Old Nov 19, 2011, 01:48 PM
FPVV is offline
Find More Posts by FPVV
Joined Mar 2010
http://www.dronemaker.co.il/shop/ind...ucts_id=45This is the best ..
MT2216
FPVV is offline Find More Posts by FPVV
Old Nov 19, 2011, 02:18 PM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Tiger Motors ?
renatoa is online now Find More Posts by renatoa
Old Nov 19, 2011, 02:20 PM
FPVV is offline
Joined Mar 2010
yes,Exactly the same thing only without sticker
Old Nov 19, 2011, 05:20 PM
Mortimer is offline
Find More Posts by Mortimer
Mortimer's Avatar
Joined Apr 2010
Originally Posted by patricklupo View Post
What prop is GF 10x4.5 supposed to mean?
I have used this propeller : http://flyduino.net/10x45-GF-Propell...z-Set-4-Stueck
Mortimer is offline Find More Posts by Mortimer
Old Nov 28, 2011, 04:22 PM
Mortimer is offline
Mortimer's Avatar
Joined Apr 2010
New test: 5 motors compared
Fixed parameters:
Battery Orion 3S 4000 mAh 30-60C fully charged before each test
Propeller GF 10x4.5 (Link) (XAircraft is identical but the hub)
ESC Hobbywing Pentium 30A - Turnigy Servo Tester
Junsi PowerLog 6S Wattmeter - LogView software
Tests results:
Turnigy Park 450 890KV (Link) - Weight: 65 g - Max power: 180 W - Max thrust: 960 g - Mean efficiency: 6.9 g/W
T-Motor MT 2216 900 KV (Link) - Weight: 74 g - Max power: 170 W - Max thrust: 920 g - Mean efficiency: 6.8 g/W
Flycam 925 KV (Link) - Weight: 48 g - Max power: 160 W - Max thrust: 800 g - Mean efficiency: 6.7 g/W
Xaircraft X650V motor 1050-1100 KV (Link) - Weight: 50 g - Max power: 275 W - Max thrust: 1150 g - Mean efficiency: 6.3 g/W
Hacker Style KA 20-26 M 1130 KV (Link) - Weight: 46 g - Max power: 165 W - Max thrust: 750 g - Mean efficiency: 5.9 g/W
Weights include cable, connectors and propeller adapter
Test bench:
Old Dec 01, 2011, 11:38 AM
Joined Sep 2007
You can label "Tests results" or how you like, but not compare, it is flawed from the start to compare 850kv with 1130kv with same prop !
Redo test with 9" prop on 20-26 and will see.
Old Dec 02, 2011, 04:54 PM
Mortimer is offline
Mortimer's Avatar
Joined Apr 2010
What pitch ?
Old Dec 20, 2011, 03:50 AM
eirikso is offline
Find More Posts by eirikso
Joined Dec 2011
First of all: thank you so much for this thread. Really useful for all of us.
I've done enough flying with cheap vibrating motors and have spent enough time trying to balance them. So I want to buy some new better (and more expensive motors). So I'm reading, reading, reading...
But still can't decide. My number one priority is low vibrations. Seems like you've tested a lot of motors. So what are your experience if I want to buy a set of motors that are well balanced out of the box?
More info on my quad etc here: http://www.rcgroups.com/forums/showthread.php?t=1558759
eirikso is offline Find More Posts by eirikso
Old Dec 24, 2011, 09:45 AM
drcigg is offline
Find More Posts by drcigg
drcigg's Avatar
United States, MN, Chaska
Joined Sep 2011
I can't tell you how many times I have used this thread for reference on motor tests. It has been a great resource.
