Old Jun 13, 2011, 01:28 PM
bajas is offline
Find More Posts by bajas
making big holes in the sky..
Scandinavia
Joined Aug 2009
Here is my report...
First I want to say: THANK YOU IBCRASY..
I have tried out my mig-tread CL and SPW on my 2,4ghz video on my KK-quad a couple of times.
I dont fly far with my quads, but I do like to fly low... lower the better..
With the CL/SPW combo I can fly my quad 40km/h 30cm over the tarmac 200meters away standing next to a concrete building without any drop-outs or glitches in the video. Its like having the camera pluged in with cable into my goggles. There is NO WAY this is possible with "old linier" system with a rubberduck/patch bombo. With my old linear setup there was a lot of signal reflection and interference in the video.
PS:: this is with a $10 100mw vTX from ebay..
CP with CL/SPW is now my standar for short distance fun flying...
bajas is offline Find More Posts by bajas
Old Jun 13, 2011, 02:04 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by tkeeg View Post
Alex,
A few weeks ago I purchased a Cloverleaf & a Skew-Planar Wheel antenna from you for a 1280MHz receiver & transmitter setup. They are working well and I wanted to buy a second Cloverleaf for my other drone. Do I have to specify a right or left handed orientation or do you only make one kind. I want it to be the same as the first Cloverleaf antenna I got from you so it will work with the Skew-Planar Wheel antenna of yours that I already own. I just have no idea on if they are right or left handed.
Please advise.
Tom
I have only made a few LHCP as special orders. Yours are RHCP.
IBCrazy is offline Find More Posts by IBCrazy
Old Jun 13, 2011, 02:05 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by teopbako View Post
Can i use the same wire for a 2.4GHz Cloverleaf, a 2.4GHz CP Helical 7 turnand a 1280MHz Helical 7 turn??
If yes what size should i use?
Thank you
Teo
No. Helicals should use a fairly thick wire. As thick as you can possibly wind it. I use 6AWG on my personal helicals for 1280MHz.
-Alex
Old Jun 13, 2011, 04:00 PM
SX_ is offline
SX_
Find More Posts by SX_
SX_
.........lost..........
Zambia, Lusaka, Lusaka
Joined Jun 2005
Hey Alex
I just wanted to say im very happy with my clovers! they fly great!
I bought a tracker(will be here in a week or so) and was wondering what the best antenna would be on it im thinking your CP patch or double BiQuad??
and should i rather go to a SPW for the plane?
I still wan to put a diversity on as well with a SPW/clover rx for close flight....
Willie
SX_ is offline Find More Posts by SX_
Old Jun 13, 2011, 04:17 PM
foufly is offline
Find More Posts by foufly
Joined May 2010
over head flying
I fly a lot overhead,high. Would your cloverleaf solve the polarity problem I get doing this .Thanks , foufly
foufly is offline Find More Posts by foufly
Old Jun 13, 2011, 04:23 PM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Flying overhead with linear polarized antennas is not a "polarity problem" but based on the fact that the radiation pattern of all real world antennas is not like a ball but can take a lot of different shapes. The shape (or radiation pattern) depends very much on the type of antenna used. A rubber duck (asuming that's what you use) has a pattern that resembles a bit an apple. So there is a weak signal spot on top and on the bottom, good distribution around it. The skew planar wheel (which you would use on the rx end) is a bit similar, but according to my experience its still better than a rubberduck as the weak signal spot seems to be smaller. So if you are not after flying absolutely above yourself you should be good to go. If you need to fly directly above yourself, get a helical as your reciver antenna and use an antenna tracker.
HTH
Markus
markus123456 is offline Find More Posts by markus123456
Old Jun 13, 2011, 04:30 PM
Pen is online now
Pen
Find More Posts by Pen
Pen
FPWhat?
Pen's Avatar
United States, AL, Huntsville
Joined Sep 2008
For the CL/SPW combo, I still see different opinions on which goes on the VTX and which on VRX. Is there a clear winner or is one way better sometimes and sometime the other?
I have SPW on VTX and CL on VRX. Wondering if I would get better performance the other way around. I would just switch them and see for myself but my SPW has a 90 built in and the CL has no 90, so would not be an easy swap.
Pen is online now Find More Posts by Pen
Old Jun 13, 2011, 05:04 PM
clipper99 is offline
Find More Posts by clipper99
Oh so close!
clipper99's Avatar
Campbell River
Joined Jan 2010
Different opinions? The only one that matters for me is IBCrazy himself, the man, the myth, the LEGEND, says the CL goes to the TX and the SPW goes...well, you'll figure it out.
cheers
clipper99 is offline Find More Posts by clipper99
Old Jun 13, 2011, 05:38 PM
gtrick90 is offline
Find More Posts by gtrick90
aka Nigel Uno
Italia, Lazio, Monterotondo
Joined Sep 2004
CL on vTX rocks!!
Also with a patch or rubber duck on vRx.
For LOS 5/8 km go with CL on both rx/tx
For LOS > 8 km go with CL(tx)/Helical 5/7 turns (rx)
(with vTx 1.2GHz 800mW)
Ciao
Luca
gtrick90 is offline Find More Posts by gtrick90
Old Jun 13, 2011, 05:47 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
cheers
Yes. CL on TX, SPW on RX. ReadyMadeRC has their picture backwards
-Alex
Old Jun 13, 2011, 05:49 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by SX_ View Post
Hey Alex
Willie
You need a helical. I will have some 5 turn helicals for 5.8GHz available in a few weeks.
-Alex
Old Jun 13, 2011, 08:02 PM
flyboy321 is offline
Find More Posts by flyboy321
RC = FUN
Fort Wayne, Indiana
Joined Aug 2008
Anyone else have crappy video with LM CP combo? It might just be my new DL TX, but my video was horrible today with the new Lawmates. -Tyler
flyboy321 is offline Find More Posts by flyboy321
Old Jun 14, 2011, 04:23 AM
zea is offline
zea
Find More Posts by zea
zea
Joined Mar 2011
well, it seems that it is not a good camera can get good pics. if you wanna get good pics, you need a good complete FPV kit.
zea is offline Find More Posts by zea
Old Jun 14, 2011, 05:28 AM
scoobysport is offline
Find More Posts by scoobysport
Joined Jun 2011
I've tried the modification as posted by klaassie, still everything is bad
Can't wait till the antenna's from Alex come in, hope that will make a difference.
Just in case it won't.... I've also ordered a 1500mw 900mhz video rx/tx combo
scoobysport is offline Find More Posts by scoobysport
Old Jun 14, 2011, 06:58 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Is it really bad, as in your video flashes in your screen? If this is the case, your RX battery is low. If your Dragonlink is an older model (ie more than 2 months old) it has a harmonic right on the 1280MHz badn and will kill reception.
-Alex
Mini-HowTo Circularly Polarized Helical antenna 7.5 -13 dbi - New: Wave Trap match! IBCrazy FPV Equipment 2402 Jul 19, 2016 11:29 PM
Mini-HowTo IBCrazy's DIY antenna tracker!!! IBCrazy FPV Equipment 460 Jul 01, 2016 06:09 PM
Mini-HowTo Fast Patch - IBCrazy's easy DIY patch antenna IBCrazy FPV Talk 359 Jun 26, 2016 02:04 PM
Build Log IBCrazy's Minion - The ultimate FPV plane IBCrazy FPV Aircraft 151 Apr 19, 2013 11:04 PM
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 06:07 PM
