added, it will be easier for mounting the motor on the plane and installing the propellers.
Thanks and Best Regards!
Attached are the pictures:
YXmotor is offline Find More Posts by YXmotor
Old Oct 25, 2012, 01:17 AM
Lantsov Alexey's Avatar
Russian Federation, Saint Petersburg, St Petersburg
Joined Jan 2009
The coaxial system, differential type , ready.
Weight system, with motor 22-2.5/37 is 14.2 grams.
Lantsov Alexey is offline Find More Posts by Lantsov Alexey
Old Oct 26, 2012, 08:36 AM
slow but inefficient
Ron Williams's Avatar
Riverhead NY USA
Joined Dec 2000
So the O-rings are the gears in the differential? Brilliant!
Ron Williams is offline Find More Posts by Ron Williams
Old Oct 27, 2012, 02:53 AM
Vladimir88's Avatar
Joined Mar 2010
Alexey, congratulations!
Great idea and realization!
I believe that the presence of a electric rotating contacts in coaxial system completely kills the idea brushless motors.
You managed to get rid of it, but at the cost of the additional structural element-differential.
This element, though, and performs a necessary function of the opposite rotation, but from an energy point of view is the ballast.
That is, the extra weight does not give additional thrust.
In my opinion most promising idea is to system in Post # 107.
This idea is very simple, in a constructive sense.
The simplest design is usually the most reliable and efficient.
Here there is no unnecessary contact, no ballast by weight, no friction loss in differential.
But the problem is that for coaxial system with weight of about 14...15 grams, requires two motors with greater diameter of the rotor and stator with a lot of poles that can work with a 8...10-inch props and their weight should be about 6...7 grams.
This motor so far not, that's the problem.
But for a coaxial system with a weight of more than 22 grams is no this problem.
Vladimir88 is offline Find More Posts by Vladimir88
Old Oct 29, 2012, 03:14 AM
Kimmo Kaukoranta's Avatar
Tampere, Finland
Joined Apr 2004
Alexey and David, great job both of you! Nice to see what started as a crazy idea being adopted by so many and in different variations!
Alexey, I did not quite understand what was the problem with the co-runner, can you explain further? In our first protos, there was a small issue that while hovering, the torque would most of the time be very close to zero, however sometimes the plane could torque to left or to the right. The this seemed to vary. We thought it could be just down to the manufacturing accuracy, which on ours was not that great. Is this what you experienced?
The friction drive differential is very interesting, should be very quiet. I did not really understand the first hand drawn picture, but the photos make it clear.
Is the rod with the ball bearings on the ends free to rotate on the carbon shaft? I did not see any ball bearings between that and the carbon shaft. If it’s fixed, both props will turn the same RPM in opposite directions. If it’s free to rotate, it should function as a differential, right? Anyway very interesting idea, looking forward to hearing how it works and seeing the video!
Kimmo Kaukoranta is offline Find More Posts by Kimmo Kaukoranta
Old Oct 29, 2012, 08:41 AM
Joined Jan 2009
Hi Kimmo, and all guys.
Your idea to brush coaxial have a reduction of 1:2.
This is very good. you can put a large propeller.
But there is a loss of electricity and friction in the brushes.
In any case, my plane is flying 4 minutes at 120 mA acc.
It is more than necessary.
I hope the video of my system, make clear the work of a differential system.
Дифференциальная система (0 min 0 sec)
Old Nov 01, 2012, 06:50 PM
http://roys-rc-tv.webs.com/
Basingstoke Roy's Avatar
United Kingdom, England, Basingstoke
Joined Oct 2005
That's a fantastic piece of engineering; the gear box arrangement is just brilliant
Basingstoke Roy is offline Find More Posts by Basingstoke Roy
Old Nov 03, 2012, 03:48 PM
Neil Stainton's Avatar
United Kingdom, England, Stratford-upon-Avon
Joined Feb 2001
Brilliant engineering guys, well done all.
I realise this question is a little off-topic, but why use two co-axial contra rotating props? Why not mount two conventional motor/props on the wings, rotating in opposite directions, like many full size twin motor lightplanes? This will solve the torque and P factor problems, and the greater swept prop area will probably result in a more efficient powertrain too.
Neil.
Neil Stainton is online now Find More Posts by Neil Stainton
Old Nov 03, 2012, 04:32 PM
Inspired by the wings of an An
Andycap's Avatar
Leeds
Joined Mar 2003
Neil.
Tiny differences in each motors winding / efficiency and prop differences will result in unwanted yaw at different throttle settings. Also the added weight outboard of the centre line will give more unwanted roll inertia
Andy
Andycap is offline Find More Posts by Andycap
Old Nov 03, 2012, 05:33 PM
Joined Feb 2001
This is also true for all the dual motor co-axial solutions. The brushed single motor solutions have brush drag to contend with, so I think the only truly zero torque solution is Alexey's "differential" design.
True. But with lightweight geared motors mounted only 10 cm (4") from the centre line, this may not be a big deal.
Neil.
Old Nov 04, 2012, 12:27 AM
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Neil.
Hi Neil,
I assume any effect from "brush drag" will be negligible.
The smallest difference in thrust on a twin model however will become very noticeable at low speeds, even with the prop axis just 8" apart. Considering a complete wing structure weighing only 20 to 25g, even light motors would increase wing inertia noticeably - the last thing you need on a vertical downline with two quarter rolls.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Nov 04, 2012, 01:39 AM
Professional idiot
Hampshire, UK
Joined Jun 2002
All that weight outboard on the wings would not only ruin the flight performance as Jurgen has mentioned but the added engineering to mount even the lightest of motors rigidly would add even more complexity & weight.
Dave
wildpalms is offline Find More Posts by wildpalms
Old Nov 04, 2012, 02:44 AM
Andycap's Avatar
Leeds
Joined Mar 2003
With the motors only 4" from the centreline we could probably only run 5" props too. Dont forget we have the horizontal fuselage still to deal with Even without the motor forces mounted on the nose it would till need to be around 2.5" at the L.E. of the wing to make the fuselage suitably strong
Old Nov 04, 2012, 05:15 AM
Joined Jan 2009
Нi Neil. Two engines on the wing be problems .
So as , to be weak flow to the rudder.
Build Log EPP f3P Plane tallflyer SDPARKFLYERS 14 Feb 28, 2012 02:32 PM
Discussion The New Phantom F3P Plane by Budgetrc.com tallflyer Foamies (Kits) 8 Jun 04, 2011 12:37 PM
Question Very slow indoor plane - F3P or??? Petrik59 Foamies (Scratchbuilt) 2 Dec 31, 2010 06:03 AM
Discussion Galaxy F3P Review, hobbyking plane dhdsracer Electric Plane Talk 0 Dec 17, 2010 09:45 PM
Discussion Another full scale electric plane Bob Chiang Electric Plane Talk 5 Sep 09, 2010 09:20 PM
