This thread is privately moderated by Carlos230023, who may elect to delete unwanted replies.
Old Feb 14, 2011, 04:12 PM
Carlos230023 is offline
Find More Posts by Carlos230023
um.. yeah, I can make that fly
Carlos230023's Avatar
United Kingdom, Milton Keynes
Joined Jun 2007
Build Log
Gullow's Spirtfire 3/4"-1' scale
Ill probibally post this somewhere a little more obvious when the build really gets rolling but this will do for now :P. Here is the build log of my Guillow's Supermarine Spitfire kit I bought from hobbycraft for 23 ish. I came as a flat stamped balsa kit designed for display or some prehistoric method of flight called "u-control". basically an elevator, a few lengths of string and a cox .49 engine. Time to bring the old girl into the 21'st century! Ill be using blue arrow D0301 3.1g servos X4 (alierons, rud and ele). the famous (and a personal favorite of mine) 24g Blue wonder brushless motor, swinging a GWS 8040 3 bladed prop (good results with the watt meter on 3s). A turnigy 9g 10 amp ESC. and im very tempted to use the hobbyking $50 900mhz 200Mw Tx & cam (depending on the weight and nose cowl space). Time for some piccys!
Description: The fuse top and bottom runners
Description: my electrics, 6 CH 2.4Ghz HK raido in this bird
Description: The fuse ribbed up and ready for some servos
Description: the wings laid out, never intended to have alierons so the servo's have been cut into the ribs and wired internally
Will update soon
CJ
Carlos230023 is offline Find More Posts by Carlos230023
Old Feb 14, 2011, 04:39 PM
Joined Jun 2007
More progress (that I did early today, I just didnt take piccys) snapped from my Iphone. Motor is on, Wings are togeather and I still dont know how to make the pics full size, even when I attach them to the post Grr! Ele & Rud servo's next, then more stringers, some sanding+filling then it'll be time to cover! may put a fer balsa pannels in though, at full throttle the motor warps the fuse something chronic!
Description: Alierons cut out of the wings, Landing gear attached to spar and motor is on
Description: Looking good!
CJ
Old Apr 17, 2012, 07:13 AM
JSS4 is offline
Find More Posts by JSS4
I'm BIG on micros
Canada, ON, Brampton
Joined Mar 2011
Looking good! How's the Lancaster coming?
JSS4 is offline Find More Posts by JSS4
Old Apr 17, 2012, 12:07 PM
Joined Jun 2007
Lol till hobbyking get some stock in its not going. I need 4x mini ESC's and a few mini liniar servos for their gear. I havnt got the space to build it if I can finish it in a week or so :P.
CJ
Old Apr 17, 2012, 03:59 PM
JSS4 is offline
I'm BIG on micros
Joined Mar 2011
any plans to share?
Old Apr 17, 2012, 04:57 PM
Joined Jun 2007
Still sketching, I've got the airfoil, done the tail and the rear fuse, still working on the canopy and front fuse, figuring out the dihedral to look scale but work at this size, and the motor nacelles. I'll let you know when I've got some concrete sketches.
CJ
Old Apr 17, 2012, 05:48 PM
JSS4 is offline
I'm BIG on micros
Joined Mar 2011
Thanks. For dihedral, go for it b/c the plane should be more stable in the air.
I'll keep wait for the plans!
For Sale BEECHCRAFT STAGGERWING; Royal - Model D-17S Staggerwing Kit 1-3/4"=1' Scale old_dude Aircraft - Electric - Airplanes (FS/W) 3 Jan 09, 2011 07:11 PM
For Sale BEECHCRAFT STAGGERWING; Royal - Model D-17S Staggerwing Kit 1-3/4"=1' Scale old_dude Aircraft - Fuel - Airplanes (FS/W) 13 Jan 09, 2011 07:09 PM
Sold NIB Sig 1/4 Scale J-3 Cub Kit $185.00 Shipped! stevster Aircraft - Fuel - Airplanes (FS/W) 3 Nov 29, 2010 12:58 AM
For Sale J-3 Cowl - Sig 1/4-scale EJWash1 Aircraft - Fuel - Airplanes (FS/W) 0 Oct 03, 2010 08:03 PM
Sold 1/4 Scale ASK 13 Plans-3-view-photos *REDUCED* raceredg Aircraft - Sailplanes (FS/W) 5 Sep 05, 2010 05:20 AM
