Old Feb 13, 2011, 12:24 PM
LowFlier07 is offline
Find More Posts by LowFlier07
United States, OH, Chardon
Hacker Motor For P-51
I plan on building a Brian-Taylor P-51, wing span 69 inches, weight about 10 lbs. What Hacker motor would be recommended - the A-50 or A-60 series of motors?
Tom.
LowFlier07 is offline Find More Posts by LowFlier07
Old Feb 13, 2011, 01:49 PM
800mZero is offline
Find More Posts by 800mZero
3DHS Junkie
800mZero's Avatar
Rhode Island
Joined Jun 2005
realize its not the same bird--but read mikes thread--the esm is roughly the same weight and measurements and his is hacker powered.
http://www.rcgroups.com/forums/showthread.php?t=1155776
800mZero is offline Find More Posts by 800mZero
Old Feb 13, 2011, 02:36 PM
strictlyscale is offline
Find More Posts by strictlyscale
Dream Build Fly Scale
strictlyscale's Avatar
Philadelphia, PA
Tom,
I would think the A50 series would be nice. Btw, I've built and flown 2 mustangs from Brian's plans. Very nice and in my opinion the best looking model in the air of the mustang despite its smaller size. Let me know if you have any questions regarding the build.
strictlyscale is offline Find More Posts by strictlyscale
Old Feb 13, 2011, 07:22 PM
Thanks guys for the info. Looks like the A-50 will work. Smaller battery packs lighter. Also, what do you think of these E-Flite motors? This one might be the right size, not sure. Do these motors hold up as well as a Hacker?
Thanks.
Old Feb 13, 2011, 07:33 PM
Philadelphia, PA
Not sure, haven't trusted any other motor other than Hacker yet.
Here's a couple pics of my two Brian Taylor scratchbuilt Mustangs. Both the 69" version, both powered by Enya 1.20 4-strokes. There are a couple things I'd change but not many. Brian does a really nice job.
Old Feb 13, 2011, 08:04 PM
Strictlyscale:
Your P-51s look great. Nice job. What retracts would you recommend and whose canopy will fit? I don't think Brian-Taylor sells the canopies anymore.
Thanks.
Old Feb 14, 2011, 09:07 AM
Philadelphia, PA
Thanks Tom.
Bob Holman in the US supports Brian's designs:
http://www.bhplans.com/BTPlansPg2.html
Traplet in th UK does the same:
http://shop.traplet.com/product.aspx?c=1287
I used Unitracts mechanical retracts on mine as they are designed for the BT Mustang. I think they offer them in a pneumatic version too which would be easier to use for sure. I'd recomend supporting the shaft that the leg pivots on, it's a cantilever design to get the pivot close to the leading edge per scale but it's a weak point. See pictures of how I know.
I made my own tailwheel retract per the dwgs on the plans.
Another potentional weak spot is at the rear of the cowl along the fuselage side. Mine broke on the second one during and heavy landing. It's an easy fix with ply doubler inside the fuse.
Hope that helps.
Old Feb 14, 2011, 04:24 PM
Thanks again. The landing gear seems to be a problem area. I have had the plans blown up to an 80" wing span. This will give me better options as for a spinner, canopy (can be bought from Tower). Robart 630 retracts should fit will and I think I will go with the A60 hacker motor. Should handle better for take offs. I've been viewing your Corsair project. Your craftsmanship is top notch and ideas. Do you think the A60 will fly this plane with good performance?
Tom
Old Feb 14, 2011, 04:55 PM
Philadelphia, PA
Sorry Tom, I didn't realize you were enlarging the BT plan. You're right the A50 would not be large enough.
Not sure what canopy you're looking at but if its for the top flite mustang you may be creating quite a job for yourself. The TF cockpit is too short for 1/5 scale and is about 1/4 scale in width.
You may have better luck using an aerotech canopy or one for the CJM Mustang. Just a thought.
Another point about the BT plan is that the whole nose is a fiberglass cowling. Which is really nice as it saves a ton of work and affords a lot of access. The down side is that your plan won't show this area with any formers etc for you to build from.
It may be less trouble to go with the TF kit or ARC and use an after market cowl to correct the nose shape. I think there are two available on the market.
Please post your progress as you embark on your build. Thanks for the generous comments regarding the corsair, it was a fun little project. Hope to run it up this week and see what numbers I get from the A60 motor.
Old Feb 14, 2011, 08:30 PM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
I'm sure you are aware but there is the A-60 S, M and L you want the L for a larger warbird.
I have the A60- 16L (168 KV) with a 24x14 prop on a 17.5 pound 30% extra it is a stump puller and on 12s 5000 will out perform a DA 50cc gas engine...at 4500 watts
I would myself want to go faster with a P-51.. so I would bring up the KV and go with the A60-14L (192 KV) then adjust your prop size to give you the speed and vertical you are looking for..
The 22x10 or 12 would be safe place to start
for more speed less vertical try a 21x14 or 20x12 you could also mess with 10s or 12s but I would think if your over 20 pounds you need 12s
all of that is my opinon..lol
Ron101 is offline Find More Posts by Ron101
Old Feb 15, 2011, 05:47 PM
drksyd is offline
Find More Posts by drksyd
MultipleCrashSurvivor
drksyd's Avatar
USA, HI, Honolulu
Joined Jan 2003
I think an A60 S will do fine if you are about 10lbs flying weight. I have an A60 14L in my H9 P-47 with 20x10 and was running some TP Extremes (10S) that were ready to kick the bucket and still had good performance. I haven't weighed it, but I think it's about 17lbs. With new packs I have and a 21x14, I should see a big improvement in performance.
drksyd is offline Find More Posts by drksyd
Old Feb 15, 2011, 06:05 PM
Philadelphia, PA
IMHO 10 lbs is more realistic for the 69" span Taylor Mustang, not one at 80" or more.
Old Feb 15, 2011, 06:14 PM
drksyd is offline
drksyd's Avatar
USA, HI, Honolulu
Joined Jan 2003
Missed that part. Looks like I'll agree with Ron and suggest an A60 L as it'll be 20+lbs as a rough guess.
Discussion Motor for Guanli P-51? (GWS clone) Murman Electric Warbirds 6 May 13, 2011 08:35 PM
Discussion brushless motor for parkzone um p 51 ultra stick Scratchbuilt Indoor and Micro Models 15 Nov 26, 2010 12:50 PM
Found Parkzone UM Sukhoi 26m Motor Trade for UM P-51 Motor microflitedude Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Nov 08, 2010 01:56 AM
Sold Hacker P-51 epp foam: Relisted/reduced Doug Hinkel Aircraft - Electric - Airplanes (FS/W) 4 Sep 26, 2010 11:59 AM
Sold Great Planes P-51 w/Hacker motor project for sale. bruff Aircraft - Electric - Airplanes (FS/W) 2 Sep 25, 2005 01:38 PM