drcigg is offline Find More Posts by drcigg
Old Jan 11, 2012, 12:50 PM
holco is offline
Find More Posts by holco
holco's Avatar
The Netherlands
Joined Mar 2007
Soon a test with the,
Axi 2814/22 (765KV)
Mikrokopter MK 3538 (770KV)
RC-Tiger MT2814-11 (710KV)
RC-Tiger MT2814-10 (770KV) (equivalent to the Avroto 2814)
All on 4S and 5S with the following props,
Graupner 11x5 E
APC 12 x 3.8 SF
APC 14 x 4.7 SF
Xoar 14 x 5 (wood)
holco is offline Find More Posts by holco
Old Jan 11, 2012, 01:56 PM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
Axi 2814/22 (765KV)
Graupner 11x5 E
APC 12 x 3.8 SF
APC 14 x 4.7 SF
Xoar 14 x 5 (wood)
I am looking forward to seeing these tests.
robone is offline Find More Posts by robone
Old Jan 17, 2012, 03:44 PM
holco is offline
holco's Avatar
The Netherlands
Joined Mar 2007
I posted this in my Flexacopter topic, but I think here is also a good place for this test.
Today a have done a test with all the props that I have suitable for the Flexacopter, I try to show what prop will give the most smooth image with the current MK gyro settings that still need some tuning.
Setup,
Flexacopter with in the AV-130 mount the GH2 camera fitted with the Olympus 45 mm F1.8 (90 mm telelens equivalent to 35mm film) (F5.6) 720P/50f-sec.
Total flying weight with the 5S/8000mAh lipo and GH2 4520 grams, Picloc Pro is off so no mount stabilization.
I have also noted the Amp rating from the MK indicated during the hoover with each prop, here the outcome.
Graupner 11x5 E (43A)
APC 12x3.8 SF (41A)
APC 14x4.7 SF (38A)
Xoar 14x5 wood (37A)
Outcome regards the video quality.
Graupner 11 x 5 (E) a clear first place.
APC 12 x 3.8 SF and the Xoar 14x5 2nd and 3rd place
APC 14 x 4.7 SF Gets the fourth place
You see also here no Free-Lunch!!
The Graupner 11x5 does it surprisingly good but has the highest consumption, The Xoar 14x5 is despite his shared 2nd and 3rd place far below the video result of the Graupner props but 6A more economical.
I would clearly indicate that this test outcome regarding the video quality in my situation is no guarantee for the same outcome with an other setup.
The 4 videos,
Flexacopter prop test (Graupner 11x5 E) (2 min 16 sec)
Flexacopter prop test ( APC 12x3.8 SF) (2 min 41 sec)
Flexacopter prop test (APC 14x4.7 SF) (3 min 22 sec)
Flexacopter prop test (Xoar 14x5 wood) (3 min 43 sec)
Old Jan 17, 2012, 04:12 PM
SpeedMaster is offline
Find More Posts by SpeedMaster
UAS Test Pilot
SpeedMaster's Avatar
Norway
Joined Jul 2003
What about the new ipower 2814 750kv that Monto sells? Anyone tried it?
SpeedMaster is offline Find More Posts by SpeedMaster
Old Jan 18, 2012, 01:55 AM
volver is offline
Find More Posts by volver
Russia, Moscow
Joined Jan 2011
Setup,
APC 12x3.8 SF (41A)
APC 14x4.7 SF (38A)
Thanks for tests!
What motors were used, as it's not clear regarding your previous post?
volver is offline Find More Posts by volver
Old Jan 18, 2012, 02:05 AM
holco is offline
holco's Avatar
The Netherlands
Joined Mar 2007
Avroto's on 5S
Discussion Airfoil Comparison Database Yak 52 Modeling Science 4 Oct 10, 2010 03:16 PM
Discussion Motor weight database GoatZilla Power Systems 2 Feb 23, 2006 11:43 AM
RCgroups DIY motor performance database button Power Systems 2 Jun 10, 2005 07:56 PM
GoBrushless Motor Database RFI Jay C Power Systems 88 Aug 20, 2004 07:42 AM
Motor Database F.Littleton Electric Plane Talk 8 Nov 16, 2003 09:31 AM
