Old Jan 28, 2012, 04:28 PM
frankg is online now
Find More Posts by frankg
Joined Dec 2004
TOM- Your not alone. I have asked around up a the Thousand Islands at the different boat yards and at the museum, but no go for the eleventh boat name. If and when you come across the name don’t forgeet to post it here.
frankg is online now Find More Posts by frankg
Old May 04, 2015, 11:19 PM
CG Bob is online now
Find More Posts by CG Bob
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
Originally Posted by frankg View Post
All of the mahogany planking of the hull will be done with the 1/2” wide mahogany veneer planking. All of the planks will be back sanded on the butting edge side of the plank. This means that the bottom butting edge of the plank will be sanded off at a slight angle to allow the plank to have a tight joint against the butting plank. (see DWG 1)
I recently started building this kit. I'm using a piece of 1/2" aluminum angle as a guide for back sanding the planks.
CG Bob is online now Find More Posts by CG Bob
Old May 08, 2015, 05:58 PM
californiakid is offline
Find More Posts by californiakid
mahoganyfan
californiakid's Avatar
United States, NJ, Atlantic City
Joined Nov 2010
Legend Model Boat
CG bob, great idea on how to make the back sanding easier. Are you going to do a build log?
californiakid is offline Find More Posts by californiakid
Old May 10, 2015, 10:56 AM
KC8WPF
CG Bob's Avatar
Joined Sep 2004
I won't be doing a build log. Since I plan on modifying the stock kit to look like a new full size boat based on the Garwood hull, I will post pictures of the changes as I make them.
Old May 10, 2015, 12:03 PM
Joined Dec 2004
BOB- Be advised that if you are going to build one of the new Gar Wood 20’ speedsters, the real boat also added some beam to the boat as compared to the 16’ original. You might get away with adding some distance equally between the frames from the widest beam to the transom.
If you are going to make the 16’ Gar Wood utility, you can get away with changing the deck layout on the speedster. That is how Phil Wood, Gar’s brother, came up with the original speedster, going from the original 16’ utility to the 16’ speedster, by changing the deck layout on the hull.
Old May 10, 2015, 01:07 PM
KC8WPF
CG Bob's Avatar
Joined Sep 2004
frankg -
Changes will be in the cockpit area; left hand drive; floor mounted shift lever; different windshield; trim pieces; etc. The boat in the picture was built from one of the fiberglass hulls, with a few design changes by the builder.
Old May 10, 2015, 01:28 PM
Joined Dec 2004
BOB- That boat looks to be a DART Speedster, built by the DART motor boat company. The dimensions are almost identical to the Gar Wood except for the upswept deck to the cockpit and the raised comings around the cockpit.
I think they did a write up on the DART Speedster in one of the latest issues of Classic Boating Magazine. The original Darts were mahogany planked like the Gar Wood. You say that this one is fiberglass? I did not know of anyone making replica DART Speedsters.
Old May 10, 2015, 01:57 PM
KC8WPF
CG Bob's Avatar
Joined Sep 2004
The Dart Speedster is mahogany veneer over a fiberglass hull. I took the picture last year at the Toledo Antique and Classic Boat Show. The boat in the picture is hull #1601 - the first one built by the company.
More pictures from the 2015 show.
Old May 18, 2015, 08:17 PM
mahoganyfan
Joined Nov 2010
Modifications
Keep us posted CG bob on your modifications of the Garwood speedster, would you please. I have seen your builds and all your boats look great.
Old May 18, 2015, 10:45 PM
KC8WPF
CG Bob's Avatar
Joined Sep 2004
I will. I spent an hour today in the Dart Boats Shop today getting some additional measurements and sketches. Took the model and box with me. Now I just have to convert my numbers and sketches into templates for the model.
Mini-Review The "Cavalier" from Legend Model Boats -- Kit Review P. Tritle Scale Boats 86 Jan 24, 2016 06:08 PM
Legend Model Boats "Thunderbolt" Kit Review P. Tritle Scale Boats 122 Feb 28, 2013 03:06 PM
New Product New kit releases for 2011 from legend model boats frankg Scale Boats 62 Jan 04, 2012 11:46 AM
Discussion Legend Model Boats Lyman? Aerominded Scale Boats 19 Nov 19, 2006 09:34 AM
