Old Feb 13, 2011, 06:52 PM
The Don is offline
Find More Posts by The Don
MA Indoor FreeFlight Columnist
Willoughby, Ohio
Joined Jan 2002
Build Log
Wicked Powered Electrifly F-20 Tigershark
Here is my build log.
Power system used,
Motor: Wicked 4400+ motor
Fan: Stock hyperflow fan unit
ESC: Pentium 60 amp
Lipo: 4S2250 40C Skylipo.
Don
The Don is offline Find More Posts by The Don
Old Feb 13, 2011, 07:01 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Here are some photos will add captions in a little bit because I want to keep building!
Don
Old Feb 13, 2011, 07:18 PM
Matt Howard is offline
Find More Posts by Matt Howard
Dyess AFB
Joined Apr 2009
I maidened my stock F-20 tonight, dopplered at an average of 96mph between two passes.
Matt Howard is offline Find More Posts by Matt Howard
Old Feb 13, 2011, 07:35 PM
sonny1 is offline
Find More Posts by sonny1
Kool Kats Fly RC!! AMA 30462
sonny1's Avatar
United States, CA, Baywood-Los Osos
Joined Feb 2009
Cool Don, thanks for the thread. I haven't finished assembly of my Tshark yet, but now I'm very tempted to stop where I am and order the power system you listed above. Though, if the stock system approaches 100mph like Matt Howard's stock F-20, I'm not sure if I could handle it being much faster, (yet). Other than the power system upgrade, are you doing any other modifications to your F-20?
Sonny
sonny1 is offline Find More Posts by sonny1
Old Feb 13, 2011, 07:38 PM
Dyess AFB
Joined Apr 2009
oops, didn't mean to stop anyone from upgrading their F-20. I was just stating how fast mine was stock so Don could see how much faster his is.
Old Feb 13, 2011, 08:00 PM
sonny1 is offline
sonny1's Avatar
Joined Feb 2009
No worries, I'm just relatively new to edf's and just wonder if I should fly it stock first. The Tigershark isn't my first edf, but the one I'm flying now tops out at around 80; just wonder if I'm ready for 100. How did yours fly?
Sonny
Old Feb 13, 2011, 08:06 PM
Dyess AFB
Joined Apr 2009
Sonny
The plane flies great no problems on the 3 flights I got in tonight. Carefull making tight turns though, she drops her nose pretty quick if you're not paying attention.
Old Feb 13, 2011, 08:35 PM
sonny1 is offline
sonny1's Avatar
Joined Feb 2009
Thanks, the Hobby Lobby F9F Panther I have does the same thing, it just flies slower. I'll watch to see what Don comes up with before I decide whether to upgrade or not. It's nice to know he has motors which will fit directly onto the stock fan though; very tempting.
Sonny
Old Feb 13, 2011, 09:10 PM
victapilot is online now
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
This is getting interesting! Please post videos asap!
victapilot is online now Find More Posts by victapilot
Old Feb 13, 2011, 10:34 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Do you have video for the doppler by chance? Any idea what watts you are pulling on the stock setup?
Old Feb 13, 2011, 10:51 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
And more.
Don
Old Feb 13, 2011, 11:02 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
nice don!!! its about time you do one
oooh! big motor...thats what im talking about! what kind of watts are we talking? 800 ish? i bet this sucker is going to haul. you know, i really like the electrifly fan...if i had one that ran true. so far, thats a no go. i bet having a dynamic balancer takes some of that pain away. you aught to have some good dons adapters made for them.
corsair nut is offline Find More Posts by corsair nut
Old Feb 13, 2011, 11:09 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
The spinners are the real issue, with no spinner they are easy to balance. The install on this uses no spinner due to the ducting. This is the power setup I had in my Evader, it was around 700 watts settling down to 650 watts but I have some 40C lipos coming so will see if it goes up a little. The bigger diameter motor really helps boost the rpm for same watts. The Wicked 4800 KV motor being smaller in diameter will have about the same wattage but lower RPM.
Don
Old Feb 13, 2011, 11:48 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Actually I just arranged for some samples of a 4800KV and 5000KV motor in the larger can size
Old Feb 13, 2011, 11:54 PM
sonny1 is offline
sonny1's Avatar
Joined Feb 2009
Don
That red decal looks right at home on the Tshark Don, might have to order one of those motors to get one for myself. The Tigershark is my second edf, so I'm not sure I'm ready for 700 watts; do you have any other motors somewhere between what you're using and the stock motor which would work with the Hyperflow fan?
Sonny
Article Great Planes® ElectriFly™ F-20 Tigershark EDF Jet ARF Review Bajora Foamy EDFs 276 Mar 17, 2013 12:51 AM
Build Log Wicked Powered Max-Jet F-117 Stealth EDF from Nitroplanes The Don Foamy EDFs 62 Jun 01, 2011 09:45 PM
