Old Feb 24, 2011, 09:53 PM
killerwin is offline
Find More Posts by killerwin
Say watt?!
killerwin's Avatar
United States, FL, Miami Lakes
Joined May 2009
Looking good, Peter. How long does it take you to clean the basement after a build like this?
killerwin is offline Find More Posts by killerwin
Old Feb 24, 2011, 10:47 PM
Doushiyou12 is offline
Find More Posts by Doushiyou12
Winter Is Coming
Doushiyou12's Avatar
Joined Feb 2010
spackle is your friend lol. i have used heaps of it
Doushiyou12 is offline Find More Posts by Doushiyou12
Old Feb 25, 2011, 12:50 AM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Why clean it? I don't get it
Looks just fine to me!
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Feb 25, 2011, 10:51 AM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
yeah, it wouldn't take too much to modify your nose. just a bit of sanding to the right shape, if it's solid foam.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Feb 25, 2011, 10:54 AM
foam and tape is online now
Find More Posts by foam and tape
Retardedly intelligent
foam and tape's Avatar
beavercreek,ohio
Joined Jan 2007
Took me 3 days to clean the basement from where it was to now where it is. Spent last night fixing the nose and adding some spackle and started building the wing box. Now I have to figure out how to shape the wing box....
foam and tape is online now Find More Posts by foam and tape
Old Feb 25, 2011, 11:07 AM
Joined Jan 2009
you are doing a wing box construction, like my 57? face the top and bottom of vertical edges with balsa and then use your wing ribs for solidity and then skin the top and bottom. I am also using coffee filter paper and WBPU on the inside edges as a composite sandwich. the whole structure is incredibly strong and light.
Old Feb 25, 2011, 11:17 AM
beavercreek,ohio
Joined Jan 2007
Got to remember the coffie filter paper wbpu trick! Sounds intresting.
Old Feb 25, 2011, 12:02 PM
Joined Jan 2009
I'm also doing the entire outer shell of the fuselage with coffee filter paper and WBPU. it's very hard when dry and light. not quite as strong as glassing with epoxy, but very good for what it is.
here's how my wing box is constructed: the wing is in three pieces before final joining, the two outer and the central wing section. I knew the thickness of each wing rib, so I was able to make a template of the two wing spars, as if looking from the front and rear. these are your vertical surfaces of the wing box. decide what thickness your balsa facing will be (I used 1/8 inch) and cut spar out of foam to suit. this balsa facing will give the foam incredible strength. make the rear spar the same way. your foam wing ribs link the structure together, but I remove every other rib, to allow the wing to flex somewhat. this extra space also allows for internals such as flap mechanics, etc. remember to make the rib in the nacelle pylon location out of ply or a composite sandwich of foam and two balsa layers. I join the outer panels to the inner panel with a male/female join and epoxy. the join is at the ply rib for the engine pylon for extra strength in that location.
just thought I'de share how I did it.
Rich
Old Feb 25, 2011, 12:38 PM
Concordefan is offline
Find More Posts by Concordefan
Scale Modeler
Concordefan's Avatar
Canada, ON, Mississauga
Joined Feb 2006
Pictures please, great progress being done on this model, spending good amount of time on her......lolz
Concordefan is offline Find More Posts by Concordefan
Old Feb 26, 2011, 10:01 PM
beavercreek,ohio
Joined Jan 2007
Rich
huh? got pics? good info though, I had to read it a few times though (my incompetent mind cant figure out what i'm reading)
Old Feb 26, 2011, 10:13 PM
beavercreek,ohio
Joined Jan 2007
pics, as requested
Old Feb 26, 2011, 10:18 PM
Say watt?!
killerwin's Avatar
Joined May 2009
Originally Posted by foam and tape View Post
huh?
|____ What he said...
Old Feb 26, 2011, 10:27 PM
Joined Jan 2009
wing box pics
here's a few pics from Olle's A380 build. mine is built exactly the same way. I'll post pics of mine tomorrow, but they look exactly the same as these.
Old Feb 26, 2011, 10:32 PM
beavercreek,ohio
Joined Jan 2007
thanks Rich, pictures are (literally) worth a thousand words.
Old Feb 26, 2011, 10:39 PM
Joined Jan 2009
yup, you get the point now. LOL. it's all good. the good thing about a wing box structure, is that it will be incredibly strong, just like the real thing. the other added benefit is that it will allow the wing to flex and flap like the full size too.
Discussion Boeing 777-200LR Twin 90mm project NickM91 Scratchbuilt EDFs 20 Jul 10, 2011 08:40 AM
boeing 777 u.s air Scale Kit/Scratch Built 16 Dec 03, 2002 06:15 PM
Looking for Boeing 777 AutoCad Drawing David McCracken Electric Ducted Fan Jet Talk 5 Nov 25, 2002 06:23 PM
Boeing 777-200/300 Sections Guybo Fuel Jet Talk 3 Jun 15, 2002 07:04 PM
boeing 777 nacelle jermaine Electric Ducted Fan Jet Talk 1 May 20, 2002 01:24 AM
