Old Nov 17, 2011, 04:01 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by Kimmo Kaukoranta View Post
Hi Jürgen,
Last winter Janne used a geared single motor system. That unit uses a single 5g motor to swing a 10" prop and weights 11g without the prop. This year he switched to the twin motor contra system and that is what he is currently using.
So on the above videos, in the one with last years final program, he was still using the single motor system. On the AP-13 and AF-13 videos he has the (twin motor) contra system.
Hi Kimmo,
perhaps I should have made my question clearer: Did Janne use a single motor contra system (as shown in your prototype video), or a twin motor system in the videos? Your answer however was clear enough.
The "torque-roll" in the F3P-AF schedule with direction change and a "ridiculous" k-factor of 6 (provided this does not get changed), gives contra systems an advantage.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Nov 17, 2011, 07:48 AM
Kimmo Kaukoranta is offline
Find More Posts by Kimmo Kaukoranta
Kimmo Kaukoranta's Avatar
Tampere, Finland
Joined Apr 2004
I think you mean the "co-runner" concept, with the single motor driving two props in opposite directions without any gears. That is not yet developed to the point it could be used in a light competition plane. It works, but it's too heavy.
I'm currently putting my efforts to the twin motor geared system to improve it further. The main idea is to simplify it's construction.
The ones Janne and myself are using, the one Donatas flew in the EToc and the few units I have sold have been so far built with methods not really suited for larger scale production. For example the gearbox frame consist of something like 16 small pieces. Lots of small fitting required.
I drew the frame in Solidworks in one part, and had it 3D printed in Shapeways. Actually I had the whole system printed, but unfortunately the printed gears did not last, which I was a bit afraid of. However the gearbox frame and the mount came out great. The next version will have the 3D printed frame and mount, but still uses injection molded gears, of which one is modified to a larger bore for the outer shaft. Not having to do the modification was the reason to try printing also the gears.
Here's a couple of links to my galleries in Facebook on what I have been up to lately (these should be public, so visible to everyone):
The original "hand made" version
3D design in Solidworks
3D Printed Contra, first version
3D Printed Contra, second version
Kimmo Kaukoranta is offline Find More Posts by Kimmo Kaukoranta
Old Nov 17, 2011, 11:02 PM
infinitefoamies is offline
Find More Posts by infinitefoamies
Eric Johnson
United States, NY, Northport
Joined Mar 2011
is the 3D printed gearbox lighter? also will the price be a bit cheaper? i love my coaxial unit by the way i just need a hall with a bit more height to practice down line manuevers
infinitefoamies is offline Find More Posts by infinitefoamies
Old Nov 18, 2011, 02:52 AM
Tampere, Finland
Joined Apr 2004
They are very close to the same weight (see the attached photos). There is some variation also in the weight of the props. I'm glad you like the system!
Old Nov 18, 2011, 07:56 PM
Eric Johnson
Joined Mar 2011
i think ill stick with the CF version if you are still going to be selling it
Old Nov 21, 2011, 10:28 PM
Doug Cronkhite is offline
Find More Posts by Doug Cronkhite
TimeShare
Doug Cronkhite's Avatar
United States, UT, Tooele
Joined Feb 2002
Yeah.. I'm interested Kimmo. Very interested.
Doug Cronkhite is offline Find More Posts by Doug Cronkhite
Old Dec 03, 2011, 08:41 PM
Eric Johnson
Joined Mar 2011
kimmo, how are you getting your props shiny?
Old Feb 04, 2012, 06:42 AM
Tampere, Finland
Joined Apr 2004
There was some discussion about the distance of the props earlier. I have been testing one unit that has a 10mm shorter distance between the props compared to previous ones. Distance of props is now 35mm measured from tips, 25mm shortest distance in the center of the blades. Also the rear prop is a 10x4.7, instead of 10x3.8 for both. Seems to be working fine with no problems, and the higher pitch prop on the rear increases the total power output a bit (not that I need it in a 94g plane).
I think there was a slight increase in the interference noise when bench testing, caused by the props passing each other so close. However it's not audible in the air. Also the 3D printed gearbox frame in the latest versions seems to dampen high frequency vibrations from transmitting to the plane. The previous carbon fiber frame sounds a bit louder.
