Old Jun 14, 2011, 07:04 AM
Klaassie is offline
Find More Posts by Klaassie
The Netherlands
Joined Feb 2010
Originally Posted by scoobysport View Post
I've tried the modification as posted by klaassie, still everything is bad
Can't wait till the antenna's from Alex come in, hope that will make a difference.
Just in case it won't.... I've also ordered a 1500mw 900mhz video rx/tx combo
I already doubted you had the same problem, because you had reception at short range. With my Airwave video-Rx, when I attached the CL/SPW-antenna video-reception was totally gone. Even without antenna it was better!
What type of Airwave-module is in your Fatshark? Is there anything like "AWMxxx" written on the circuit-board?
1500mw 900Mhz, bad choice IMO!
This frequency is used for mobile phone. You'd better choose 1.2Ghz 800mW or something.
Klaassie is offline Find More Posts by Klaassie
Old Jun 14, 2011, 07:46 AM
scoobysport is offline
Find More Posts by scoobysport
Joined Jun 2011
Will check the unit tonight.
I've chosen the 900mhz because a friend of mine uses a 900mhz 1watt, he's very pleased with the results he's getting.
scoobysport is offline Find More Posts by scoobysport
Old Jun 14, 2011, 08:03 AM
Carlos230023 is offline
Find More Posts by Carlos230023
um.. yeah, I can make that fly
Carlos230023's Avatar
United Kingdom, Milton Keynes
Joined Jun 2007
I use the same. I've just turned the Tx to the highest channel it can use to get above the phone signals. I think it's at 1010Mhz.
CJ
Carlos230023 is offline Find More Posts by Carlos230023
Old Jun 14, 2011, 09:49 AM
SX_ is offline
SX_
Find More Posts by SX_
SX_
.........lost..........
Zambia, Lusaka, Lusaka
Joined Jun 2005
Originally Posted by IBCrazy View Post
You need a helical. I will have some 5 turn helicals for 5.8GHz available in a few weeks.
-Alex
Thanks Alex im gonna be flying 0.9G ... so the Helical will be quite Lagre off memory something like 30x40cm or 60cm
i know the Helical will have a better rejection than the CP double quad, but i have a UHF LRS on its way with the tracker.... still Helical? as the CPDQ is your newest?
for now i wont be flying more than 5-10km. so ill make a Helical 4 or 5 turn? or you fly a 4 1/4 turn?
with a Clover on the vTX ? or the SPW?
Thanks so much for your efforts still apreciate it a lot!
cheers
Willie
SX_ is offline Find More Posts by SX_
Old Jun 15, 2011, 07:41 AM
Joined Jun 2011
CJ
I'll do that as well.
This one goes up tot 1.040;
Frequency: 0.9G 0.910G,0.980G,1.010G,1.040G
Old Jun 15, 2011, 05:24 PM
gtrick90 is offline
Find More Posts by gtrick90
aka Nigel Uno
Italia, Lazio, Monterotondo
Joined Sep 2004
9.32 miles video with CloverLeaf antenna on vTx
http://www.rcgroups.com/forums/showt...0#post18510352
Ciao
Luca
gtrick90 is offline Find More Posts by gtrick90
Old Jun 16, 2011, 12:06 AM
rollinolin is offline
Find More Posts by rollinolin
Joined Oct 2010
Originally Posted by jon davies View Post
Any one had any trouble with these CP antennas on this 5.8GHz combi?
Any one actually using them with this combi?
Cheers.
That setup looks just like the one i got from foxtech
rollinolin is offline Find More Posts by rollinolin
Old Jun 16, 2011, 12:14 AM
QiW is offline
QiW
Find More Posts by QiW
QiW
south east asia
Joined Mar 2009
regarding the thickness of wire used to build the CL and SPW
previously i had used the same wire to make both the CL and SPW .. on 900mhz
had very good results ...
now i changed to 1.2g and made new ones as per 1.2g measurements ... 0.9mm welding wire on CL on vtx to save some weight and 2mm steel wire for the SPW on vrx to withstand some rough handling
results were BAD compared to previous set up
i will build another set with same wires and compare ... when i find the time
MUST we use the SAME WIRE SPECS for building both VRX and VTX ??
QiW is offline Find More Posts by QiW
Old Jun 16, 2011, 10:22 AM
gtrick90 is offline
aka Nigel Uno
Joined Sep 2004
I'm using 0.8mm welding wire on both tx & rx @ 1.2 and ALL works fine
Ciao
Luca
Old Jun 16, 2011, 10:42 AM
Pen is offline
Pen
Find More Posts by Pen
Pen
FPWhat?
Pen's Avatar
United States, AL, Huntsville
Joined Sep 2008
oops
Pen is offline Find More Posts by Pen
Old Jun 16, 2011, 11:41 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
No. Wire thickness is almost irrelevant. i would guess it was some outside influence that caused the lesser reception problem.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Jun 16, 2011, 11:48 AM
QiW is offline
QiW
QiW
south east asia
Joined Mar 2009
test was done in the SAME EXACT LOCATION (in my house)
with all the same electrical appliances wifi etc etc ON
the only difference was the frequency used .. previously 980mhz .. now 1160mhz
tried a few different frequencies on the setup from 1080-1200mhz .. same results (BAD)
out of wire now .. will report back once i get new wires .. same ones on vtx and vrx
Old Jun 16, 2011, 06:20 PM
Joined Jun 2011
Here are the pics of the Rx:
Old Jun 16, 2011, 08:11 PM
JLager is offline
Find More Posts by JLager
Canada, BC, North Vancouver
Joined Apr 2011
Wasn't sure where to post this and maybe it's been answered already but I was wondering if the Cloverleaf and Skew Planar Wheel antenna don't cause a lot of aerodynamic drag or whatever you want to call it?
I was planning to put a 1.3Ghz one on the wing but was worried that it will have a big effect on how the plane flies.
Anyone have any experience with this?
JLager is offline Find More Posts by JLager
Old Jun 16, 2011, 09:40 PM
Joined Oct 2010
foxtech 5.8ghz 200mw tx and rx
I got it in the mail and have got it to work for about 2 minutes max. it keeps going in and out.
its like it wont switch channels when i try different ones. on the tx it seems to work when i have sw#3 down and the rest up ch6 i believe. but the rx doesnt tune to it. It is distorted.
what can be causing this?
I am trying everything stock
Mini-HowTo Circularly Polarized Helical antenna 7.5 -13 dbi - New: Wave Trap match! IBCrazy FPV Equipment 2402 Jul 19, 2016 11:29 PM
Mini-HowTo IBCrazy's DIY antenna tracker!!! IBCrazy FPV Equipment 460 Jul 01, 2016 06:09 PM
Mini-HowTo Fast Patch - IBCrazy's easy DIY patch antenna IBCrazy FPV Talk 359 Jun 26, 2016 02:04 PM
Build Log IBCrazy's Minion - The ultimate FPV plane IBCrazy FPV Aircraft 151 Apr 19, 2013 11:04 PM
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 06:07 PM
