I used standard steel wire. I have tried several different types from Miller to Lincoln electric to Chicago Electric. All work fine. Aluminum doesn't solder. You will need to add flux to the wire before soldering or the solder will not take. Stainless steel doesn't work very well either.
-Alex |
Latest blog entry: Project Covert Ops: Long range ground...
Higher horizontal gain. Vertical gain in the skew-planar wheel and Cloverleaf is identical.
-Alex |
Alex. I also use the 'bob' system. What plug are you useing on the RX. This is the only one that I can find that fits. Is it OK to use. It is 75ohm.
Thanks. http://cgi.ebay.co.uk/2off-f-plug-sa...item4cf5289dde |
I use an F male to SMA female adapter on the RX. This way I can use the SMA connector on my antennas.
-Alex |
oxford uk
Joined Aug 2010
![]() Blooming expensive bit of metal that!! If you need another let me know. I bend tubes I do lol. How on earth you managed to fab and solder a clover at 5.8 is well beyond me for the time being but I will be giving this a go in a couple of weeks having seen Alex's results. Alex I hope that Kempo (on the dosd thread) will give this a go. His results 4 miles out at 10m up are stunning as it is. He would be the ideal candidate to do long range testing for you! Thanks again for everyones research and sharing Paul |
Mount them as high in the air as possible. Of course they work well. They're an IBCrazy antenna
![]() -Alex |
-Alex |
Cloverleaf angles?
Alex-
Could you check my angles? I had a hard time thinking in three dimensions but I think I figured it out except for possibly the actual values. I have an opportunity to re-bend things now that it is soldered. Are the angles that I've listed correct? The actual angles probably are not those yet. pardon the ugly soldering. This was my learning one. Any other tips for construction? Thanks, Tom |
Joined Sep 2005
Hey Alex - I built a 5.8ghz cloverleaf about 2 weeks ago, but the elements have been conspiring to keep me from testing it.
I managed to get out today for a little bit, but the wind was pretty strong and my Fox is only about 200gm, so I was still held back by the wind quite a bit. I did manage about a mile (as per google earth), but the wind coming through the valley was too strong to go much further. I only started to lose the video once and I think I was just starting to get too much altitude. The mountains in the area are ~750ft high and I was convincingly above them at that point. The video was solid as a rock otherwise. Hardly exciting distances, but up until now Ive been using a 13mm wire, so its great to have a realistic antenna for this frequency. Thanks for all the DIY assistance. I dont have a picture to post right now, but Ill try and get one posted soon. |
-Alex |
| Thread Tools | |
| Mini-HowTo Circularly Polarized Helical antenna 7.5 -13 dbi - New: Wave Trap match! | IBCrazy | Video Piloting (FPV/RPV) | 1488 | Yesterday 10:43 AM |
| Mini-HowTo Fast Patch - IBCrazy's easy DIY patch antenna | IBCrazy | Video Piloting (FPV/RPV) | 293 | May 13, 2013 05:03 PM |
| Build Log IBCrazy's Minion - The ultimate FPV plane | IBCrazy | Video Piloting (FPV/RPV) | 151 | Apr 19, 2013 11:04 PM |
| Mini-HowTo IBCrazy's DIY antenna tracker!!! | IBCrazy | Video Piloting (FPV/RPV) | 242 | Mar 27, 2013 11:52 AM |
| Build Log IBCrazy's homebrew antenna tracker | IBCrazy | Video Piloting (FPV/RPV) | 48 | Oct 25, 2012 06:07 PM |
