Old Apr 28, 2011, 10:42 PM
Lantsov Alexey is offline
Find More Posts by Lantsov Alexey
Lantsov Alexey's Avatar
Russian Federation, Saint Petersburg, St Petersburg
Joined Jan 2009
I'm still trying to find the place that sells the micron film to cover http://www.freeflightsupplies.co.uk/lightweight.htm
Lantsov Alexey is offline Find More Posts by Lantsov Alexey
Old May 18, 2011, 12:07 PM
upshifting is offline
Find More Posts by upshifting
Penza, Russia
Joined Mar 2009
http://www.a2zcorp.us -> BuildingMaterials -> Covering
upshifting is offline Find More Posts by upshifting
Old May 19, 2011, 05:51 AM
Ron Williams is offline
Find More Posts by Ron Williams
slow but inefficient
Ron Williams's Avatar
Riverhead NY USA
Joined Dec 2000
Film:
http://www.homefly.com/products.asp?id=31
Ron Williams is offline Find More Posts by Ron Williams
Old Jul 26, 2011, 05:29 PM
JNovelini is offline
Find More Posts by JNovelini
Joined Jul 2011
Where can I get this style propellers (carbon fiber)?
they are manufacturing are bought or own?
Thank you and good flight!
JNovelini is offline Find More Posts by JNovelini
Old Aug 02, 2011, 05:37 AM
srl is offline
srl
Find More Posts by srl
srl
srl's Avatar
Sydney New South Wales Aust
Joined Mar 2007
I've made some props, but still have to make the aircraft.
A lot of the materials will come from HomeFly.
srl
srl is offline Find More Posts by srl
Old Aug 03, 2011, 03:16 AM
Kimmo Kaukoranta is offline
Find More Posts by Kimmo Kaukoranta
Kimmo Kaukoranta's Avatar
Tampere, Finland
Joined Apr 2004
JNovelini, yes the props are self made. The ones on the geared coaxial are laminated in a mold taken from a commercial plastic prop. The mold has the shape of the backside of the commercial prop. Instead of using a 2 piece mold, the laminate is just pressed against the mols in vacuum. The plastic of the vacuum bag makes up the second part of the mold.
The ones on the co-runner are laminated in 3 pieces (2 blades + spar/hub). The blades are glued to the hub in a jig so you get same pitch on both sides. A bit like what is done in rubber powered indoor planes, you know the wet balsa over a bottle etc, but with carbon instead of balsa. The benefit of this construction is that you can make different shape, diameter and pitch prop using the same molds. For example the ones I have made have a very wide blade for extra braking in the downlines, much wider than GWS/APC etc.
Nice pair of props srl, what size are those and how much did they end up weighting?
Kimmo Kaukoranta is offline Find More Posts by Kimmo Kaukoranta
Old Aug 03, 2011, 05:04 PM
srl is offline
srl
srl
srl's Avatar
Joined Mar 2007
Hi Kimmo
10x4 and only made of west. 13g
I will try to make some lighter with 3600 now that the weather is starting to warm up.
I have two half's of the mould of one side of the prop. So its a matter of squeezing it some more.
It will be going into a light weight Index4
Thanks for building Ideas, will keep you updated on how its going.
srl
Old Nov 07, 2011, 02:54 PM
Tampere, Finland
Joined Apr 2004
Janne got the contra system set up in his Manta v3. Here's two videos of it flying last weekend in Iittala. With sub titles so you can also learn the names of the maneuvres in Finnish
F3P AP-13 Janne Lappi (2 min 26 sec)
F3P AF-13 Janne Lappi (2 min 28 sec)
Old Nov 07, 2011, 10:55 PM
Joined Jan 2009
Hi Kimmo.
Janne before flying on a propeller as slowly and clearly.
I want to know the opinion of Janne, preferably two propeller why?
F3P-AF11 Janne Lappi, Finnish F3P Championships 2011 (2 min 38 sec)
Old Nov 08, 2011, 09:54 AM
JanneL is offline
Find More Posts by JanneL
Janne Lappi, F3A Team Finland
JanneL's Avatar
Helsinki, Finland
Joined Sep 2008
Terve, Alexey!
