Old Feb 20, 2011, 12:12 AM
foam and tape is offline
Find More Posts by foam and tape
Retardedly intelligent
foam and tape's Avatar
beavercreek,ohio
Joined Jan 2007
Pictures!!!!!
foam and tape is offline Find More Posts by foam and tape
Old Feb 20, 2011, 12:23 AM
beavercreek,ohio
Joined Jan 2007
heres the rest of em, im fairly happy with the 3mm depron wrapping exept that I kept bending it a bit much and warped the rear part of the structure it! I'll just attach the tail cone to it and spackle in the gaps....
Old Feb 20, 2011, 12:40 AM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Nice work. I like that style of building a fuselage. It makes a strong/lightweight fuselage.
The skin keeps the fuselage torsion free.
What are you projecting for weight, wing area and thrust?
Eric B.
AirX is offline Find More Posts by AirX
Old Feb 20, 2011, 12:47 AM
beavercreek,ohio
Joined Jan 2007
Not sure about the weight but that fuse weighs just 9oz! I really need to figure out the motors I need though...
Old Feb 20, 2011, 12:59 AM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
There is a thread in the EDF Forum on a cheap setup for the Hoaye 4" fans for up to 4kW/12s. If you can get an idea of how much wing area and weight you can figure out the power needs.
This thread has the 4" Hoaye towards the last few pages.
http://www.rcgroups.com/forums/showthread.php?t=1324088
Eric B.
Old Feb 20, 2011, 01:40 AM
Concordefan is offline
Find More Posts by Concordefan
Scale Modeler
Concordefan's Avatar
Canada, ON, Mississauga
Joined Feb 2006
Beautiful work so far!, now i'm starting to think, i should have made my Concorde's fuselage the same way....
Not to put u down in anyway but to me ur nose and cockpit windows don't look as B777s on plans, they more look as B707s....
Concordefan is offline Find More Posts by Concordefan
Old Feb 20, 2011, 08:46 AM
beavercreek,ohio
Joined Jan 2007
Yeah, I need to touch up on those areas, these 3 veiws I got suck
Old Feb 20, 2011, 08:48 AM
beavercreek,ohio
Joined Jan 2007
Eric B.
Thanks for the link, not sure if I need all that power though! EDF hovering 777!!!
Old Feb 20, 2011, 08:57 AM
Doushiyou12 is offline
Find More Posts by Doushiyou12
Winter Is Coming
Doushiyou12's Avatar
Joined Feb 2010
You move fast F&T. She is looking great. Keep the updates coming.
Doushiyou12 is offline Find More Posts by Doushiyou12
Old Feb 20, 2011, 12:46 PM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Looking good!
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Feb 20, 2011, 10:12 PM
IWC is online now
IWC
Find More Posts by IWC
IWC
Joined Feb 2003
307 RC airliner with DSR 46 retracts (0 min 23 sec)
IWC is online now Find More Posts by IWC
Old Feb 20, 2011, 11:28 PM
beavercreek,ohio
Joined Jan 2007
todays progress, the tail section was a total to make. I should have built this hot wire foam cutter first... its a little crooked, so more sanding is needed. 5 hours of labor with a tiny 4 inch coping saw
Old Feb 21, 2011, 12:33 AM
Scale Modeler
Joined Feb 2006
NIce n fast....looking good, ur tailcone section seems to be off a "V" bit, i'm sure you fix it.
Old Feb 21, 2011, 12:36 AM
beavercreek,ohio
Joined Jan 2007
hmmmm.... maybe I should leave it that way that way when my radio locks out the plane will always veer twoards the left!
will do, I just need to let the spackle dry and fuss with the arse end of this bird a bit more.
Old Feb 21, 2011, 11:52 AM
LuvEvolution7 is online now
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
you better, or Sam is gonna drive all the way down to Ohio and fuss with your arse. LMAO
I think Sam is the bouncer of the airplane bar. hahahahahahaha
LuvEvolution7 is online now Find More Posts by LuvEvolution7
Discussion Boeing 777-200LR Twin 90mm project NickM91 Scratchbuilt EDFs 20 Jul 10, 2011 08:40 AM
boeing 777 u.s air Scale Kit/Scratch Built 16 Dec 03, 2002 06:15 PM
Looking for Boeing 777 AutoCad Drawing David McCracken Electric Ducted Fan Jet Talk 5 Nov 25, 2002 06:23 PM
Boeing 777-200/300 Sections Guybo Fuel Jet Talk 3 Jun 15, 2002 07:04 PM
boeing 777 nacelle jermaine Electric Ducted Fan Jet Talk 1 May 20, 2002 01:24 AM
