Old Feb 14, 2011, 10:11 AM
Samjet is offline
Find More Posts by Samjet
Samjet's Avatar
Joined Mar 2010
Hobbywing HV 120a/TURNIGY K-Force 120A-HV OPTO 5-12S Brushless ESC
Hey all
Does anybody have experience with this product??? (Hobbywing HV 120a/TURNIGY K-Force 120A-HV OPTO 5-12S Brushless ESC). I have just ordered one and hope it will be more reliable than my old sentilon HV 100a that burned down my mb-339 fuse.
Samjet is offline Find More Posts by Samjet
Old Feb 14, 2011, 10:19 AM
yakhakker is offline
Find More Posts by yakhakker
still trying to get it right
yakhakker's Avatar
Belgium, Région wallonne, Tournai
Joined Feb 2009
I have used these ESC'S for some time with success but be careful not to overdo it with the amps as they do not like too many
yakhakker is offline Find More Posts by yakhakker
Old Feb 14, 2011, 10:52 AM
SCALEFAN is offline
Find More Posts by SCALEFAN
Done it all
United States, CA, Corona
Joined Feb 2006
I used these for years, never a problem. Get the programming card, makes life easier.
Where did you find one to order, I need more.?
Al
SCALEFAN is offline Find More Posts by SCALEFAN
Old Feb 14, 2011, 11:29 AM
Samjet is offline
Samjet's Avatar
Joined Mar 2010
Thanks a lot
I will be using it with Lee's Hayoe turbax combo with 110a. I really hope it doesn't burn out.
I bought it at Hobby hot for 120 $. Cheapest place I could find.
http://www.hobbyhot.com/hobbywing-pl...er-pr-751.html
Old Feb 14, 2011, 01:06 PM
SCALEFAN is offline
Done it all
Joined Feb 2006
Thanks for the info.
At first I thought that the Hobbywing version was the exact same as the Turnigy, but now I suspect that they are different. The Hobbywing appears to have a built in BEC, the turnigy doesn't and requires a receiver battery.
I am still going to order a few of them as there is nothing else on the market, price wise, that can compare.
Remember that the programming is different for an inrunner motor, as compared to an outrunner.
Old Feb 14, 2011, 02:00 PM
Neil Guildford is offline
Find More Posts by Neil Guildford
Neil Jarvis
Neil Guildford's Avatar
Surrey U.K.
Joined Sep 2004
I have one operating on 12S at 135A peak. Seems OK so far.
Neil
What planes it for?
Neil Guildford is offline Find More Posts by Neil Guildford
Old Feb 14, 2011, 02:09 PM
Samjet is offline
Samjet's Avatar
Joined Mar 2010
I am using it on the Falcon 120.
Old Feb 14, 2011, 02:11 PM
sheppard559 is offline
Find More Posts by sheppard559
Joined Mar 2008
Hey scalefan, what settings do you use for inrunners with that esc?
sheppard559 is offline Find More Posts by sheppard559
Old Feb 14, 2011, 02:36 PM
SCALEFAN is offline
Done it all
Joined Feb 2006
I actually forgot as I have several EDF planes, some inrunners and some outrlunners.
Outrunners are high timing
Inrunners are low timing.
I asked the guys at XPS about this, and jim's suggestion was to try diffeent settings.
In additon to timing, I believe that inrunners use a hard strart option. Perhaps some other guys will jump in and comment.
But you have to be really carfull with any ESC, if you get the timing wrong, or the start wrong, the ESC can immediately heat up and destroy itself. I suggest that after the ESC is hooked up, test it out with a battery and transmitter. If the motor does not start turning, or it barks and balks, immediately shut down. Feel the ESC.
Old Feb 17, 2011, 11:16 AM
MaHö is offline
Find More Posts by MaHö
MaHö's Avatar
Germany, BW, Stuttgart
Joined Dec 2001
Neil
Hi Neil, where do you use it? HST or other.
I know "Knife Liddle" is using his with much more amps than 120A....and works fine....
regards Martin
MaHö is offline Find More Posts by MaHö
Old Feb 17, 2011, 12:17 PM
Neil Jarvis
Surrey U.K.
Joined Sep 2004
Hi Martin
I'm using it in my Hunter with a Stumax 110-45 and prior to that my Tamjets F-16 with the same fan. I am concerned about another speed controller letting go with my DS-77...next in line is a Jeti spin 200 but I will be using it in something less valuable to me, my ASM Panther.
Neil
Old Feb 17, 2011, 12:46 PM
mikes68charger is offline
Find More Posts by mikes68charger
Why kamikaze pilot wear helmet
mikes68charger's Avatar
United States, IL, Rock Island
Joined Jul 2010
I just got one of the 150a opto in today and man it looks nice, a little big but nice.
Just rember a few thing about any ESC. I always test with a little 1000mah 40c 3s lipo. This way there is not a lot of power to fry or spark anything, but there is enof power to turn the edf to a decent speed.
Also I read somewere to always program you esc with the smallest lipo possable, this cause less heat and stress in the esc while going throw all those beebs...
Dose any one know how to connect this thing to a computer? It says it USB able.
mikes68charger is offline Find More Posts by mikes68charger
Sold Castle Creations Phoenix Ice HV 120A 12s (50V) Brushless ESC HeliPro5 Aircraft - Electric - Helis (FS/W) 1 Feb 14, 2011 11:47 AM
Help! Turnigy program box? 120amp 12S K-Force? wise guy Power Systems 10 Nov 30, 2010 02:09 PM
Discussion Turnigy K-force 120A-HV esc appleflyer Giant Electric Planes 22 Jun 25, 2010 06:25 PM
Discussion Is anyone getting the TURNIGY K-Force 120A-HV OPTO 5-12S Maxthrottle Electric Ducted Fan Jet Talk 15 Jun 02, 2010 04:08 PM
