Old Mar 19, 2011, 02:02 PM
dimar is offline
Find More Posts by dimar
Joined May 2009
http://www.mwjournal.com/Journal/Com...tenna/AR_8587/
wouldn't this be a simpler solution?
dimar is offline Find More Posts by dimar
Old Mar 20, 2011, 12:31 AM
teebok is offline
Find More Posts by teebok
teebok's Avatar
Pico Rivera, CA
Joined Apr 2004
Anyone know if these CP cloverleaf antennas work with the fatshark goggles? I just got a set of these but they dont work at all with the fatshark 5.8ghz. All i get is a black screen. The goggles work fine with the stock antennas. Im using the immersionRC 600mw TX.
The cloverleafs do work on my Iftron yellowjacket 5.8 RX
teebok is offline Find More Posts by teebok
Old Mar 20, 2011, 01:52 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
I found this statement in the description:
By using the gain comparison method, the measured gain of the proposed antenna is 0.2 dB.
0.2db "gain"... Well, antenna "gain" is usually compared to an imaginary idealized omni directional antenna that radiates like a ball evenly in all directions (that's where the "i" comes from with the unit dBi) or to a dipole with the former being the most often used. So this antenna would have five times less "gain" than basically no gain (1 dBi).....
I think almost everyone can make his/her cloverleaf with some practice and patience. The mentioned antenna uses PCB fabrication technologies and teflon substrate. I don't think that this would be easier for hobbyists.
The antenna has surely a potential in mobile handheld devices which are supposed to be rugged and mass produced.
Markus
markus123456 is offline Find More Posts by markus123456
Old Mar 20, 2011, 11:10 AM
Pipe Merchant is offline
Find More Posts by Pipe Merchant
Pipe Merchant's Avatar
Joined Mar 2011
My cloverleafs work fine on my 5.8 fatshark goggles. That seems like a rather odd problem...
On a side note, I finally had a chance to test them out at the field yesterday, and the experience was incredible! The increased confidence from using these antennas is just amazing - I couldn't get the smile off my face
Pipe Merchant is offline Find More Posts by Pipe Merchant
Old Mar 20, 2011, 11:40 AM
Rizzak is offline
Find More Posts by Rizzak
Joined Mar 2011
Hmmm. Would one of these RHCP CL antennas work well on the VTX with a 15dB Yagi on the RX? (lawmate 1 watt system 1280mhz) or is some modification needed. OR will two CL's beat out the Yagi? Also can I diversify using two CL's on two receivers to get a better cross beam width for slightly less liner long range flights?
Rizzak is offline Find More Posts by Rizzak
Old Mar 20, 2011, 12:54 PM
yogz is offline
Find More Posts by yogz
oxford uk
Joined Aug 2010
I am probably being a complete numpty here... so feel free to shoot me down in flames. The use of two or more receivers is fairly common place. I was wondering if it is possible to have two antenna's on the Tx side. My own obvious guess is no... for lots of reasons, not least of which would be how to join for arguments sake a clover leaf and an inverted v and not have the active element 'start' where the join is rather than the intended start of the active and ground. Is it possible to run to Vtx's on seperate frequencies - say 900 and 2.4 and have receiver diversity give you best at screen? Spent first spring day mowing lawns and tidying garden.... think the fresh air is confusing my nuerons
Paul
yogz is offline Find More Posts by yogz
Old Mar 20, 2011, 01:53 PM
flight01 is offline
Find More Posts by flight01
DODOLAND
Joined Feb 2009
Hi guys,
a couple of pict of my CL and set up as promise.I have flown up to 1 km in all direction without any noise in the video.
Anthony.
flight01 is offline Find More Posts by flight01
Old Mar 20, 2011, 02:04 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Paul
You can use two TX antennas if properly coupled and phased appropriately, but generally this is a bad idea and I would not recommend trying it.
And using two frequencies is redundancy that is not needed. Just try a circularly polarized system and see what I mean. The last three crashes I had were running out of radio range because my video was rock solid the whole way. And my radio has been tested out over 2 miles and repeatedly has no trouble out that far. That should tell you something about the power of these antennas.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Mar 20, 2011, 02:05 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Use a CL and a helical. Forget the Yagi. Trust me, once you fly CP on both ends, you'll never look at that Yagi again.
-Alex
Old Mar 20, 2011, 02:06 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
What version Fatsharks are you using. Are they the V1 or V2? teebok is having trouble with his V2's and the CL antenna.
-Alex
Old Mar 20, 2011, 05:29 PM
Rizzak is offline
Joined Mar 2011
-Alex
Thanks for your help. Im looking toward a 5 mile radius with moderate obstacles and varying altitude using DL for radio link. This shows how little i now about radios but would i be better with a ground level setup or putting the helical a 30 foot antenna mast?
Old Mar 20, 2011, 09:34 PM
Kyle D. is offline
Find More Posts by Kyle D.
Kyle D.'s Avatar
Troy, Michigan
Joined May 2006
Finally got around to finishing mine. These are the first antennas that I've ever built. They took a couple tries but i finally got it. Let me know if they look alright to you guys, I don't have a lot of experience with antennas.
Kyle D.
Kyle D. is offline Find More Posts by Kyle D.
Old Mar 21, 2011, 06:27 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Your cloverleaf could use a little tweaking, but your skew-planar wheel looks exceptional!
I will release an update on this page on how to make the antenna bottom fed and much easier to construct. The way I designed mine was to be side fed and it makes it very difficult to build when feeding from the bottom. It appears most are bottom feeding theirs.
Actually, I made a video on how to do it. I just need to edit it.
-Alex
Old Mar 21, 2011, 06:49 AM
healthyfatboy is offline
Find More Posts by healthyfatboy
Joined Jan 2007
Alex,
Would these designs help at all on a ground vehicle? I'm looking to use a 500mW 900MHz Lawmate Tx on a Traxxas Summit and am wondering if this would maximize my chances of getting the best video possible.
Thanks!
healthyfatboy is offline Find More Posts by healthyfatboy
Old Mar 21, 2011, 07:52 AM
Registered FPVer :)
Joined Aug 2006
Originally Posted by healthyfatboy View Post
Alex,
Thanks!
Sorry if I jump in to add my 2 here. CP antennas are advantageous in all scenarios where the target is to reduce reflections. Therefore I think it would be pretty advantageous for a ground vehicle. Clearly, the higher the frequency, the more the effect kicks in but 900Mhz is still high enough IMHO.
A HAM antenna book I'm having says that a vertical linearized antenna system suffers a 40!!! dBi loss when moving around in a forest, wheras a horizontally aligned antenna in the samme situation has a loss of ~12 dBi and a circular polarized one suffers only 3 dBi. I think this tells a lot.
Just my 2 though
Markus
Mini-HowTo Circularly Polarized Helical antenna 7.5 -13 dbi - New: Wave Trap match! IBCrazy FPV Equipment 2402 Jul 19, 2016 11:29 PM
Mini-HowTo IBCrazy's DIY antenna tracker!!! IBCrazy FPV Equipment 460 Jul 01, 2016 06:09 PM
Mini-HowTo Fast Patch - IBCrazy's easy DIY patch antenna IBCrazy FPV Talk 359 Jun 26, 2016 02:04 PM
Build Log IBCrazy's Minion - The ultimate FPV plane IBCrazy FPV Aircraft 151 Apr 19, 2013 11:04 PM
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 06:07 PM