Before with the single prop gear reduction system the plane flew slowly enough, that was not the problem. But the torque caused by the huge propeller was a bit nasty because I had to use a little aileron on every upline to prevent the plane from rolling and in level flight or inverted flight I had to use some rudder, quite a lot in fact. Anyway it's possible to fly slowly and clearly but it required very careful compensations.
The coaxial added about 4-5g weight and I can notice it but it's still OK. The coaxial makes the plane fly very steadily and straight in every position thanks to the neutralised torque. It's a bit easier to fly maneuvers since I don't have to concentrate anymore on compensating the torque. Rolls and especially the ends of the rolls are very precise now. And I need no knife edge mixes anymore which makes knife edge maneuvers (like in the new final sequence) easier.
As for the brake on downlines, with coaxial it's as good as before with the single prop system. One thing that was maybe a bit better with the single prop system is that you always know what kind of compensation you have to do in maneuvers. Now, due to tiny breezes that always exist in halls the plane may turn slightly in some direction when for example pulling the plane onto a vertical upline. You can't know it beforehand whereas with the single prop system you can always know that you will have to use right aileron in uplines. But I don't consider it a problem, it is a rather insignificant thing. The neutralised torque is a much more considerable thing and I can say it is very nice. Based on an experience of a few practise sessions I prefer the coaxial.
Janne
JanneL is offline Find More Posts by JanneL
Old Nov 08, 2011, 05:05 PM
wingster is offline
Find More Posts by wingster
Massachussets
Joined Nov 2005
Originally Posted by Kimmo Kaukoranta View Post
This one is using 2 AP-03 outrunner motors weighting 3.25g a piece. Since there is no way to run a 10" prop direct drive with a 3g motor, gears are used. To give You an idea of the size, the diameter of the motor is around the same as the hub in a 10" GWS prop... pretty small.
http://www.youtube.com/watch?v=vErE-29IrIA
http://www.youtube.com/watch?v=8xSoNLkCf8Y
Kimmo
Hobby King has two ap-03 motors. One has a kv=7000 and the other has a kv=4200. I'm thinking you used the 4200 kv motor. Is this correct?
wingster is offline Find More Posts by wingster
Old Nov 09, 2011, 02:14 AM
Tampere, Finland
Joined Apr 2004
wingster, yes we are using the 4200kv motors.
Old Nov 13, 2011, 05:54 PM
Basingstoke Roy is offline
Find More Posts by Basingstoke Roy
http://roys-rc-tv.webs.com/
Basingstoke Roy's Avatar
United Kingdom, England, Basingstoke
Joined Oct 2005
Hi Kimmo
Sorry I've taken a long time to reply, love your simple solutions.
I really like the idea of using brushes, to get the torque reaction from the one motor. Is the brush tension critical I.e. will to much cause drag, to little losses power or cause arcing?
Roy
Basingstoke Roy is offline Find More Posts by Basingstoke Roy
Old Nov 17, 2011, 01:48 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Janne got the contra system set up in his Manta v3. ...
Hi Kimmo,
does Janne use a single motor setup, or a twin setup as shown on your Fb page?
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Nov 17, 2011, 03:48 AM
Tampere, Finland
Joined Apr 2004
Hi Jürgen,
Last winter Janne used a geared single motor system. That unit uses a single 5g motor to swing a 10" prop and weights 11g without the prop. This year he switched to the twin motor contra system and that is what he is currently using.
So on the above videos, in the one with last years final program, he was still using the single motor system. On the AP-13 and AF-13 videos he has the contra system.
Build Log EPP f3P Plane tallflyer SDPARKFLYERS 14 Feb 28, 2012 02:32 PM
Discussion The New Phantom F3P Plane by Budgetrc.com tallflyer Foamies (Kits) 8 Jun 04, 2011 12:37 PM
Question Very slow indoor plane - F3P or??? Petrik59 Foamies (Scratchbuilt) 2 Dec 31, 2010 06:03 AM
Discussion Galaxy F3P Review, hobbyking plane dhdsracer Electric Plane Talk 0 Dec 17, 2010 09:45 PM
Discussion Another full scale electric plane Bob Chiang Electric Plane Talk 5 Sep 09, 2010 09:20 PM
