Old Sep 04, 2012, 03:49 PM
jan scholten is offline
Find More Posts by jan scholten
jan scholten's Avatar
netherlands
Joined Oct 2001
Glavak CR pictures
some detail pictures. the brushes are lifetime guaranteed, testing this motor for over 50 hours at once was no problem.
Description:
Description:
jan scholten is offline Find More Posts by jan scholten
Old Sep 05, 2012, 05:27 AM
Kimmo Kaukoranta is offline
Find More Posts by Kimmo Kaukoranta
Kimmo Kaukoranta's Avatar
Tampere, Finland
Joined Apr 2004
That seems to be built after Kimmo Kaukoranta's Co-runner principle/idea. I bet this is one of the prototypes Kimmo is talking about above.
Yes, it's one of them, I saw a couple of photos of it earlier.
Compared to the first co-runners we built, the motor seems to be reversed which makes attaching it to the plane much simpler. Hard to see from the photo, but I'm guessing the stator is attached to the inner shaft driving the front prop and the rotor is driving the rear prop, opposite to any "normal" outrunner? It's a very interesting system, looking forward to seeing it in action.
About the brushes, since it's a constant connection, not intermittent like the commutator on a brushed motor, the lifetime of the brushes should be quite long.
Kimmo Kaukoranta is offline Find More Posts by Kimmo Kaukoranta
Old Sep 05, 2012, 05:34 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
I am even more interested in "hearing it in action", because without the reduction gears of the twin motor setup, it should be a lot quieter.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Sep 06, 2012, 02:02 AM
Joined Sep 2000
Originally Posted by jan scholten View Post
... the brushes are lifetime guaranteed, testing this motor for over 50 hours at once was no problem.
Actually, Sergej and Alex have run the unit for over 200 hours on a teststand - without a problem.
Jürgen
Old Sep 08, 2012, 01:46 PM
Andycap is offline
Find More Posts by Andycap
Inspired by the wings of an An
Andycap's Avatar
Leeds
Joined Mar 2003
If the performance and quality is anything like the Standard Glavak motor I suspect we will see a good number of top european pilots flying this setup.
Andycap is offline Find More Posts by Andycap
Old Sep 23, 2012, 11:32 AM
Lantsov Alexey is online now
Find More Posts by Lantsov Alexey
Lantsov Alexey's Avatar
Russian Federation, Saint Petersburg, St Petersburg
Joined Jan 2009
Kimmo thanks for the idea.
Started making coaxial system.
Here you can see everything you need to build.
Lantsov Alexey is online now Find More Posts by Lantsov Alexey
Old Sep 25, 2012, 02:51 AM
3Don is offline
Find More Posts by 3Don
3Don's Avatar
Joined Nov 2004
Hey guys, here is Glavak system in use:
New Coaxial system tested on "Anubis". (6 min 24 sec)
I will build new light plane and test Kimmo system in lighter application, then it will be fair to compare. In any case both systems give obvious advantages for F3P planes. I think in very near future it will become standart in hi level F3P competition.
3Don is offline Find More Posts by 3Don
Old Sep 25, 2012, 11:09 AM
Free is online now
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
WOW, that is slow on the down lines!
Free
Free is online now Find More Posts by Free
Old Sep 25, 2012, 11:51 AM
Andycap is offline
Andycap's Avatar
Leeds
Joined Mar 2003
Downlines are very impressive as is the power available
The Glavak products really are superb quality, better start saving
Old Sep 26, 2012, 03:52 PM
Glavak is offline
Find More Posts by Glavak
Joined Sep 2012
Hi together
At first we would like to introduce ourself. We are Sergej & Alex Glavak and come from Germany. The one or other pilot from the F3P scene know us.
Since we saw the first coaxial concepts for F3P from Kimmo and Fabien we decided to develop an own concept. We would like to introduce our coaxial system and share our knowledge/experience which we collect during the development. Maybe the one or other guy can use it (like us: we were also glad to found some first experience from Kimmo and Fabien). Thank you guys for that!!!
The idea was to create a coaxial system with following technical requirements:
1) low noise emission
2) high reliability
3) compact construction
4) enable a quick and easy exchange of propellers
5) enable a quick and easy exchange of the motor
6) low weight
The result of the requirements low noise emission/compact construction are the unusual propellers with a V-form.
We read the report from Kimmo about the optimal distance between contra rotating props and the optimum was: R(radius of prop)*0,35 = optimal distance between props. After a theoretical analysis "the formula says -> less radius = less distance" the idea of V-form propellers was born (and thus the first difficult part of this coaxial system ;-) ).
To develop a coaxial motor with low weight as possible the only opportunity was to choose the idea actio=reactio (rotating stator and rotor of a brushless engine). The result is that you have to use brushes to realize the electrical contact for the stator (and thus the second difficult part of the this coaxial system ;-) ). The next difficult point is to make a symmetrical and tidy motor winding to prevent unbalance of the stator. We also balancing the stator and rotor at the end to prevent unbalance of the rotating parts.
