Old Feb 14, 2011, 05:08 PM
Matt Howard is offline
Find More Posts by Matt Howard
Dyess AFB
Joined Apr 2009
I use a contact cement to glue my fan units in my planes. Holds nice and tight but I can "pop" them out if I need to.
Matt Howard is offline Find More Posts by Matt Howard
Old Feb 14, 2011, 05:12 PM
sonny1 is offline
Find More Posts by sonny1
Kool Kats Fly RC!! AMA 30462
sonny1's Avatar
United States, CA, Baywood-Los Osos
Joined Feb 2009
Great idea, I have some 3M 77; I'll give it a try, thanks!
Sonny
sonny1 is offline Find More Posts by sonny1
Old Feb 14, 2011, 05:31 PM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
Victapilot,
Here is what I can tell you on thrust, I just weighed the plane with a 4S2200 lipo and it is about 27 ounces. I ran it up and at ~500 watts I was at 1:1 thrust to weight. I need to charge the lipo to see what it is at on a full charge, my guess is about 32 ounces thrust.
I install the fan units with hot melt glue.
Don
The Don is offline Find More Posts by The Don
Old Feb 14, 2011, 06:03 PM
victapilot is offline
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
Don - thanks! That will be a rocket!
The stock setup is about 29oz thrust at 482Watts and 48,000RPM according to the fan manual.
PS thanks again for all your work, it's great stuff!
victapilot is offline Find More Posts by victapilot
Old Feb 14, 2011, 06:04 PM
sonny1 is offline
sonny1's Avatar
Joined Feb 2009
Originally Posted by The Don View Post
Victapilot,
Don
Best idea yet, got that too! Thanks, keep the good info comin"!
Sonny
Old Feb 15, 2011, 12:31 PM
Dyess AFB
Joined Apr 2009
I watt-metered mine (stock) today and on a fresh 4S 2200 40C pack I got 560 watts settling down to around 525 after about 30 seconds. Amp draw started at 36 amps and settled to 34-35.
Old Feb 15, 2011, 02:57 PM
victapilot's Avatar
Joined Feb 2009
Thanks! I was hoping for that - the fuselage duct is probably having some effect. The fan data in the manual is not specific to this plane, so it makes sense!
Old Feb 15, 2011, 03:39 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
I have a new 4S lipo coming, I recharged mine an it still was low on watt, it was only 3.4 volts per cell under load! No wonder I was only getting ~500 watts
Old Feb 16, 2011, 03:51 PM
victapilot's Avatar
Joined Feb 2009
I did a quick test with my 2900kv motor on 6S. It goes 700 watts at WOT, very scary. I know this is way over what they say the motor is good for, but it didn't smoke at least. For the test I used a fresh 4000 mah 45C 6S. It will not fit in the plane, it was just to get a measurement. Now I need to find a battery setup that fits, looks like a 2x1800x3s.
No hand launch for this one! I suspect the motor might not last long, but we'll see
Old Aug 29, 2011, 03:07 PM
kremecheze is offline
Find More Posts by kremecheze
kremecheze's Avatar
United States, NY, Queens County
Joined Jun 2007
no more info or video on this build don?
kremecheze is offline Find More Posts by kremecheze
Old Aug 29, 2011, 03:42 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Nope it tucked on the maiden when I went to WOT and destroyed the plane. I think this model has issues with high speed. I thought I posted that here, must have posted it in the other thread.
Don
Old Aug 29, 2011, 05:17 PM
sonny1 is offline
sonny1's Avatar
Joined Feb 2009
Gotta agree with Don, shortly after he started this thread I lost mine during the maiden flight while at WOT on the stock set up; lost all control authority at full throttle and nosed in. I've read of others having similar issues.
Sonny
Old Aug 29, 2011, 09:59 PM
kremecheze's Avatar
Joined Jun 2007
just picked up another pnp 4s version for dirt cheap, guess i'll have to try and fix all the high speed problems before taking her up
Old Mar 10, 2013, 09:10 PM
MJB9 is offline
Find More Posts by MJB9
ARMY ATC (93C)
MJB9's Avatar
United States, TX, Keller
Joined Jan 2005
Don, did you every get another one to build/fly? Do you still like the F-20, or you prefer your evader more? I liked the size of the F-20, as the evader is a bit smaller (but composite shell).
MJB9 is offline Find More Posts by MJB9
Old Mar 11, 2013, 06:31 AM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
No I never did. So can not really compare the two planes.
Article Great Planes® ElectriFly™ F-20 Tigershark EDF Jet ARF Review Bajora Foamy EDFs 276 Mar 17, 2013 12:51 AM
Build Log Wicked Powered Max-Jet F-117 Stealth EDF from Nitroplanes The Don Foamy EDFs 62 Jun 01, 2011 09:45 PM