I put the printed parts on sale on Shapeways, just in case anyone who has one of the units needs a spare part. Obviously they can also be used to build a similar unit by someone who knows how to make the props etc:
http://www.shapeways.com/shops/kimmoshobby
BTW. If anyone is wondering how strong is the printed frame, see (same material):
How strong is White Strong & Flexible? (0 min 20 sec)
Old Feb 04, 2012, 06:48 AM
Tampere, Finland
Joined Apr 2004
Eric, the shine to the props. The backside of the prop is against the mold, so if the mold is smooth the backside of the prop will be shiny. The front is against the plastic vacuum bag, which again has a smooth surface. I do use peel ply and breather to squeeze any extra epoxy out, but I remove that after ~10-15minutes and for the rest of the cure, the bag is directly against the laminate.
Old Apr 21, 2012, 03:35 AM
Lantsov Alexey is offline
Find More Posts by Lantsov Alexey
Lantsov Alexey's Avatar
Russian Federation, Saint Petersburg, St Petersburg
Joined Jan 2009
Hi Kimmo.
As you see my version with one motor?
Lantsov Alexey is offline Find More Posts by Lantsov Alexey
Old Apr 21, 2012, 01:29 PM
Piper J3 is offline
Find More Posts by Piper J3
Full Scale Piper Cub Driver
Piper J3's Avatar
Hinckley, Ohio
Joined Nov 2008
Originally Posted by Lantsov Alexey View Post
Hi Kimmo.
This is a very elegant design... Has this been tried successfully?
Piper J3 is offline Find More Posts by Piper J3
Old Apr 21, 2012, 04:27 PM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
Is there any reason stoping you from having one motor, a gear on the shaft of that motor, two gears attaching to that gear on the motor shaft, a short rod coming from each gear attached to the one on the shaft of the motor, and on the end of those rods, a gear, smaller that the one on the other side of the rods, that attach two two bigger gears, that in turn attach to the props? Sorry I do not have a picture of my idea, so if you do not understand my explanation, please ask.
Free
P.S. For the setup above, I would need to make something to hold it together.
Free is offline Find More Posts by Free
Old Apr 22, 2012, 07:07 AM
Vladimir88 is offline
Find More Posts by Vladimir88
Vladimir88's Avatar
Joined Mar 2010
Bearings are not suitable as a contact rotating assembly.
Resistance contact is unstable and has a very large value.
This can be seen in the video.
IMG_0073.MOV (1 min 1 sec)
In my view, promising coaxial motor without gearbox must not contain unreliable moving contact node.
Similar this -
http://www.aeorc.com/english/?gallery-57.html
http://www.cyclonemotor.net/YX-13DZ-...r_21828_0.html
Two motors are not the problem, because this increases the thrust twice.
I think that for example on the basis of two motors AX-1304N (http://www.hobbyking.com/hobbyking/s...Motor_7g_.html) it is possible to try to create a coaxial motor with weight about 12...14 grams for working with props about 8 inches.
Vladimir88 is offline Find More Posts by Vladimir88
Old Apr 22, 2012, 10:42 PM
Vladimir88's Avatar
Joined Mar 2010
I suggest the idea of ​​a coaxial gearbox with one motor.
Old Apr 23, 2012, 01:35 AM
Joined Jan 2009
Vladimir thanks for the reply.
1. your bearing to press, then measure the resistance.
2. the gearbox is problems in the red zone.
Do the gearbox at the rear.
Build Log EPP f3P Plane tallflyer SDPARKFLYERS 14 Feb 28, 2012 02:32 PM
Discussion The New Phantom F3P Plane by Budgetrc.com tallflyer Foamies (Kits) 8 Jun 04, 2011 12:37 PM
Question Very slow indoor plane - F3P or??? Petrik59 Foamies (Scratchbuilt) 2 Dec 31, 2010 06:03 AM
Discussion Galaxy F3P Review, hobbyking plane dhdsracer Electric Plane Talk 0 Dec 17, 2010 09:45 PM
Discussion Another full scale electric plane Bob Chiang Electric Plane Talk 5 Sep 09, 2010 09:20 PM
