LI, New York, USA
Joined Mar 2003
http://www.rcgroups.com/forums/showt...8#post20452005 FWIW, Tests on the Radian seems to show that a 45 to 55 degree climb angle gets the best height in the shortest time. What kind of climb angle were you using on your Phoenix II? Depending on how much the Phoenix II motor can handle a small upgrade to the prop would probably do it. These results may be helpful. On the Radian and Pro, the stock prop is a 9.75 X 7.75. The standard Radian, upgraded to a Graupner 10X8 gets it over the 200 meter mark in about 25 seconds. On the Pro, an 11X8 and a battery upgrade to a higher C battery seems to get the job done too. The stock parkzone battery is a 15C. 25C seems to hold voltage a lot better. I don't know about the typical amp draw of the Phoenix set-up but these might be worth a try. I did see your post earlier about this test that you ran. If the motor is not getting hot but the ESC is maybe an upgraded prop would need an upgraded ESC too. When tested on the bench, WOT with a stationary plane, it went from room temperature to too hot to touch is just under 10 seconds while drawing 18 amps at 12 volts from a bench power supply. I used the bench power supply as it has an amp meter built in, and my cheap multi-meters are only rated to 10 amps |
| Thread Tools | |
| Article Hobby People Phase 3 U-2 EDF Glider Review | gp125racer | Foamy EDFs | 62 | May 10, 2013 09:32 PM |
| Sold S2G Models KA6E 3.2m scale glider | radman615 | Aircraft - Sailplanes (FS/W) | 2 | Nov 28, 2010 12:52 PM |
| Help! Phase 3 EPP planes. | cyclops2 | Foamies (Kits) | 0 | Nov 01, 2010 07:25 PM |
| Discussion Squall!(3 Cell) vs Phase 3 EF-16 – EP | JezUK1 | Electric Plane Talk | 2 | Nov 26, 2009 03:30 PM |
| Help! Lets talk hobbycity EPP vs phase 3 epp? which one | nickname236 | Foamies (Kits) | 2 | Sep 18, 2008 09:12 AM |