The result of the point high reliability/enable a quick and easy exchange of the motor was
1) the construction of a brush holder which is pivoted at the axle of the stator. This solution allows that the motor is autonomous from the plane. We are very proud of the solution with the brush holder because we have never seen something like that.
2) that we use silver-carbon brushes and slip rings of silver
Silver has very good electrical conductivity and is used for electric parts with low voltage and current. The second advantage of silver is that it does not oxidize in air so you are every time sure that the contact between slip ring and brush exist (it is not really a problem if you run the engine every day but if you do not use the engine for a longer time the slip rings can oxidize). We tried also bronze-carbon and carbon brushes and the difference (efficiency) to the silver-carbon is very high.
The diameter (4,3mm) of the slip rings was chosen as small as possible because to reduce mechanical wear of the slip rings and brushes.
3) that we made a cross mount to mount the motor at the plane.
The mounting of the engine is also standard (mounting diameter 30mm, like our normal engines, AXI .... ).
4) that both props have an prop saver
@ data of the coaxial system:
- weight: 16,5 g (only engine, without o-rings (0,3g))
- weight: 25,5g (engine, 2x o-ring, 2x prop=2x4,0g)
- prop size: 10"x3.8" (wide blade props, widest part 26,5mm)
- for planes less than 140g fly weight
- only on speed controller
- for 120mAh battery (for planes with 140 g flyweight better 180-240mAh)
- mounting size diameter 30mm (like the 12g engine)
- lifetime test at brushes 200 hours (100 hours without props and 100 hours with props) -> 4000 flights per 3 minutes (without problems)
- 900 Rpm/V
some test data: (120mA battery, 10" props)
thrust current voltage
100g 1,5A 7V
120g 2,0A 7V
160g 3,2A 7V
220g 5,0A 7V
dimensions
length 56mm
diameter (mounting cross) 35mm
diameter (engine) 22,2mm
As you can see the weight of the motor is only 16,5g (thats not much we think). The big 10" props weight together 2x4g=8g. The result of the V-form it that you have side forces (centrifugal-forces) which reduce the distance between the props. There is no problem to make the props very light (3-3,3g like Kimmo´s) but because of the V-form I have to make them stiffer and that means additional weight of 2x1g=2g. However, we think this additional weight is worth if you can reduce the noise of the engine. The speed of the props is limited at 7000 1/min
The first small series was the first step of our development. We want to wait at first at the feedback of the pilots/ results after the EIAC 2012 in November (DMFV competition) and than decide if some design changes are necessary and make a decision of a bigger series.
As you see the motor has a lot of power. The decision to make a motor with more power was that the planes will be bigger (more weight) and that planes with a coaxial system have more weight.
We plan to develop a variant of this coaxial system for planes with a weight of 100g. This variant should be lighter more efficient (lower RPM/V value).
If there are more questions about details of the coaxial system feel free to ask us.
@ forum or personally @ glavak@gmx.net
of course some pictures ;-)
Description:
Description:
Description:
Description:
Description:
Description:
Glavak is offline Find More Posts by Glavak
Old Sep 26, 2012, 03:54 PM
Glavak is offline
Joined Sep 2012
Description: Name: DSC_3561.jpg
Description: Name: DSC_3571.jpg
Description:
Old Sep 26, 2012, 04:07 PM
Free is online now
Free's Avatar
Joined Jan 2012
BEAUTIFUL! Thanks for the explanation.
How much will you be selling it for?
Free
Old Sep 26, 2012, 04:17 PM
Glavak is offline
Joined Sep 2012
Price_list_6.2_2012
Old Sep 26, 2012, 04:59 PM
Free is online now
Free's Avatar
Joined Jan 2012
*Long whistle*
Old Sep 26, 2012, 06:41 PM
ChrisBowker is offline
Find More Posts by ChrisBowker
RC Bum 4 Hire
ChrisBowker's Avatar
United States, NM, Albuquerque
Joined May 2004
Alex and Sergej; thanks for sharing the pics and info on the new set up, I will defiantly be getting the coax system as soon as you will sell me one.
Chris
ChrisBowker is offline Find More Posts by ChrisBowker
Build Log EPP f3P Plane tallflyer SDPARKFLYERS 14 Feb 28, 2012 02:32 PM
Discussion The New Phantom F3P Plane by Budgetrc.com tallflyer Foamies (Kits) 8 Jun 04, 2011 12:37 PM
Question Very slow indoor plane - F3P or??? Petrik59 Foamies (Scratchbuilt) 2 Dec 31, 2010 06:03 AM
Discussion Galaxy F3P Review, hobbyking plane dhdsracer Electric Plane Talk 0 Dec 17, 2010 09:45 PM
Discussion Another full scale electric plane Bob Chiang Electric Plane Talk 5 Sep 09, 2010 09:20 PM
