Old Jun 22, 2005, 10:40 AM
Ice is offline
Ice
Find More Posts by Ice
Ice
United States, CA, El Cajon
Joined Jul 2002
I put vib supression on the motor mount.. not an issue now
Ice is offline Find More Posts by Ice
Old Jul 14, 2005, 02:16 PM
db4962 is offline
Find More Posts by db4962
Lakeland, FL
Joined Mar 2005
Any updates on the T-34? I was considering getting the ARF version. Also didn't know if one brand of .46 size engine would be better for this bird than another. I would like to get a 4-stroke, but that is a little cost-prohibitive right now.
db4962 is offline Find More Posts by db4962
Old Oct 23, 2005, 06:49 PM
RDD is offline
RDD
Find More Posts by RDD
RDD
United States, MI, Sanilac
Hi Guys,
Can anybody tell me which color of Ultracote the Yellow is on this plane (Hangar 9, t-34 ARF version)? I have to do a little "patching" on mine (due to an unplanned corn field incident), and their website (horizon hobby) lists 3 different shades of yellow. I have to mail order it, since my locality is hobby shop challenged, and I can't seem to tell which color shade it is. I apologize if this has been addressed, but my searching has led me nowhere, and I'm sure some of you guys will know. Thanks in advance for any help.
Ron
RDD is offline Find More Posts by RDD
Old Oct 24, 2005, 11:13 AM
Ice is offline
Ice
Ice
Joined Jul 2002
Its in the manual in the back
Old Oct 24, 2005, 11:33 AM
RDD is offline
RDD
RDD
I don't have the original manual. But, I downloaded it from the website and I just didn't see it in there. Am I just missing it?
Ron
Old Oct 24, 2005, 12:21 PM
Ice is offline
Ice
Ice
Joined Jul 2002
Wing Span: 57.25 in (1454 mm)
Overall Length: 45 in (1146 mm)
Wing Area: 555 sq in (35.8 dm)
Flying Weight: 6 - 7 lb (2.7 - 3.2 kg)
Engine Size: .40 - .46 2-stroke, .56 - .82 4-stroke
Radio: 4 channels
Servos: 5 (6 w/ retracts)
Trim Scheme Colors: HANU884 Cub Yellow, HANU874 Black
Old Oct 24, 2005, 02:50 PM
RDD is offline
RDD
RDD
Thaaank You!!
Old Apr 09, 2007, 02:51 PM
gosmondson is offline
Find More Posts by gosmondson
Fresno, CA
Joined Sep 2005
Just got a newer (white/red) T-34 from H9. So far I love everything about the plane.. The H9 retract install was very easy (a little sanding, line things up and call it good). I am still waiting on getting a powerplant for this guy, I was thinking of going with the SAITO .82GK. Anyone have any experience with this setup?
gosmondson is offline Find More Posts by gosmondson
Old Apr 09, 2007, 04:34 PM
rz22g is offline
Find More Posts by rz22g
United States, CA, Bear Valley Springs
Joined May 2006
This plane to me had the most realistic flight feeling of any plane I have owned. My only complaint would be with the front retract if you are landing on a grass field. Eventually my front gear would twist when landing and the wire would bend slightly. I could straighten but it would do it again, getting worse each time.
rz22g is offline Find More Posts by rz22g
Old Apr 10, 2007, 11:38 AM
Fresno, CA
Joined Sep 2005
I was thinking about trying a 2 1/2" wheel up front to help for this, as my primary field is grass. It fits but barely and it would be very easy to bind up..
What about using like a robostrut or something? There are a few posts showing people having a strut up front to help with shock, and it gives a nice scale look too...
Old Apr 14, 2007, 07:59 AM
Dora Nine is offline
Find More Posts by Dora Nine
The sky is my playground.
Dora Nine's Avatar
United States, NH
Joined May 2005
I've had good luck with the kit supplied struts. PLenty of take-off's and landings with them. The only change I made was the main struts. I removed them from the units and then use my dremel to cut a notch to match the one supplied. I then use a fair amount of RED lock-tite to hold the strut and set screws in place. Since then, I haven't looked back. Mine is powered by a Magnum 46 with an 11X7 prop. It's quiet and damn fast.
Dora Nine is offline Find More Posts by Dora Nine
Old Apr 03, 2008, 08:33 AM
Sir Barf is offline
Find More Posts by Sir Barf
Joined Apr 2007
H 9 T-34 Mentor
Hi
Just bought the new version (white/red). Im not sure if Im going for an electric or an fuel engine on this bird. I have an OS 70 II that might fit but what about electric engines in this one ?? Has anyone tried electrify this bird, what kind of electric set up is used ??
Is the OS 70 too heavy (do I have to add lead at the tail) ?? What fuel engine is the most suitable (no lead attach to the nose or tail) ?
Does the new version have the same high speed landing as the old (yellow) one ?
Are
Sir Barf is offline Find More Posts by Sir Barf
Old Apr 04, 2008, 04:15 AM
Dora Nine's Avatar
United States, NH
Joined May 2005
Instead of adding lead, think of using a bigger battery, why carry dead weight when you could carry extra power for servos, etc.
Old Apr 05, 2008, 03:09 AM
tmulder is offline
Find More Posts by tmulder
United States, CA, Oceanside
Joined Aug 2007
I built the new red and white one and love the way it flys. I have a Saito .82 with a MAS 3 blade 12X8 with a TruTurn spinner. I started with a 13X8 2 blade but with the 3 blade it looks more scale and the .82 satio works really well with this prop on PowerMaster YS 20/20 fuel at about 9500 RPM.
I enclosed the front wheel well to keep out the goo and used 1/32 ply to build a A frame type enclosure. I also made the Flap modification detailed at the following RCU link: http://www.rcuniverse.com/forum/m_18...tm.htm#1893157.
The plane came it at 6 lbs 14 oz and I had to add 7oz of weight in the tail cone to balance. I used the stock retracts and they work fine a pavement.
This is a really fun plane to fly and always gathers attention at teh field.
tmulder is offline Find More Posts by tmulder
Old Apr 07, 2008, 01:56 AM
Dora Nine's Avatar
United States, NH
Joined May 2005
tmulder: Any pics?
Article Hangar 9 T-34 Mentor 40 ARF w/ Optional Retracts Review rc2xs Fuel Warbirds 83 Jul 31, 2011 12:31 AM
For Sale H-9 T-34 Mentor DbleX Aircraft - Fuel - Airplanes (FS/W) 9 Jul 26, 2007 10:50 PM
Hangar 9 T-34 Mentor ARF db4962 Fuel Warbirds 1 Jul 21, 2005 10:12 PM
Hangar 9 T-34 Mentor ARF - Question about retracts??? bradj11 Fuel Warbirds 2 Oct 18, 2004 06:45 AM
Hangar 9 T-34 Mentor E-conversion jet_jer Scale Kit/Scratch Built 1 Aug 12, 2003 11:42 AM
