Old Jun 24, 2012, 08:50 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
I have seen the numbers for 2814 700-770kv motors on 4s and most that I see show 11x4.7 and 12x3.8 are highly efficient and put a lot of thrust.
I also have 2216 800kv on 4s with 10x4.5 and they output a decent amount of thrust
That might give you a ballpark.
Both are used to carry a Sony Nex5 in Y6 frame type.
Adidas4275 is offline Find More Posts by Adidas4275
Old Jun 24, 2012, 11:01 PM
aForcefulThrust is offline
Find More Posts by aForcefulThrust
aForcefulThrust's Avatar
United States, LA, New Orleans
Joined Jun 2012
Thanks for the info! I'm thinking just fork out the extra cash for avroto's or the sunnysky 700kv's. Your 2216's don't get hot on 4s with 10"?
Is it just me or are the avroto and the RC-Timer BC-3536/11 (750KV) VERY similar? What would the advantage of avroto be here?
aForcefulThrust is offline Find More Posts by aForcefulThrust
Old Jun 24, 2012, 11:10 PM
voltaren is offline
Find More Posts by voltaren
Joined Apr 2012
Originally Posted by Lyyar View Post
MT2212 750KV has about 600g thrust (3S and prop APC 10x4.7)
see table at the end of this link:
http://rctigermotor.com/show.php?contentid=145
6x600=3.6kg
but at least at 50% of thrust you should start to hover, so ... 1,8kg-2kg us max for you copter.
2500g / 6 motors = 416g per motor at 50% thrust, so I will try to find motor with 900g of thrust at least. I suggest something around 1000-1100g for comfortable flight. For instance MT2216 800 or 900 or 1100KV
L
Originally Posted by RENATOA View Post
As above, if you don't have clearance for 12" prop, go for higher kv motors.
Or think to 4s.
thx for your advise, do you think with 2,5kg AUW 2x3cell 5000 mah 10x4.7 prop
what will you reccomend between MT2216 800 ,900 or 1100 kv?
voltaren is offline Find More Posts by voltaren
Old Jun 24, 2012, 11:35 PM
Adidas4275's Avatar
Joined Mar 2011
you are going to fly 2x5000mah packs? that is a TON of battery!
Old Jun 24, 2012, 11:40 PM
voltaren is offline
Joined Apr 2012
i dont know how many flight time if im using 1x3cell 5000 i just assume 2x3cell 5000 make it to 3cell 10000mah iwill get longger flight time, but its just my plan now im flying with 1x3cell 5000
anyone know how much maximum thrust DJI 2212 920kv motor with 3cell and 4cell?
and which one between MT2212 and DJI 2212 can handle more payload?
Old Jun 25, 2012, 12:29 AM
Joined Jun 2012
Anyone know about the iPower 2814Q? It's cheap, long wires, and 750kv. Any opinions on that one?
Old Jun 29, 2012, 05:30 PM
boiko is offline
Find More Posts by boiko
Home of A-10 - Farmingdale NY
boiko's Avatar
United States, NH, Londonderry
Joined Dec 2006
Low cost motors for high performance DJI F330..?
I'm thinking about maybe building a smaller Quad (DJI F330)...
Of all the motors listed in this thread (or any others) what do you guy's recommend for low cost/max performance motor(s)? The DJI F330 frame can only run 8" props..so any motor selection would have to run well with that size prop.
-mike-
boiko is offline Find More Posts by boiko
Old Jun 29, 2012, 05:54 PM
Captain3D is offline
Find More Posts by Captain3D
Captain3D's Avatar
United States, CA, Brisbane
Joined Jan 2012
sunnysky X2216 1250kv?
http://www.himodel.com/electric/SUNN...ess_Motor.html
Apart from the collet prop mount. I love these punchy motors.
phil
Captain3D is offline Find More Posts by Captain3D
Old Jun 29, 2012, 06:28 PM
Mortimer is offline
Find More Posts by Mortimer
Mortimer's Avatar
Joined Apr 2010
My last test, 2 motors and 10 propellers.
Turnigy Park450 890KV 150W - 28mm diameter - 65g
and Park480 850KV 250W - 35mm diameter - 78g
I like these motors, I use them for many months.
