Old Feb 13, 2011, 01:18 PM
Blue Jacket is offline
Find More Posts by Blue Jacket
United States, OH
Joined Dec 2006
Question
Fuel Tank Size for DLE 20 and Electronic cutoff??
Nearing completion of my TF Seafury. I am putting a DLE 20 on it and was wondering ow large of a fuel tank to use. The plans call for a 12oz for a .60 nitro, but I wasn't sure if I should go larger or smaller.
Also, what is the censuses on an optical cutoff. Should I have one or is a mechanical switch acceptable?
Blue Jacket is offline Find More Posts by Blue Jacket
Old Feb 13, 2011, 04:19 PM
jetmech05 is online now
Find More Posts by jetmech05
Jacksonville Fla.
Joined Mar 2007
Optic cut off is a must in my opinion....a gasser at an event needs 2 or more ways to kill an engine....trim is one....either a choke servo or an optic kill switch is another......with an optic kill switch and 2.4 lose signal lose ignition.....
I have several gasser all have optic kill......
Please don't fly without one...
tank size...a 12 oz will be plenty...remember you need a different stopper and fuel lines for gas...and the tank is plumbed differently...no exhaust to worry about.....
jetmech05 is online now Find More Posts by jetmech05
Old Feb 13, 2011, 04:35 PM
RCFVR is offline
Find More Posts by RCFVR
Keller, TX
Joined Aug 2005
Definately don't go with a larger tank, unless you are planning marathon flights or like to haul extra weight. My G20 with a 12oz tank gives me 2 flights of 8-10 minutes with reserve. It's on a YAK 54, so I'm not going full throttle all the time. A 10 oz tank might be a better choice for a war bird, depending how long flight duration you expect.
RCFVR is offline Find More Posts by RCFVR
Old Feb 13, 2011, 06:46 PM
United States, OH
Joined Dec 2006
No I was thinking smaller, but I wasn't sure if I should go 8 or 10 oz. 8-10 minutes of flying time with a suitable landing reserve is plenty. I have the gas stopper and Tygon lines.
Jetmech, Thanks for the advice on optical cutoff, guess I need to pop for one.
Old Feb 13, 2011, 07:49 PM
RCFVR is offline
Keller, TX
Joined Aug 2005
Fuel consumption for a 20cc gasser is around .7oz/minute at full throttle (actually a touch less than that). A 10oz tank should be good for a bit over 14 minutes at full throttle operation.
I have used mechanical ignition cut off for the past 12 years I have been flying gas, but I have bought one of the electronic gadgets that are popular now, will put it on my next plane. One gnawing thought troubles me about it, and that is that it one more potential fail point in the electronic system. I will give it a try just because I like new toys from time to time. So far, I have never experienced a need for one. I'll see if it's worth the trouble.
Old Feb 15, 2011, 06:00 AM
Jacksonville Fla.
Joined Mar 2007
Jim ignition cut off wether its electrical or mechanical is a fail point.....electrical is alot more reliable than mechanical
Discussion RCGF 15CC Fuel Tank Size aramsdell Fuel Plane Talk 6 Nov 14, 2011 09:27 PM
Wanted Fuel Tank for Phantom P30 redball8 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Dec 02, 2010 10:23 AM
Discussion Fuel tank size for a .55 2stroke? stegla Fuel Plane Talk 2 Sep 22, 2007 01:39 PM
Question Fuel tank size for Saito 1.80 Mike_Then Engines 1 Jan 08, 2006 07:52 AM
Fuel Tank size for a Zenoah G.45 Pro Flyer Giant Scale Airplanes 3 Jun 06, 2005 03:23 PM
