Old Aug 12, 2011, 08:53 PM
United States, PA, Erie
Joined Dec 2006
Originally Posted by windfou View Post
can i use bigger props with my 2830-14 rc timer motor? like 11x4.7 apc or 12x4.7
Yes you can use 11.4.7 props on those motors as long you are using a 3 cell lipo. I have ben doing it for a long time with out any problems.
JET MAN TWO is offline Find More Posts by JET MAN TWO
Old Aug 12, 2011, 09:11 PM
United States, TX, Thrall
Joined Feb 2010
Hey Jet Two Michael64 here have you tried any of the Graupner E 11x5 props. Claimed here to have the less vibs of all.
Michael64
Michael64 is offline Find More Posts by Michael64
Old Aug 12, 2011, 11:22 PM
multi rotors,foamies,car lover
windfou's Avatar
Joined Dec 2008
Michael64
thank you i will try them also the graupner props are looking good
can i have a link i want to buy them but i can't find a website
windfou is offline Find More Posts by windfou
Old Oct 16, 2011, 05:54 AM
Lithuania
Joined Jan 2007
Avroto-M2814 800g ~7A
RCTimer BC3536/11 800g ~7A
Looks like RCTimer has same performance as Avroto, but RCTimer is 2,5x cheaper. Am I right?
evvaldis is offline Find More Posts by evvaldis
Old Oct 20, 2011, 06:57 PM
windfou's Avatar
Joined Dec 2008
maybe cheaper but the weigth of the 3536 rc timer is 2x , but for a low budget like me i will go with the rc timer
but for long lasting i will go with the avroto , i don' think the rc timer can hold 4s for a long period
Old Oct 22, 2011, 03:44 PM
Romania, Dolj, Craiova
Joined Sep 2007
Why 4S? No idea who spread this misconception that high S is good, because for efficiency is not.
BL motors are not efficient at low curents, such 3536 class motor best efficiency is in the 10-15A range.
Look at the MT2814 test results table, the higher the voltage, the lower the efficiency
http://flyduino.net/T-Motor-MT2814-710KV
You should go to 4s only if you really need that thrust, but, who need 2kg per arm ?
Other criteria is props max rpm, the props used in copter are in the 6-7000 range maximum. APC 10" SF for example is 6500.
750kv * 11V is already more than 6500
renatoa is offline Find More Posts by renatoa
Latest blog entry: JRSky - birth of a dream radio
Old Oct 23, 2011, 01:42 PM
windfou's Avatar
Joined Dec 2008
the reason why some use 4s is for reducing vibration they use smaller props ,smaller props are more easy to balance but need more rpm to obtain the same trust with a bigger props also and also for better stability when you descend fast and cause less drag
my next set up will be with 4S but with avroto motor for long lasting
Old Oct 23, 2011, 02:06 PM
Joined Sep 2007
Got it.
Question: what about Tiger motors?
They looks as a duck, walk like a duck, quack as a duck... but 2/3 price of avroto...
I see flyduino started to sell them as premium motors, are they or not the real mfr of avroto ?
Old Oct 25, 2011, 05:57 PM
drcigg's Avatar
United States, MN, Chaska
Joined Sep 2011
Wow what a great resource for everyone. Thank you for taking the time to do this. This will help us all immensely when assembling our next multicopter
drcigg is offline Find More Posts by drcigg
Old Nov 01, 2011, 06:06 PM
Mortimer's Avatar
Joined Apr 2010
Thanks to holco for this interesting thread.
My participation :
Motors :
- Flycam 925KV
- Turnigy Park 450 890KV
- T-Motor MT2216-10 900KV
Propeller : GF 10x4.5
ESC : Hobbywing Pentium 30A
Battery : Turnigy nano-tech 3300 mAh 25-50C
Flycam 925KV :
Turnigy Park 450 890KV :
T-Motor MT2216-10 900KV :
My test bench :
More to follow.
Mortimer is offline Find More Posts by Mortimer
Old Nov 01, 2011, 06:27 PM
Joined Dec 2010
Got it.
Yes, they are the same!
But I actually find this Tiger more interesting:
http://rcflight.se/visaprodukt.aspx?id=1656
Look at the efficiency numbers...
Malx is offline Find More Posts by Malx
Old Nov 01, 2011, 06:30 PM
RC Farmer
Farmer_Joe's Avatar
Joined Aug 2011
Great tests guys.
I find Mortimer tables more user friendly to read, because rpm is not relay useful data. For me most important is W to g.
Farmer_Joe is offline Find More Posts by Farmer_Joe
Old Nov 01, 2011, 06:54 PM
Joined Dec 2010
No, No and a big No. You can't use those tables to say that higher voltage gives lower efficiency. They are more or less using full power on each voltage level and efficiency is of course lower for a higher wattage output/higher trust level. The only thing those tables are good for is comparing efficiency at different TRUST levels. (And to get max trust at different voltage levels)
The only way to compare efficiency at different voltage levels is to measure the wattage at the same trust level but different voltages.
I agree, great tests but really hard to read the graphs. Including g/W (or W/g) would help a lot.
Old Nov 02, 2011, 09:25 AM
Mortimer's Avatar
Joined Apr 2010
Good idea.
It's done, look at the graphs above.
Old Nov 19, 2011, 01:34 PM
Joined Jul 2009
What prop is GF 10x4.5 supposed to mean? Do you mean Glass Fiber MPI EPP1045's?
patricklupo is offline Find More Posts by patricklupo
Discussion Airfoil Comparison Database Yak 52 Modeling Science 4 Oct 10, 2010 03:16 PM
Discussion Motor weight database GoatZilla Power Systems 2 Feb 23, 2006 11:43 AM
RCgroups DIY motor performance database button Power Systems 2 Jun 10, 2005 07:56 PM
GoBrushless Motor Database RFI Jay C Power Systems 88 Aug 20, 2004 07:42 AM
Motor Database F.Littleton Electric Plane Talk 8 Nov 16, 2003 09:31 AM
