Old Dec 10, 2012, 05:22 AM
Lantsov Alexey is offline
Find More Posts by Lantsov Alexey
Lantsov Alexey's Avatar
Russian Federation, Saint Petersburg, St Petersburg
Joined Jan 2009
Originally Posted by JanneL View Post
The power system is of course "the good old" coaxial system by Mr. Kimmo Kaukoranta
Kimmo and Janne.
What settings in the coaxial system?
You make the mix to the ailerons?
Lantsov Alexey is offline Find More Posts by Lantsov Alexey
Old Dec 10, 2012, 09:53 AM
JanneL is offline
Find More Posts by JanneL
Janne Lappi, F3A Team Finland
JanneL's Avatar
Helsinki, Finland
Joined Sep 2008
Hi Alexey,
yes we use aileron -> throttle mix. In torqueroll flight mode I adjust the mix so that I hover the plane with constant throttle and then start torqueroll. The height must stay the same despite the aileron input.
In normal flight mode there is a bit more mix than in torqueroll mode. I don't know how Kimmo uses this, but at least I have set the mix off at the bottom position of the throttle stick. I don't want that plane will accelerate during rolls in vertical downlines.
This helps a lot of course in torqueroll but also in rolls. Especially the rolls in vertical upline are much better because the climbing speed remains unchanged even though there are rolls.
Regards,
Janne L
JanneL is offline Find More Posts by JanneL
Old Dec 12, 2012, 02:40 AM
Kimmo Kaukoranta is offline
Find More Posts by Kimmo Kaukoranta
Kimmo Kaukoranta's Avatar
Tampere, Finland
Joined Apr 2004
I have the same mixes as Janne, both throttles increase when applying aileron, except when the throttle lever is in the low position.
In the past I also experimented with differential throttle, so applying left aileron would increase only the front prop RPM and cause a left torque, but it caused some yaw in the rolls, not good.
Kimmo Kaukoranta is offline Find More Posts by Kimmo Kaukoranta
Old Dec 12, 2012, 02:56 AM
Tampere, Finland
Joined Apr 2004
Christian, very interesting designs. I was pretty sure the co-runner idea had to be thought of by someone before us. Maybe we were just the only ones crazy enough to actually build it ;-)
The flex cable drive looks interesting, never thought of that. I guess the same could be done with two sets of bevel gears (90-degree angle drives) and straight shafts, maybe for better efficiency? It would still have just one motor. Or maybe even the quad prop design with either one or two motors in the center.
I built a similar ringless planetary gearbox earlier also from my sons's legos. The benefit is that you only need spur gears, small module ring gears do not seem to be easy to come by. The downside is that the diameter of the whole system will be larger for the same gear ratio compared to a "normal" planetary with the ring gear.
Old Dec 12, 2012, 06:12 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Hi Kimmo,
you could use a switch to activate differential throttle mix just for the torque rolls.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Dec 12, 2012, 10:15 AM
JanneL is offline
JanneL's Avatar
Helsinki, Finland
Joined Sep 2008
Originally Posted by Jurgen Heilig View Post
Hi Kimmo,
Jürgen
Hi,
Kimmo means that the problem was exactly in torqueroll and in rolls during vertical uplines. The thrust angle has been adjusted straight with coaxial system. When a differential mix is used, another of the two props accelerates more. As a result of this, the straight thrust angle is now wrong, because the torque is not anymore neutralised. In horizontal rolls it's no problem but in vertical upline or torqueroll it causes some unwanted unstability.
Janne
Old Jan 29, 2013, 01:10 PM
Joined Jan 2009
Hi .
Now I made a new version of the coaxial system downgrade.
Reduction is 1:5
Weight of 12.9 grams.
Old Jan 31, 2013, 11:17 AM
Stular is offline
Find More Posts by Stular
Stular's Avatar
Slovenia
Joined May 2006
Now THAT is thinking out of the box
Motor sideways…of course…why not...
Stular is offline Find More Posts by Stular
Old Feb 19, 2013, 11:34 AM
Joined Jan 2009
Hi Guys.
The coaxial system works !
Weight system with 7 grams of motor = 10.5 grams.
I made 2 props 10x3 and 10x3.5
The total weight of 15.2. gram.
Video system:
Lantsov coaxial system (1 min 42 sec)
Old Feb 21, 2013, 03:31 PM
frans tinnemans is offline
Find More Posts by frans tinnemans
The Netherlands, LI, Echt
Joined Nov 2012
hi lantsov/ kimo
I am not a indoor flyer by my self,only outdoor,but I am very interested in building your differential systems and also Kimo's contra-runners.(brushed and geared).
I build your first differential (wrong motor,thus to heavy) and Kimo's brushed one as a unit .Thank's both of you.
Now I like to build Kimo's geared one ,but first Lantsov's latested differential,the reduction is simple to change and it is light. Lantsov can you tel me witch motor you have used and witch Kv the motor has. Thank you!
frans tinnemans is offline Find More Posts by frans tinnemans
Old Feb 22, 2013, 03:35 AM
Joined Jan 2009
Hi Frans.
I used a homemade engine 22-3/45.
1400 rpm/volt
Old Feb 24, 2013, 12:04 PM
Joined Nov 2012
hi lantsov
your motor is 1400 kv,the reduction is 5:1,so your prop has only 280 kv.
is that right?
Old Feb 24, 2013, 03:40 PM
Joined Jan 2009
Hi
1400 kv my first system without gears.
Now I use the motor 2000 kv /
Today I did a test flight with the new coaxial,
Very good result.
Flight now lasts 5 minutes.
And my plane is lighter by 5 grams.
Video test flight.
Соосная мотоустановка А. Ланцова 24.02.2013 (1 min 57 sec)
Old Mar 12, 2013, 01:02 AM
bill clark is offline
Find More Posts by bill clark
Half way there
bill clark's Avatar
USA, FL, Ocoee
Joined Sep 2008
I have read through this entire thread and would like to say bravo to all of your successes. You guys are all great thinkers.
Lantsov, I think your latest design is great. Rediculously simple with ease of flexability in motor choice and front-rear differential ratios if desired. I would like to use your design on my next plane if you dont mind . Have you noticed any result of moving the motors torque and inertia from the roll to the yaw axis? Theoretically this seems like a good thing
bill clark is offline Find More Posts by bill clark
Old Mar 12, 2013, 03:43 AM
Joined Jan 2009
In my coaxial system I use motors 7 grams weight.
Rotor weight only 2 grams.
The moment is very small and does not affect the flight.
I made more than 100 flights and see only positive result.
My new plane has a flight 7 minutes with 7.4 v. ACC. 120 mA.
Build Log EPP f3P Plane tallflyer SDPARKFLYERS 14 Feb 28, 2012 02:32 PM
Discussion The New Phantom F3P Plane by Budgetrc.com tallflyer Foamies (Kits) 8 Jun 04, 2011 12:37 PM
Question Very slow indoor plane - F3P or??? Petrik59 Foamies (Scratchbuilt) 2 Dec 31, 2010 06:03 AM
Discussion Galaxy F3P Review, hobbyking plane dhdsracer Electric Plane Talk 0 Dec 17, 2010 09:45 PM
Discussion Another full scale electric plane Bob Chiang Electric Plane Talk 5 Sep 09, 2010 09:20 PM
