Old Feb 12, 2011, 10:13 AM
all4smallrc is offline
Find More Posts by all4smallrc
Founder of the EDF20 club!
all4smallrc's Avatar
Minnesota
Joined Apr 2008
18in Viperwing tailless flying wing with AR6400 and retractable gear! Video!
I've had it flying for a while, but just now decided to share it. This is an 18in Viperwing, the smallest ARF tailless flying wing in the world! I set this one up with an AR6400L, a Parkzone Sukhoi motor, a Zippy 240mah lipo, and retractable landing gear, actuated by a HobbyKing 2.5g servo. It weighs 35g and produces roughly 25g of thrust with a 2.25in prop. Because this wing has no vertical surfaces, drag is exceptionally low, allowing superb performance, even with an underpowered system. It will cruise around at just over half throttle, climb surprisingly well, and glide well too. It is capable of performing a variety of basic aerobatics. The top speed, according to my well trained eye, is around 30ish. Flight time has not been timed yet, but seems to be around 10-15min. If you want to see this thing fly in person, I'll be bringing it to Iowa in a week (http://www.expodome.org/). You can buy one for yourself too! I'll have pre-built airframes available (no landing gear) that just require electronics.
all4smallrc is offline Find More Posts by all4smallrc
Old Feb 12, 2011, 10:42 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Looks great and I love the Retracts.
What Motor/Prop are you running. Is that a 8.4mm Sukhoi motor?
I'm looking for good 2.25 props.
UNGN is offline Find More Posts by UNGN
Old Feb 12, 2011, 10:58 AM
Minnesota
Joined Apr 2008
Yep, 8.4mm Sukhoi motor. The prop is a BP 2.25in prop (http://bsdmicrorc.com/index.php?productID=662). I've been very happy with this setup.
Old Feb 12, 2011, 11:05 AM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
Have you ever tried a Tri-Turbo with these motors?
TODD
I R Irv is offline Find More Posts by I R Irv
Old Feb 12, 2011, 12:34 PM
Minnesota
Joined Apr 2008
I don't like how fragile they are, but I suppose I should try it with one.
Old Feb 22, 2011, 04:50 PM
Minnesota
Joined Apr 2008
While in Iowa, I decided to try the Tri-Turbo prop. It had much more power, but flight times lacked a bit due to more amps being drawn. I could still fly for about 8-10 minutes though. Here is a video of the Viperwing demonstration I did during the air show on Sunday.
Viperwing demonstration (0 min 50 sec)
Old Feb 22, 2011, 05:00 PM
gklein is offline
Find More Posts by gklein
Gary
gklein's Avatar
USA, CT, Sandy Hook
Joined Dec 2009
Can we see the details on your retracts?
gklein is offline Find More Posts by gklein
Old Feb 22, 2011, 05:09 PM
Minnesota
Joined Apr 2008
It's really pretty simple. It's just modified Sukhoi landing gear that is hinged on the foam with small heat shrink tube. Stainless steel wires link the gear to the servo. Simple as that. The hard part was getting the front and rear landing gear to travel the right amount in proportion to each other. It was just a matter of changing the length of the wire for the front gear in relation to the hinge point though.
Old Feb 22, 2011, 06:57 PM
I R Irv is offline
I R Irv's Avatar
Joined Nov 2008
Looks great SMALL, glad the Tri-Turbo worked out. I wouldn't call a 8-10 min flight lacking. Also looks like it slows down nice. If you get a brighter video please post it.
TODD
Old Feb 22, 2011, 08:37 PM
Minnesota
Joined Apr 2008
It does slow down nice. The wing loading is much lighter than most of the Parkzone models. For having as much wing sweep as it does, it sure has a massive speed range. And surprisingly, even when you slow down a lot, you don't have to pull up very much to compensate the cg shift. At first, I was kind of disappointed with how dark the video turned out too (it was cloudy outside, and they had the lights off). Now though, I think it is better this way. The Wing still shows up well, so it is much easier to see than it would be if the background was brighter.
Old Feb 26, 2011, 09:00 AM
Ron Williams is offline
Find More Posts by Ron Williams
slow but inefficient
Ron Williams's Avatar
Riverhead NY USA
Joined Dec 2000
That's kind of a thin description when you could post a couple of pictures of the underside of the wing with no more difficulty than the first two pics you posted. The whole project is really neat.
Ron Williams is offline Find More Posts by Ron Williams
Old Feb 26, 2011, 09:16 AM
Minnesota
Joined Apr 2008
Uh, yeah, about that. I kinda broke the landing gear off in Iowa. That's why I caught it in the vid. I tried landing coming right out of a turn and one wheel touched down before the other one, causing it to rotate sideways. Then the other wheel caught the high grip floor and snapped the gear. I don't have any spare Sukhoi landing gear to replace it with.
Old Mar 14, 2013, 07:21 PM
addictedtoplanes is offline
Find More Posts by addictedtoplanes
and helis!
addictedtoplanes's Avatar
Canada, ON, Guelph
Joined Jun 2012
wow! how much for kits?
addictedtoplanes is offline Find More Posts by addictedtoplanes
Old Mar 14, 2013, 08:02 PM
PeteSchug is offline
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
Except for scale I tend to fly micros without landing gear anyway. Grass is unkind to LG and I hate looking like I crashed even when I've done a good landing.
Pete
PeteSchug is offline Find More Posts by PeteSchug
Old Mar 15, 2013, 12:26 PM
Minnesota
Joined Apr 2008
Due to RCGroups rules, I probably should not talk business here. Send me an email at orders@all4smallrc.com and I will get back to you. Thanks!
New Product The Horten Tailless Flying Wing Ė Letís Build One Together! SoarScale2 Scale Sailplanes 100 Jul 12, 2013 01:50 PM
Cool Viperwing EDF30 100% pure flying wing with nothing but elevons! all4smallrc Micro EDF Jets and Power Systems 20 Jan 01, 2011 03:45 PM
Discussion Euroclydon True Stable Tailless Stable Flying Wing flashted Flying Wings 0 Jul 11, 2009 06:59 PM
Time to define 'flying wing and other tailless aircraft' TheAeronut Flying Wings 63 Jul 20, 2004 03:10 PM
Need help with chooseing retractable landing gear. KOMET 44 Power Systems 1 Jan 06, 2002 09:37 AM
