Old Feb 17, 2011, 10:33 PM
volto is offline
Find More Posts by volto
Navigator
volto's Avatar
USA, CO, Durango
Joined Sep 2010
Have fun skiing Alex! I need to hit the slopes again too before it all melts =)
volto is offline Find More Posts by volto
Old Feb 18, 2011, 06:12 PM
matyou is offline
Find More Posts by matyou
matyou's Avatar
Bay Area California
Joined Dec 2009
Hi all,
Well after having a bunch of fun making the Vee I decided to start making a cloverleaf antenna. I used 0.027 copper magnet wire just to try it out before I get some .035 mig wire. I did everything to the best of my ability and understanding of the instructions but Im not getting much performance out of the antenna when used along with a rubber ducky for the VRX. Below are some pictures I took to see if anyone can help me out.
matyou is offline Find More Posts by matyou
Old Feb 18, 2011, 07:17 PM
volto is offline
Navigator
volto's Avatar
USA, CO, Durango
Joined Sep 2010
If I understand correctly, you need a circular polarized antenna on both sides; tx and rx, to get good performance. Rubber ducky is linearly polarized.
Old Feb 18, 2011, 07:24 PM
matyou is offline
matyou's Avatar
Bay Area California
Joined Dec 2009
With a linear and a circular antenna you lose about 3db but still should work. I have a feeling that I did something wrong.
Old Feb 18, 2011, 07:26 PM
workshop is offline
Find More Posts by workshop
Closed Account
Joined Nov 2004
dbi Mismatch Basics
V to V = 0dbi
V to H = -26dbi
i.e. dbi can change from 0 to -26dbi in a 90 degree bank
CP to L (V or H) = -3dbi
Stays -3dbi when the antennae change angles
CP to CP = 0dbi
Stays 0dbi when the antennae change angles
RHCP to LHCP = -26dbi
Stays -26dbi when the antennae change angles
So one should see a marked improvement in multipath rejection and consistancy of video in a turn but not longer range with a CP and L combo.
Jeff
workshop is offline Find More Posts by workshop
Old Feb 18, 2011, 07:57 PM
matyou is offline
matyou's Avatar
Bay Area California
Joined Dec 2009
Jeff,
Have you tried this antenna yet? I wonder why I cant get any good performance from it? Does it look right?
Matt
Old Feb 18, 2011, 08:03 PM
BloomingtonFPV is offline
Find More Posts by BloomingtonFPV
KC9TPL- Get Legit
BloomingtonFPV's Avatar
USA, IN, Bloomington
Joined Aug 2007
Originally Posted by workshop View Post
V to V = 0dbi
V to H = -26dbi
CP to CP = 0dbi
Jeff
Doesn't a -3dbi change translate roughly into losing half your distance (range)? If so, this sounds like a lot. I'm trying to decide if I can mix CP and inverted Vs on different planes but have the same vertical patch on my rx.
BloomingtonFPV is offline Find More Posts by BloomingtonFPV
Old Feb 18, 2011, 08:33 PM
workshop is offline
Closed Account
Joined Nov 2004
I've tried the antenna on the bench and it burrows through walls! Simply amazing...
I've used CP on the RX side for years and it changed the hobby. -3bdi down still means two miles (w/ standard rubber duck on the TX) but with a consistant image of which I can depend.
NOW... with CP on both sides, I am really excited...
Jeff
Old Feb 18, 2011, 09:22 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by matyou View Post
Hi all,
I can see many problems:
1. Your angles are not correct. You need to come off that center conductor at 45 degrees with each element.
2. You are using RG174 coaxial cable. Chances are you heated it up too much and the center element shifted internally. RG174 has poor heat characteristics.
3. We have no idea where you are mounting this. Location makes a difference.
4. You need a CP antenna on the RX side too. Try a helix or another cloverleaf. Multipath with omnis is a killer. Believe it or not, when receiving with a linear omni antenna, a CP antenna makes the multipath problem worse!
5. The thin wire will distort very easily in the wind causing sporadic power level changes. VTX units do not adapt well to this.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Feb 18, 2011, 09:23 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Jeff
And I've got some new stuff coming out soon. Wait until you try it
-Alex
Old Feb 18, 2011, 11:42 PM
volto is offline
Navigator
volto's Avatar
USA, CO, Durango
Joined Sep 2010
-Alex
Wow already?! Glad I haven't started building this one yet
Old Feb 19, 2011, 03:02 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
I thought that the original had 4 elements, but now I see 3. Would a 4 be better?
Flypoppa is offline Find More Posts by Flypoppa
Old Feb 19, 2011, 08:11 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Build this one. It is the center piece of it all. All of my other antennas are Rx antennas that revolve around this one.
-Alex
Old Feb 19, 2011, 08:13 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
They are different antennas. The 4 lobe is the skew-planar-wheel. The 3 lobe is the cloverleaf. The cloverleaf has higher gain, but less reverse polarity rejection.
-Alex
Old Feb 19, 2011, 08:36 AM
Drednox is offline
Find More Posts by Drednox
Drednox's Avatar
Joined Jan 2011
Question:
What's type of mig wire is better to use? Steel, carbon steel, high or low nickel content, aluminum? Also, did you run into any problems soldering the wire?
Drednox is offline Find More Posts by Drednox
Mini-HowTo Circularly Polarized Helical antenna 7.5 -13 dbi - New: Wave Trap match! IBCrazy FPV Equipment 2407 Sep 01, 2016 06:01 PM
Mini-HowTo Fast Patch - IBCrazy's easy DIY patch antenna IBCrazy FPV Talk 360 Aug 08, 2016 10:44 AM
Mini-HowTo IBCrazy's DIY antenna tracker!!! IBCrazy FPV Equipment 461 Aug 07, 2016 09:36 PM
Build Log IBCrazy's Minion - The ultimate FPV plane IBCrazy FPV Aircraft 151 Apr 19, 2013 11:04 PM
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 06:07 PM
