Old Feb 13, 2011, 05:11 PM
MrBen. is offline
Find More Posts by MrBen.
Great Britain
MrBen.'s Avatar
Joined Dec 2008
metal pushrod to plastic clevis
I have some heavy duty plastic clevis/control horn matching pair at the control surface end and a 3mm threaded rod with a metal clevis on the servo end. I need to glue the metal pushrod to the plastic clevis, whats the best glue to use? I didnt want to solder a metal clevis to the control horn end as its a bit sloppy in the control horn holes.
MrBen. is offline Find More Posts by MrBen.
Old Feb 14, 2011, 12:04 AM
Curare is offline
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
AFAIK no glue will work effectively on nylon.
if you have a clevis on one end, all you really need on the other is a Z bend.
I tend not to have 2 clevises on one pushrod unless one is fixed. it makes it really hard to adjust if both are able to rotate, for obvious reasons.
Curare is offline Find More Posts by Curare
Old Feb 14, 2011, 02:37 AM
discostu956 is offline
Find More Posts by discostu956
Is my CG correct?
discostu956's Avatar
Wollongong, Aus
Joined Sep 2009
I have yet to find a reliable glue on nylon either. It is meant to be a threaded joint?
discostu956 is offline Find More Posts by discostu956
Old Feb 14, 2011, 12:17 PM
MrBen. is offline
Great Britain
MrBen.'s Avatar
Joined Dec 2008
well the 3mm rod slides right in, unless its for 4mm rod? I scored the end of the rod up with pliers so the glue would bond better. I do have the soldered metal clevis for that end of the rod but it has slop on the control horn, looks like I need some 4mm rod and clevis or a control horn with smaller holes then!
thanks for your help guys.
Old Feb 14, 2011, 11:14 PM
Merlin1205 is offline
Find More Posts by Merlin1205
USA, FL, Winter Haven
Joined May 2006
If the clevis is sloppy in the horn you can make a CA bearing to take out the slop.
Just attach the clevis pin into the control horn hole you want. The take a pin and drop 1 or 2 drops of ca glue right on the clevis pin. Spray it with kicker and then break the clevis loose. You will now have ca type bearing in the control horn hole. Try it
Merlin1205 is offline Find More Posts by Merlin1205
Old Feb 15, 2011, 01:56 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Instead of all that I think I'd go shopping for a different control horn that fits the rod better.
I'm a big fan of either a Z bend or an L bend with a snap on keeper such as the Goldberg plastic snap on types or similar from other companies. Or even a small wheel collar as a keeper works well.
Either way you do NOT want to trust any glue joint between the wire and a nylon clevis.
BMatthews is offline Find More Posts by BMatthews
Old Feb 15, 2011, 04:10 PM
MrBen. is offline
Great Britain
MrBen.'s Avatar
Joined Dec 2008
nope especially on a plane that potentially could be flying 20km away from my location (ezuhf/fpv), Im gonna source some new horns or at the very worst drill new holes in the existing ones as there is plenty of room
Discussion Metal Pushrod Clevis FlyFisch Fuel Plane Talk 7 May 13, 2010 05:42 PM
How do you secure threaded metal rod to plastic inner pushrod sleeve? Jimmy James The Builders Workshop 12 Nov 22, 2005 05:04 AM
EleBee Clevis and pushrod radcast2 Flying Wings 9 Feb 16, 2005 03:38 PM
