Old Feb 14, 2011, 11:21 AM
kennyc is offline
Find More Posts by kennyc
kennyc's Avatar
Joined Feb 2004
possible to use air receiver with ground transmitter
hi,
i;d like to know if it is possible to use a air receiver eg. electron6 on a ground transmitter, eg. hitec agressor?
my ESC would check for 0 throttle before start up but a pistol grip spring return trigger throttle would register as 1/2 way? or 50% throttle?
i tried using sub-trim to adjust the throttle to 50% but still it does not register as 0 throttle to the ESC.
Anyone have any ideas?
thanks in adv.
kennyc is offline Find More Posts by kennyc
Old Feb 14, 2011, 11:45 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
It is possible on some systems and not on others. Some simply will not allow for TX RX connection.
Then of course some esc require to see zero throttle but like you mention on surface zero would be full back.
freechip is offline Find More Posts by freechip
Old Feb 14, 2011, 12:18 PM
Xpress.. is online now
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Not possible in this case. The Aggressor Tx is on 75mhz, and the Electron 6 Rx is on 72mhz.
You really can't do it anyways because of frequency laws. 72mhz is reserved for air use only, and 75mhz is for ground only.
Xpress.. is online now Find More Posts by Xpress..
Old Feb 14, 2011, 06:45 PM
kennyc is offline
kennyc's Avatar
Joined Feb 2004
Thanks for the reply guys, where I am at they designate 29mhz for all rc. So my tx and rx are the same freq. What Ian trying to trick the rx by adjusting the sub trim. Yeas its not meant to work that way?
Old Feb 14, 2011, 09:01 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
It has nothing to do with the RX (receiver) but everything to do with the ESC (Electronic Speed Controller). You have 2 different types of ESC more or less. You have AIR and Surface esc and Water esc fall in between.
Some have reversing function and of course you do not need reverse for air.
You are mixing different components and trying to make it work.
Air TX with surface ESC and or vice verso RIGHT?
You can most of the time RE-CALIBRATE the esc and so you should be able to get it to work.
I have done this in the past but mind you it was with current up to date US/CND equipement...
Old Feb 15, 2011, 07:21 PM
kennyc is offline
kennyc's Avatar
Joined Feb 2004
Found my silly mistake, I had not reconfigure the channels. Was too used to my multiolexk evo12
Discussion Does anyone use a JR PCM 10X Air transmitter for fpv? yellowcolorado FPV Talk 1 Oct 27, 2010 04:40 PM
Sold Futaba 8FGA 8-Channel 2.4GHz Air Transmitter and R6008HS 8-Channel Receiver $350.00 mike(ocrc) Aircraft - General - Radio Equipment (FS/W) 7 Oct 13, 2010 10:30 PM
Discussion Is it possible to use a 2.4ghz transmitter with a BNF mrdb Electric Plane Talk 28 Mar 30, 2010 07:27 AM
Discussion Can I use Berg MS4L receiver with FUTABA T14MZ (PCMG3 2048) 72MHZ Transmitter? sung_ch Radios 1 Jun 05, 2006 08:10 AM
Question Can you use a fm receiver with am transmitter? Slugejudge Submarines 7 Feb 10, 2006 02:34 PM