10 propellers: APC 8x3.8, 9x4.7, 10x4.7, 11x4.7, 12x3.8, GemFan 10x4.5, Graupner 10x5, 11x5, GWS 9x5x3 and HK 10x6.
Turnigy Nano-Tech 3S 4000mAh 35-70C
Hobbywing Pentium 30A - Timing mode: Middle
Turnigy Servo Tester and Micro Tacho, GWS Servo Tester MT-1
Junsi PowerLog 6S Wattmeter - LogView software - Soehnle scale
These measuring devices are not lab grade but are suitable for a comparison.
Tests have been made in two steps:
1 - Half throttle, most significant, usually used for hover
2 - WOT, maximum thrust and current
The Turnigy Servo Tester used has a fixed center position giving a 1.486ms pulse. Max pulse is 1.976ms.
Here is what I've got:
Best efficiency with 890KV 150W motor on 3S : GRAUPNER 11x5
and with 850KV 250w motor on 3S : APC 12x3.8
Hoping it will be useful for somebody.
My previous test : hexTronik DT700 and 24 propellers
Mortimer is offline Find More Posts by Mortimer
Old Jun 29, 2012, 07:51 PM
bestever is offline
Find More Posts by bestever
Joined Jun 2011
Got them recently. Can't tell you much about them because the only experience I had before with brushless was with the DT750.
1) cheap indeed
2) long wires confirmed
3) nice,true prop adaptor with out of ballance "spinner nut" (problem solved with 6mm nuts)
4) bought 4, one had faulty bearings unfortunately. The other three run VERY smooth!!
5) use them on my AUW 2.3kg quad on 4s lipo with jxf 11x5 wooden props and get plenty of power, i hover @ 50% throttle
6) visual inspection gives me the impression of good quality.
7) got them directly from iPower in China and their customer service is excellent!
8) they are smooth
bestever is offline Find More Posts by bestever
Old Jul 01, 2012, 03:01 PM
macanaw is offline
Find More Posts by macanaw
Joined May 2012
I am using the Avroto M2814-11s V3 on my quad, the problem I'm running into is that the motors act like they are not getting enough juice when I give it alot of throttle. It's much worse on 4s than 3s. The balleries are Zippy 45c 5800's and the esc's are HobbyKing 30a blue series. I'm not sure if it's the motors, esc, cotroller refresh rate, etc..
Has anyone else seen this in their testing?
David
macanaw is offline Find More Posts by macanaw
Old Jul 01, 2012, 04:32 PM
philg31 is offline
Find More Posts by philg31
Hairy Hampster.
Australia, VIC, Barwon Heads
Joined Apr 2012
David
Have you programmed the ESC`s David?
philg31 is offline Find More Posts by philg31
Old Jul 01, 2012, 05:13 PM
macanaw is offline
Joined May 2012
They hae deafult settings.
Lipo
RPM - Off
Start - soft
brake - off
timing - auto
cutoff volatage - 3.0
cutoff power - reduce
David
Old Jul 01, 2012, 05:30 PM
philg31 is offline
Hairy Hampster.
Joined Apr 2012
Lipo
RPM - Off
Start - soft
brake - off
timing - auto
David
There is a programming card you can buy for the Blue series David.
http://www.hobbyking.com/hobbyking/s...dProduct=13431
MIght be worth a look.
Old Jul 01, 2012, 10:27 PM
macanaw is offline
Joined May 2012
Have it already, gonna try changing the cut off to 2.8v and set the timing to low. If that doesnt do it i'll nail it to the ground and set the cut off to Stop. If the motors stop then it must be an ESC issue as the Naza says voltage is fine.
David
Discussion Airfoil Comparison Database Yak 52 Modeling Science 4 Oct 10, 2010 03:16 PM
Discussion Motor weight database GoatZilla Power Systems 2 Feb 23, 2006 11:43 AM
RCgroups DIY motor performance database button Power Systems 2 Jun 10, 2005 07:56 PM
GoBrushless Motor Database RFI Jay C Power Systems 88 Aug 20, 2004 07:42 AM
Motor Database F.Littleton Electric Plane Talk 8 Nov 16, 2003 09:31 AM
